Damping factor
Thread: Damping factor
  • Short URL:  http://modifika.si/97103
    Damping factor
    How important the damping factor of an amplifier to power up a dedicated midbass or sub IN REALITY ?
    i've read about damping factor in the net saying that the higher the damping factor, the tighter the bass becos damping factor shows how amplifier control the driver's cone movement when no signal, means decay is faster.
    but is this really true in reality ?
    and about ARC SE amp, ARC rated the damping factor of 1600 while caraudiomag tested the damping factor, it comes out of only 160 !!! --->> here : http://www.caraudiomag.com/reviews/c...annel_amp.html
    is ARC really overrated their amp or is this a mistake ?
    Jakarta, Bandung
    4 Days 5 Hrs 36 Mins 41 Secs
    I wouldn't worry too much about amplifier's damping factor
    Damping factor is simply speaker's nominal impedance divided by amp's output impendance.
    Now, we know that speaker's impendance varies by frequency.
    So, damping factor calculated at 1Khz will be different than one calculated at 500hz for example.
    Infact, too high damping factor may be the result of negative feedback. And too much negative feedback may resulting phase shift.
    As for controlling cone movement, damping factor does count on this matter. But the speaker's mechanical structure impacts more than amp's damping factor.
    So, no need to worry lah...
    Most of tube amps as well as class D amps do have lower damping factor than class A/B.
    The Altair - HiFi Speaker
MBtech Mitsubishi
  1. Peredam - Noise Damping yang benar
    By LA_Light in forum UnSCAC- Hwely Audio
    Last Post: 14th March 2009, 00:40
  2. 101 in Amp Damping
    By nicric in forum Diskusi Power Amplifier
    Last Post: 29th November 2007, 07:54
  3. nanya power yg damping factornya gede
    By dexza in forum Diskusi Power Amplifier
    Last Post: 27th August 2006, 14:39
  4. factor terpenting
    By marlyn in forum Diskusi Instalasi
    Last Post: 28th July 2006, 17:32
