WTS: BMW Scanner Diagnostic Tool
Results 1 to 10 of 15
  • Short URL:  http://modifika.si/88872
    8 Hrs 46 Mins 12 Secs
    Thumbs up WTS: BMW Scanner Diagnostic Tool
    Dijual BMW Scanner Diagnostic Tool
    Kondisi 99%, beli cuma untuk memuaskan rasa penasaran saja.
    Harga 1,5jt nego, posisi surabaya
    Spesifikasi:
    BMW Carsoft 6.5 Diagnose Interface OBD2 OBD OBDII
    MCU controlled Interface for Carsoft 6.5 which is compatible with the original interface. Fully digital line switchings and MCU controlled service reset timing.
    Main Functions:
    Digital total test: It gives you a complete idea of the overall condition of the car
    Digital single test: It gives you detailed information about the appropriate control unit. Stored errors will be shown in a written report. This report has a short info-text which help you to eliminate the error.
    Special functions for some models: Including service interval reset, component activation, live data, LCM reading, sync. EWS and ECU, adaptation values, and coding.
    Application list:
    E30 / E31 / E32 / E34 / E36 / E38 / E39 / E46 / E53 / Z-3 / Z-8
    Petrol Engines : All engines from 1988 to 2004
    Additional Features :
    - LIVE DATA 1995-2004
    - ECU CODING 1995-2004
    - ADAPTATION 1995-2004
    - EWS Synchroniza tion 1995-2004
    E30 / E34 / E36 / E38 /E39 / E46 / E53
    Diesel Engines : All engines from 1988 to 2004
    - ELIVE DATA 1998-2004
    - ECU Coding 1998-2004
    - EWS Synchronization 1995-2004
    E30 / E31 / E32 / E34 / E36 / E38 /E39 / E46 / E53 / Z-3 / Z-8
    Brake & Traction : All systems from 1988 to 2004
    Airbag : All airbag systems from 1988 to 2004
    - ECU Coding 1995-2004
    Air-conditioning : All HKL systems from 1988 to 2004
    BC / MID : BOARD COMPUTER / MULTI INFORMATION DISPLAY
    Instrument Clusters from 1991 to 2004
    - ECU Programming 1995-2004
    - Change Mileage / Kilometres indication
    - Change Time indication 24/12 hours scale
    - Change Language indication into 9 different Languages
    - Change Temperature indication Celsius / Fahrenheit
    DWA : Alarm Systems
    Including : ALARM ACTIVATION COUNTER E34
    LCM / CCM : ALL LIGHT/CHECK CONTROL MODULES up to 2004
    - Reading Original Mileage / Kilometres
    - Reading Chassis ( VIN ) Number
    E30 / E31 / E32 / E34 / E36 / E38 / E39 / E53 / E46 / Z-3 / Z-8
    ZKE / ZVM : All body systems from 1988 to 2004
    - Compleete Activation 1988-2004
    - Auto-Lock after more than 20KM/h
    - Selective opening (for example: driver door only)
    EGS : All gearbox systems from 1988 to 2004
    EWS : All Immobilize Systems from 1995 to 2004
    - Synchronization with engine ECUs up to 2004
    E38 / E39 / E46 / E53 / Z-8
    CVM : Soft top systems to 2004 E46 (some E36 & Z3)
    PDC : All Park Distance Systems from 1995 to 2004
    Service Interval : All Service Systems from 1988 to 2004
    - Service Light Reset 1988-2004
    - Service Management 1995-2004
    - Reading of Days since last service
    - Reading of Fuel Consumption since last service
    - Programming of next Service / Inspection
    Package included:
    1x BMW OBD2 Interface
    1x OBD2 connection cable
    1x Serial cable RS232
    1x BMW connection cable
    1x Software CD
    Hub. 0817317095
    YM: dewagenit
  2. Jaya Bet
    sundul dulu, mana tau ada yg penasaran mau scan biem sendiri
    wah sepi yah
    3 Hrs 37 Mins 44 Secs
    pengin seh tapi takutnya bingung malah nggak bisa makai, ini fungsinya utk apa seh? hanya nyecan aja yah?
    Quote Originally Posted by ukik View Post
    Kita bisa diagnosa kondisi mobil, apa ada yg trouble atau tidak.
    Misal kita nyopot setir, nah itu kan berakibat lampu airbag nyala, nah alat ini buat resetnya.
    Begitu juga misal lampu ABS nyala, nah kita bisa scan untuk mengetahui apa rusaknya, trus kita benerin rusaknya dan reset.
    Fungsi lengkapnya dah saya jelaskan diatas, gampang kok makenya.
    kolong langit
    1 Day 6 Hrs 53 Mins 17 Secs
    termasuk reset indikator (oil inspection / engine check)..?
    PM super-nett price ya om.. skalian tanya nama / merk scannernya, setau saya ada 2 jenis yg biasa dijual buat bmw klo di luar. Trims
    booked by B45
    UPDATE : SOLD TO B45. Thx yg dah respon.
    ya elah kalah cepet hehehehe, nasib dah
    he he kalo masih ada yg minat boleh ntar saya bantuin masukin lagi. diabsen dulu sapa-sapa aja yang mau nitip. proses pemesanan kurang lebih 2 minggu. mau?
Venom 300x250 Vkool
  1. WTS : Engine Diagnostic Launch X431 Scan Tool
    By rickey168 in forum Jual Beli Mesin Lainnya
    Last Post: 31st March 2011, 12:32
  2. Diagnostic Tool - Launch x431 TOOL BARU Service Mesin
    By mnm in forum Jual Beli Mesin Lainnya
    Last Post: 1st June 2010, 02:01
  3. STAR Diagnostic
    By elite in forum Diskusi Kaki-Kaki
    Last Post: 16th March 2010, 09:48
  4. DIAGNOSTIC SOCKET CEFIRO
    By ~B~ in forum Diskusi Mesin
    Last Post: 14th February 2008, 00:53
