Engine swap yg nga umum....dan cerita2 kecil lainnya...
Results 1 to 10 of 29
  • Short URL:  http://modifika.si/94982
    Batavia
    4 Days 5 Hrs 25 Mins 33 Secs
    Thumbs up Engine swap yg nga umum....dan cerita2 kecil lainnya...
    Toy-Jet - Worlds’s First LS1 Porsche 911 Conversion… Porsche on the Outside, LS-1 Engine on the Inside. CRAZYNESS INDEED!! Check it out, its for real and upon a quick analysis this modified 911 must kick ASS to drive!
    The SUPERCHARGED Z06 engine seems to fit beautifully in the back of this 911, and apparently weighs less than the original Porsche engine.
    I absolutely love this guys descriptive writeup:
    Warning: Make sure you are buckled up and the car is lined up perfectly parallel to the roadway before take off.
    1st gear is short and brief.
    At the instant you shift into second gear, then disengage the clutch, you will find yourself pinned into the seat while blood rushes violently towards the back of your head to feed this sensation. The violence has just began. This Beast when held in second gear, to 7000 revolutions per minute, will shift out at about 85 to 90mph. Unfortunately this does not give you much time to recuperate.
    3rd gear allow you to recover briefly, but only after you reach 5500 rpm.
    The Supercharger boost is almost instantaneous. This makes it very difficult to convince your passenger you are not secretly pushing a 200 shot of NOS while accelerating this Beast through the
    gears.
    4th gear will take you well beyond take-off speed for the average 747-Jet plane.
    5th gear is ridiculous. This gear is for those who are insane or have no fear. The faster you go the less courage you may experience, unless you have seniority in the Indy car drivers club. You will find yourself short shifting into fifth gear at about 165mph. only to disappear into the sunset.
    This Beast is only as ferocious as the nut behind the steering wheel. With all of the above considered, it is also quite docile. My wife uses this car for getting groceries and going to the local neighborhood meetings.
    In Conclusion:
    This Beast is Awesome, Insane, but also very fun and exciting to drive.
    The radiator is mounted under the wing (image above)
    His #1 FAQ: How long did it take to invent the LS1 Porsche 911 & 914 conversion?
    Answer: Thirty one days from start to finish, working daily after normal work hours.
    … I smell an Engineer
    His quarter mile time to date is (11.94 sec at 114 mph) and was accomplished with a conservative take off because of the stock Porsche axles.
    Weight of LS1 engine -vs- the Porsche 3.0 stock engine: 56 lbs. lighter
    Weight of (ToyJet) cooling system -vs- stock Porsche Wing: - 35 lbs. heavier
    The porsche 911 equipped with the LS1 conversion and Toy-Jet cooling system installation yields a
    combined weight savings of 21 pounds lighter at the rear of the vehicle!!!
    Want to know WHY he did it?
    Mohon Cendolnya.......
    "Trust is my power to success"
    Batavia
    iseng2......cendol yaaaah
    nanti saya posting lanjutannya
    "GTR R35 kenceng?, nga juga...."
    Batavia
    mohon comment dan cendolnya.... drpd maen fesbuk.
    Palembang.
    6 Days 10 Hrs 51 Mins 52 Secs
    tuh cendol senddd
    terusin dongg
    SOHC VTEC
    next to gaia, earth goddess
    4 Days 8 Hrs 49 Mins 11 Secs
    yang pasti berat tuh modifikasi drive terainnya deh, plus transmisi posisi jadi ditengah :confused:
    musti dicek tuh pake adopsi apaan
    Batavia
    Quote Originally Posted by kikosky View Post
    itu urusan yg pasang deh bos
    ky nya masih pake transmision porsche nya
    beautiful job indeed
    depok timur, jakarta, semarang, samarinda, makassar
    5 Days 8 Hrs 7 Mins 56 Secs
    ditunggu kisah selandjoetnya pak
    menarik!
    Batavia
    cendol dulu donk.....
    Batavia
    tuh cendol senddd
    terusin dongg
    rep power gw masih 1 bos?
    cendol apanya?
    kalo video ini gimana??
    sory ga bisa nampakin..ehhehe
    link : http://www.youtube.com/watch?v=TFp_e4nDHGQ
  1. Swap Engine Honda Nova to B-engine
    By soundpump in forum Diskusi Mesin
    Last Post: 29th June 2015, 14:50
  2. Q # ENGINE WORKS : PnP, Engine Swap, Etc
    By coki.de auto in forum de Auto Motorsport
    Last Post: 28th May 2015, 03:37
  3. Replies: 19
    Last Post: 12th July 2012, 23:45
  4. Replies: 0
    Last Post: 30th June 2012, 14:53
