nanya Power 4ch angkat 1 sub DVC
Results 1 to 10 of 29
  • Short URL:  http://modifika.si/8871
    DKI/BSD
    1 Wk 3 Days 2 Hrs 12 Mins 24 Secs
    mo nanya nih..
    klo misalnya aku punya
    1 power 4 ch anggaplah 4x100w di 4ohm, bridge 2x400w di 4ohm....(total 800w)....
    trus 1 subwoofer DVC 4ohm, rms 500.....
    bisa ga yah...voice coil (terminal) pertama diangkat pake ch.1 dan ch.2 yg di bridge trus voice coil kedua diangkat pake ch.3 dan ch.4 yg di bridge juga...
    jadi 1 sub DVC 4ohm 500w bisa dan aman ga diangkat pake 1 power 4ch yg dibridge?????
    ____________
    0812-951-3972
    Searching......... Unknown!
    9 Hrs 15 Mins 14 Secs
    Bisa aja sey, tapi kalo masalah aman.... Hmmm :smt017
    Maksud gw, power handling sub 500 watt dikasih makan 800 watt, don't you think that's just a little overkill???
    Just make sure gain disetel di level yang sama biar imbang dan seminim mungkin.
    DKI/BSD
    mmm dari segi rangkaian ga masalah ya....
    dr segi power handling sub vs power pasti di samain wattage to paling ndak gainnya..
    tp kayaknya susahnya mgkn dr segi imbangnya gain...apalagi masing2nya punya bass boost masing2...
    efeknya apa ya..kalo gain ato vol basboost antara voice coil atu ama yg laennya ga bener2 imbang ....
    ____________
    0812-951-3972
    Cipete, SoutH Of JakaRtA.
    1 Day 21 Hrs 37 Mins 39 Secs
    Emangnya bisa yah prakteknya Power 4ch cm buat ngangkat 1 sub DVC? Kalo bisa gw pgn nyobain nih..
    DKI/BSD
    Quote Originally Posted by Aradea
    heheee..itu pertanyaannya bos..
    ""A single dual voice coil driver offers the user three hookup choices...parallel, series and independent"" -- ""Finally, you can wire each voice coil to a separate channel of your amplifier, which can be useful if your amplifier is not mono-bridgeable or if you are bridging a four channel amplifier down to two channels to run your sub""
    itu gw kutip dr tutorial yg gw temuin di web nya JL Audio
    kayaknya gw lom prnh lihat/denger wiring kaya gitu...makanya nanya ada yg pernah nyoba ga?
    ____________
    0812-951-3972
    brarti teori nya bisa dong bro, tp gw takut nyoba kalo temen2 disini blum pernah nyobain jg.
    Lo yg nyoba mau ga bro?, tar kabarin gw hasilnya hehehehe..
    DKI/BSD
    penasaran ....pengen nyoba, tp takut ngerusak sub nya
    ____________
    0812-951-3972
    3 Hrs 59 Mins 45 Secs
    lebih aman sih jgn...soale kalo gainnya ga seimbang dikit ajahh subnya bisa pincang coilnya...that's can burn the subs...
    meding pake amps 2ch gede di bridge 2ohm ato pake mono skalian...
    over power lebih baik di banding underpower...
    1 Mth 1 Wk 2 Days 16 Hrs 40 Mins 59 Secs
    Pengalaman gue seh gak papa.........dulu gue pake Lanzar 4 ch dibikin jadi 2ch buat ngangkat sub DVC tapi subnya 1 biji ........jadi di subnya dibikin independent.........lalu gue pake sub bost dari power......he...he.......
    jakarta-seoul
    1 Wk 6 Days 4 Hrs 54 Secs
    yg penting bukannya klo wattny pas gpp? jgn ampe underpower dan jgn ampe overpower doank.. iya ga?hehehe
    gw sih dulu ngangkat sub pk power 4 channel, soalnya yg ada itu ya udah dpake aja..hehehe
    think 1st before u post something
  1. WTA>Power buat angkat sub.
    By FeeL in forum Diskusi Power Amplifier
    Last Post: 20th February 2009, 15:12
  2. Power utk angkat JL w7 10"
    By tiar in forum Diskusi Power Amplifier
    Last Post: 19th March 2008, 23:01
  3. Power buat angkat sub
    By BASS in forum Diskusi Power Amplifier
    Last Post: 13th February 2008, 21:59
  4. power buat angkat T1
    By nicks in forum Diskusi Power Amplifier
    Last Post: 30th August 2007, 23:12
  5. Nanya Power tuk angkat Sub Sony 1300W
    By D3NI in forum Diskusi Audio Lainnya
    Last Post: 24th May 2007, 11:19
