Numpang Jual Strut bar tuk Avanza/Xenia
Page 1 of 5 12345 LastLast
Results 1 to 10 of 42
  • Short URL:  http://modifika.si/91720
    A strut bar, strut brace, or strut tower brace (STB) is a mostly aftermarket car suspension accessory usually used in conjunction with MacPherson struts on monocoque or unibody chassis to provide extra strength between the strut towers.
    With a MacPherson strut suspension system where the spring and shock absorber are combined in the one suspension unit, the entire vertical suspension load is transmitted to the top of the vehicle's strut tower, unlike a double wishbone suspension where the spring and shock absorber may share the load separately. In general terms, a strut tower in a monocoque chassis is a reinforced portion of the inner wheel well and is not necessarily directly connected to the main chassis rails. For this reason there is inherent flex within the strut towers relative to the chassis rails.
    A strut bar is designed to reduce this strut tower flex by tying two parallel strut towers together. This transmits the load of each strut tower during cornering via tension and compression of the strut bar which shares the load between both towers and reduces chassis flex.
    RR Modcom,
    saya ingin jual strut bar tuk Avanza/Xenia,buatan sendiri.Materialnya dari plat besi tebal 10mm.
    Ada 2 model seperti gambar..
    Saya jual 285ribu,ongkos kirim gratis tuk wilayah Jakarta dgn catatan jarak raius 5-6Km dari M2Square atau BSD Serpong..
    YG berminat bisa call saya di 08125876894 atau viankirsta3@gmail.com
    Model pertama
    Model kedua
    Model ketiga
    up..up..bagi yg mau merasakan bantingan lebih nyaman dgn avanza/xenia-nya
    Up..up..yg mau pasang strut bar
    Up..Up...yang ingin tampil lebih OK dan bisa dapat murah...
    Jawa Tengah & Jawa Timur
    tolong Pm nya dong bos...
    Quote Originally Posted by nds ben2 View Post
    Bos udah saya jawab lewat PM
    Kalau gak terdeteksi..SMS saya di 08125876894 cukup kirim email ID nanti akan saya jawab by email..
    up..up...yg mau pasang strut bar
    Up..Up bagi pemilik Avanza/Xenia
    He..he...bantu up bro...
    smoga sukses jualannya...
    pokoke dijamin rapi dan presisi hasilnya.
    Quote Originally Posted by gue.tedi View Post
    Thanks bro..udah pakai produk saya
GT Radial MBtech
  1. strut bar avanza/xenia murah !!
    By God of speed in forum Jual Beli Mesin Lainnya
    Last Post: 30th May 2010, 05:42
