CRESCENDO NEW OPUS 5 - 2 WAY COMPONENT SPEAKER SET
Rgotogel Simota 36Goal.com
Results 1 to 10 of 28
  • Short URL:  http://modifika.si/97022
    IG @ascentti
    1 Wk 2 Days 15 Hrs 32 Mins
    Thumbs up CRESCENDO NEW OPUS 5 - 2 WAY COMPONENT SPEAKER SET
    READY STOCK !!!
    NEW CRESCENDO OPUS 5 - 2 WAY COMPONENT SPEAKER SET
    PLEASE CALL FOR PRICE !!!
    PRODUCT REVIEW =
    Opus 5 is the legendary Crescendo speaker that has won a lot of trophies in Sound Quality Competitions, especially when 2 way front system is a must and budget is limited. In this new version, the midbass is stronger, the midrange is more liquid, and the high is even more detail.
    Opus 5 consists of T1R (tweeter), MG-6 (midbass-driver), and X5 (passive crossover), all in 1 pair.
    T1R tweeter is the first tweeter that Crescendo produces. The metal housing design is original, which includes diffraction and phase into calculation to produce clear and transparent high without harsh. The engineering process took 1.5 years before arriving at the first batch that was called T1R v1 back in the year of 2005. It uses aluminum housing in matte finish and packed with 2.5 meters of Harmonic Harmony 'Acapella' speaker cable. The v1 did not have the curvy bars grill.
    After 1 year, T1R v2 was introduced. It uses aluminum ring in black chrome finish with 'Crescendo' engrave. The complimentary cable is changed to 1 meter of Harmonic Harmony 'Interlude' speaker cable for further fine tuning of sound. T1Rv2 had two curvy bars grill which improved protection and enhance appearance with minimal sound disturbance.
    August 2007 was the stand point when we decided to extrude our own aluminum configuration that we consider the best for sound. It was noted as the birth of T1R v3. The finishing was changed to shiny polish and the 'Crescendo' logo is now printed in color. The result is, again, improved sound quality and appearance.
    T1R v4 was launched in March 2008 with new silk dome material and new coating to improve transparency and phase characteristic for smoother blending with the midbass-driver.
    Starting from November 2008, T1R v5 is in the market until now. The ring shape is slightly adjusted to produce even better high and more focus midrange. T1R v5 is a mature Crescendo tweeter with the best sound at its price range. The resonance frequency is 1,500 Hz and the frequency response is 1,500 Hz up to 20 kHz in 3dB scale. Although the specification is the same as T1RP, the sound reproduction is different in any way. T1R has better attack, sharper, clearer, and more liquid.
    The new MG-6 midbass-driver is an improvement from the previous version with better midrange quality and more kick in the midbass. MG-6 shares the same ‘die cast’ chassis as MS-6 so the outer diameter is also 7 inches to take advantage of deeper midbass and easier to blend with subwoofer. Don't worry about its flexibility because the magnet size is small and we have studied thoroughly to verify that MG-6 can be installed in almost any car without hassle. MG-6 is using polypropylene cone that we consider as the perfect balance between sound, appearance, and durability. The terminal is gold plated for best connection. The resonance frequency is 46 Hz and the frequency response is 46 Hz up to 7 kHz in 3dB scale. With wider frequency response, MG-6 is considered better than MS-6 in reproducing more natural vocal and deeper midbass.
    The new X5 passive crossover separates MG-6 and T1R at 3.5 kHz. It provides 3 positions switch to adjust tweeter level and Q factor at the same time, in order to achieve smooth blending between both drivers. The passive crossover component can be considered high grade at this price range. The capacitor for high pass is using Jantzen Z-Standard Cap from Denmark and the resistor for tweeter is specially ordered from USA. The coil/inductor for low pass is using metal core for efficiency so that Opus 5 can be driven directly from head unit's internal amplifier.
    PRODUCT PICTURES =
    INSTAGRAM @ascentti
    LINE @ascentti
    BBM PIN = ascentti
    YouTube Channel = ascentti
    Smile
    bos tny hrg crescendo opus 5 nya brp an?klo di pasang untuk yaris dengan HU standar tanpa power bs gak?
    IG @ascentti
    Quote Originally Posted by dutz_dutz View Post
    Hi boss
    Harga nanti kita PM kan yah
    Untuk Yaris dengan H.U std bisa koq , suara pasti naik jauh !!!
    Minat?hehehe
    Trims
    INSTAGRAM @ascentti
    LINE @ascentti
    BBM PIN = ascentti
    PM harganya dong y...
    Trims...
    IG @ascentti
    Quote Originally Posted by A 1210 Wa View Post
    Trims...
    Harga sudah kita PM boss .. thx
    INSTAGRAM @ascentti
    LINE @ascentti
    BBM PIN = ascentti
    4 Days 3 Hrs 23 Mins 23 Secs
    pm jg bos hrgnya thx
    IG @ascentti
    Quote Originally Posted by jycrois View Post
    PRICE PM-ed boss
    INSTAGRAM @ascentti
    LINE @ascentti
    BBM PIN = ascentti
    thx boss kudu nabung dulu hehehehe
    IG @ascentti
    Bisa aja si boss
    hehehe
    ditunggu ya pemasangannya
    INSTAGRAM @ascentti
    LINE @ascentti
    BBM PIN = ascentti
    21 Hrs 35 Mins 47 Secs
    boleh di pm harganya bro??
Venom 300x250 MBtech
