CRESCENDO NEW OPUS 7 - 2 WAY COMPONENT SPEAKER SET
Results 1 to 10 of 53
  • Short URL:  http://modifika.si/93979
    IG @ascentti
    1 Wk 2 Days 15 Hrs 32 Mins
    Thumbs up CRESCENDO NEW OPUS 7 - 2 WAY COMPONENT SPEAKER SET
    READY STOCK !!!
    Opus 7 is the only speaker in Crescendo line equipped with big size tweeter. It provides excellent transparency and dispersion control. The new version comes with aluminium front ring for better sound and appearance.
    Crescendo Opus 7 specification:
    1. 2 way speaker system.
    2. Tweeter: T2R.
    3. Midbass: MG-6 v4.
    4. Passive crossover: X-7 v2.2.
    5. Tweeter cone material: 25 mm soft fabric dome.
    6. Midbass cone material: non-pressed flare polypropylene.
    7. System nominal impedance: 4 8 ohm.
    8. Frequency response +/- 3db at 30 degree off axis: 50 Hz 20 kHz.
    9. Crossover point: 3.5 kHz.
    10. Power handling: 30 60 Watt (full range), 30 100 Watt (High Pass at 50 Hz or above).
    11. Tweeter outside diameter: 143 mm.
    12. Tweeter ring thickness: 52mm.
    13. Tweeter mounting hole: 75 mm.
    14. Tweeter mounting depth: 27.5 mm.
    15. Midbass outside diameter: 176.5 mm (6.95 inch).
    16. Midbass ring thickness: 5.5 mm.
    17. Midbass mounting hole: 147 mm.
    18. Midbass mounting depth: 71 mm.
    19. Midbass magnet size (diameter x height): 79 x 25 mm (very small size).
    20. Passive crossover capacitor: Jantzen Z-Standard Cap for added warmth.
    21. Passive crossover resistor: Ohmite Audio resistor for clear high.
    Thiele-Small parameter and impedance curve of the tweeter and midbass can be downloaded on each driver category.
    Crescendo Opus 7 sound characteristic:
    1. High is clear & detail.
    2. No harsh or over sibilance.
    3. Midrange is bold and natural.
    4. Midbass has good authority and definition.
    5. Dispersion control is exceptional thus creating realistic imaging.
    6. Musical emotion and harmony is apparent.
    7. It is suitable for all kind of music.
    Crescendo Opus 7 is the right choice for those who love dispersion control of big tweeters.
    INSTAGRAM @ascentti
    LINE @ascentti
    BBM PIN = ascentti
    YouTube Channel = ascentti
    2 Days 8 Hrs 5 Mins 3 Secs
    wah
    kalo cresendo opus uda ga salah pilih deh..
    harganya itu loh.. sangat2 terjangkau utk mendapatkan kualitas yg sangat baik..
    gw sndiri uda pake cukup lama n uda ngerasainnya sendiri
    gw bilang ini kualitas suara speaker yg paling bgs di level harga tersebut..
    cmiiw
    2 Wks 5 Days 10 Hrs 58 Mins 11 Secs
    harganya berapaan nih bos??
    13 Hrs 43 Mins 27 Secs
    bisa PM harganya
    opus 5 kalo ada sekalian
    buat perbandingan
    SunTer & BSD City
    1 Wk 16 Hrs 25 Mins 32 Secs
    wih, ini mantep bner, tweeternya msh 4 inch ga? harga brp yah skrg??
    IG @ascentti
    Quote Originally Posted by [ Magic^X ] View Post
    wah
    cmiiw
    Betul banget boss..kalau bisa dibilang ini BEST VALUE untuk speaker di harga kisaran segitu ...
    BTW main2 boss ke bengkel kita,nanti kita ngobrol2 soal audio dan pernak perniknya ...
    INSTAGRAM @ascentti
    LINE @ascentti
    BBM PIN = ascentti
    IG @ascentti
    Quote Originally Posted by jazz_31 View Post
    Harga sudah di PM boss .. thx
    INSTAGRAM @ascentti
    LINE @ascentti
    BBM PIN = ascentti
    IG @ascentti
    Quote Originally Posted by ed88fi View Post
    bisa PM harganya
    buat perbandingan
    PM SENT BOSS !!!
    INSTAGRAM @ascentti
    LINE @ascentti
    BBM PIN = ascentti
    IG @ascentti
    Quote Originally Posted by DV View Post
    Masih boss .. harga gampang lah sama ente mah .. hehehe
    Alvin
    INSTAGRAM @ascentti
    LINE @ascentti
    BBM PIN = ascentti
    SunTer & BSD City
    Quote Originally Posted by ascentti View Post
    Alvin
    biar tau gtu kisaran harganya, biar ane bisa siapin budget, hahaha..
    opus 7 ama CFS 3 bagusan mana nih vin?
    klo pake opus 7 lgs msk d rmh tweeter gw yg lama kan brarti yah??
Venom 300x250 MBtech
