CRESCENDO NEW OPUS 9.6 - 2 WAY COMPONENT SPEAKER SET
Results 1 to 10 of 29
  • Short URL:  http://modifika.si/97027
    IG @ascentti
    1 Wk 2 Days 17 Hrs 26 Mins 29 Secs
    Thumbs up CRESCENDO NEW OPUS 9.6 - 2 WAY COMPONENT SPEAKER SET
    READY STOCK !!!
    NEW CRESCENDO OPUS 9.6 - 2 WAY COMPONENT SPEAKER SET
    PLEASE CALL FOR PRICE !!!
    PRODUCT REVIEW =
    Opus 9.6 is the top line Crescendo 2-way speaker offering best performance from end to end. Reproduction of high is sharp and transparent, reproduction of midrange is liquid, and reproduction of midbass is deep and clean. Opus 9.6 is certainly the best choice when 3-way speaker is not applicable.
    Opus 9.6 consists of T3R (tweeter), MB-6 (midbass-driver), and X9.6 (passive crossover), all in 1 pair.
    T3R tweeter is the best tweeter in Crescendo speaker line so far. Its unique dome material, coating, and damper are designed to reproduce accurate and natural highs without flaws. The concave ring shape enhances the high extension for extra smooth and relaxing high. T3R uses aluminum housing with back chamber for resonance frequency as low as 850 Hz. Therefore, the frequency response is 850 Hz to 20 kHz in 3 dB scale. The back chamber is rounded to reduce the mounting depth and create wider soundstage. T3R is complimented with 2 curvy bars grill for protection and 10 centimeter of Harmonic Harmony UP-OCC solid silver for fine tuning of sound. The only weakness, if considered as weakness, is quite long break-in time. It should be played at least 100 hours to achieve its maximum performance.
    The MB-6 midbass-driver is the same as used in Crescendo Opus 8.6.
    The X9.6 passive crossover separates MB-6 and T3R at 2.5 kHz. X9.6 is different from the rest of Crescendo 2 way passive crossover because the 3 positions switch only allows adjustment of tweeter level but the Q factor remains un-changed. The component is absolutely high quality to make sure there is no weak link in the chain. The capacitors for high pass and low pass are all Jantzen Cap from Denmark. The resistors are all Mills and Ohmite from USA. The coils/inductors are all air-core 18AWG size. Since the coil is air-core, Opus 9.6 is not as efficient as other 2 way Crescendo speakers. But, it still can be driven by head unit’s internal amplifier of certain brand and type.
    PRODUCT PICTURES =
    INSTAGRAM @ascentti
    LINE @ascentti
    BBM PIN = ascentti
    YouTube Channel = ascentti
    17 Hrs 26 Mins 3 Secs
    Quote Originally Posted by ascentti View Post
    READY STOCK !!!
    PRODUCT REVIEW =
    The X9.6 passive crossover separates MB-6 and T3R at 2.5 kHz. X9.6 is different from the rest of Crescendo 2 way passive crossover because the 3 positions switch only allows adjustment of tweeter level but the Q factor remains un-changed. The component is absolutely high quality to make sure there is no weak link in the chain. The capacitors for high pass and low pass are all Jantzen Cap from Denmark. The resistors are all Mills and Ohmite from USA. The coils/inductors are all air-core 18AWG size. Since the coil is air-core, Opus 9.6 is not as efficient as other 2 way Crescendo speakers. But, it still can be driven by head unitís internal amplifier of certain brand and type.
    PRODUCT PICTURES =
    nice.......
    IG @ascentti
    Quote Originally Posted by rin_dix View Post
    nice.......
    Thanks boss :smt033
    INSTAGRAM @ascentti
    LINE @ascentti
    BBM PIN = ascentti
    Thanks boss :smt033
    gue ud pernah dgr masalahnya...pake power genesis profile tape alpine lupa seri apa buat pasif custom alhasil saya tdk berani komentar dgn anggaran total kt si pemiliknya 14jt bs ngalahin kelas yg 30jt krn pengaplikasiannya benar tidak asal pasang dgn perhitungan pasif yg bener pula obat yg paling vital and paling mujarab. saya sendiri dgr ampe kaget...sistem sederhana bkn berarti jelek tergantung tangan sapa yg pegang.
    IG @ascentti
    BETUL SEKALI !!! Bumbu yang sama di tangan koki yang berbeda bisa menghasilkan cita rasa yang berbeda boss ... Gw pasang di mobil customer gw dengan keadaan pasif standard,angkat pakai McIntosh suaranya LUAR BIASAAA ... HU pakai CD 700 II,TOB MARKOTOB
    INSTAGRAM @ascentti
    LINE @ascentti
    BBM PIN = ascentti
    mantap deh....racikan bumbunya!!! di jejelin mcintosh pula
    ayo brg mantap dibeli donk....:smt098
    IG @ascentti
    Thanks boss !!! :smt098
    INSTAGRAM @ascentti
    LINE @ascentti
    BBM PIN = ascentti
    Jakarta Barat
    Pak Ascentti,
    Harga speaker ini berapa ya?
    IG @ascentti
    Quote Originally Posted by Seopu View Post
    Pak Ascentti,
    Ini boss Leo yg tadi call saya ya ?
    INSTAGRAM @ascentti
    LINE @ascentti
    BBM PIN = ascentti
