[wts] engine damper spoon bolt on honda fit
Results 1 to 10 of 13
  • Short URL:  http://modifika.si/89406
    dijual cepet nee.. kondisi mulu 99% ..
    utk pemasangan dijazz hanya butuh ubah engine mounting sedikit. krn ini bolt on Fit.
    pengubahan bisa dilakukan di tuner" terdekat.
    hrga 1,6 jt.
    include mounting (tuker sama mounting std anda) + 100rb
    contact : Nicz - 0813-88098888
    naek up up up..
    naek up up up..
    naek up up up ..
    naek up up up ..
    naek up up up ..
    naek up up up..
    jakarta utara
    2 Wks 1 Day 23 Hrs 47 Mins 5 Secs
    nich maksudnya brang ap om?
    Quote Originally Posted by kambingcongek View Post
    Benefits:
    *Greatly improved off-the-line acceleration
    *engine damper will provide reduced wheel hop
    *engine damper will provide improved vehicle stability
    *Reduced shock loads on driveline components
    *engine damper will provide Smoother shifting
    *engine damper reduced wear on exhaust system joints
    *Less vibration transmission to the driver compared to polyurethane motor mounts.
    *Less shock load, compared to torque straps and chains.
    *Drifting helps reduce shock loads when wheels gain traction.
    *engine damper reduces motor movement decreases the chance of motor parts rubbing against the hood and frame.
    naek up up up ..
  1. WTS: SPOON Engine Damper GD3 & Spoon Sport Throttle Body
    By BMZL in forum Jual Beli Mesin Lainnya
    Last Post: 28th March 2012, 20:33
  2. WTS : rep.SPOON black duracon & rep.spoon engine damper for GD3
    By RdiSun in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 1st March 2012, 13:00
  3. SALE : Spoon Engine Torque Damper Civic FD2
    By Rboy in forum Jual Beli Mesin Lainnya
    Last Post: 6th July 2011, 20:32
  4. WTS : engine damper replica spoon(civic EG)
    By weeQz in forum Jual Beli Mesin Lainnya
    Last Post: 7th March 2011, 12:09
  5. Replies: 39
    Last Post: 24th June 2010, 09:18
