READY STOCK !!!
NEW CRESCENDO OPUS 8.6 - 2 WAYCOMPONENT SPEAKER SET
PLEASE CALL FOR PRICE !!!
PRODUCT REVIEW =
Opus 8.6 is all round performers that provide high definition and deep bass. This speaker is the starting point where midrange texture is clearly reproduced. Complimented with emotion and harmony, Opus 8.6 is the right way to go.
Opus 8.6 consists of T1R (tweeter), MB-6 (midbass-driver), and X8.6 (passive crossover), all in 1 pair.
The T1R tweeter is the same as used in Crescendo Opus 5.
MB-6 is the best midbass-driver in Crescendo speaker line at the moment. It is better than MG-6 in reproducing midrange texture and providing better definition and even deeper midbass. MB-6 shares the same ‘die cast’ chassis as MS-6 and MG-6 so the outer diameter is also 7 inches to take advantage of deeper midbass and easier to blend with subwoofer. MB-6 is using polypropylene cone that we consider as the perfect balance between sound, appearance, and durability. The terminal is gold plated for best connection. Its nominal impedance is 8 ohm because our design team faced the fact that 8 ohm driver is somehow better than 4 ohm driver. We challenged ourselves to create very high sensitivity driver to compensate for the amplifier’s power drop and the result is: “MB-6 has the same loudness as MG-6 with the same amplifier power”.
The X8.6 passive crossover separates MB-6 and T1R at 3.5 kHz. It provides 3 positions switch to adjust tweeter level and Q factor at the same time, in order to achieve smooth blending between both drivers. The passive crossover component can be considered high grade at this price range. The capacitor for high pass is using Jantzen Z-Standard Cap from Denmark and the resistor for tweeter is specially ordered from USA. The coil/inductor for low pass is using metal core for efficiency so that Opus 8.6 can be driven directly from head unit's internal amplifier.
PRODUCT PICTURES =
