Buruan deh di beli sebelum nyesel !!!
Results 1 to 10 of 21
  • Short URL:  http://modifika.si/8416
    Sebelah tetangga
    9 Hrs 37 Secs
    CONCEPT CA664 - 5 channel, specification :
    * RMS Power 60W x 4 @ 4 Ohm
    * RMS Power 90W x 4 @ 2 Ohm
    SUBCHANNEL:
    * RMS Power 200W x 1 @ 4 Ohm bridge
    * RMS Power 320W x 1 @ 2 Ohm bridge
    * Signal-to-noise ratio: 100 dB
    * Frequency Response: 5Hz - 50kHz
    * Total harmonic distortion: 0.05%
    * Continuously variable 0 - 18dB BASS boost
    * Built-in continuously variable 18dB per octave crossover
    * Remote bass level control “port�
    (remote RM-100 available separately)
    * Input sensitivity: 200mV - 4V
    * Backlit CONCEPT logo
    * Platinum connectors
    * Dimensions: L x W x H: 300mm x 296mm x 60mm l 11.82" x 11.66" x 2.37"
    CONCEPT HZ 124 :
    * Peak power handling: 600 Watts
    * Continuous power handling: 300 Watts
    * Impedance: DUAL COILTM4 ohm (2 X 4 ohm)
    * 2" black anodized Aluminum voice coil former with Kapton layered protection
    * 110-oz magnet structure
    * Progressive Nomex spider for maximum excursion
    * Double stamped steel frame
    * Ultra Rigid PolyPropylene cone
    * Rubber-Toughen isolated high current Tinsel lead wire
    * Silver-plated spring loaded binding posts
    * Driver Diameter: 12 Inch
    * Sensitivity: 88 dB SPL
    * Frequency Response: 30-250 Hz
    * Optimized for: Ported, Sealed, Band Pass
    * Mounting Depth: 5-7/8 Inches
    * Weight: 16 lbs
    * Marine Grade
    Harga Paket Rp. 3.500.000,-
    Tunggu !!! Lum puas ?
    Gue bonusin lagi 1 set speaker Metallic (Critical Mass) Split (midbass + Tweeter + Crossover Pasive) 6.5 inch Senilai Rp. 790.000,-
    Udah puas lum ?? Lum juga ?
    Gue tambahin lagi deh 10 meter kabel APL senilai Rp. 300.000,- (diluaran sih bisa 350-450 rebu neh kabel ;-) )
    Lagi donk !!!
    Ok deh, gue tambahin lagi 1 set (pair) rca standard 5 meter.
    Masih lum puas juga ??? Udah ah. Kasian gue donk. Masa jualan harus merugi !! :smt005
    Kondisi ? Baru bos !
    Asli gak ? Bisa dibuktikan :smt004
    Sampe kapan neh promosi berlangsung ?
    Terhitung 7 x 24 jam dari tanggal ini. Atau sampai stok habis. (siapa yang lebih dulu)
    FYI : Paket Promo Hanya disediakan beberapa set saja dari pihak sponsor.
    Promo ini akan terhapus secara otomatis setelah 7 x 24 jam atau jika stok barang sudah habis sebelum masa promosi habis
    0817756556 (back !) - 021 30863062 (damn fuckin hp) -
    ikan asin ikan tongkol
    orang miskin cuma bisa misscall
    ikan lele gede di ember
    cuma orang jelek yang pake private number
    http://www.geocities.com/bantulmerana_2006/katalog1.gif
    1 Day 20 Hrs 7 Mins 36 Secs
    ck...ck....ck.....
    Sebelah tetangga
    9 Hrs 37 Secs
    nape cak cek cak cek .. :smt017
    oh iye. setiap beli barang minimal 2 item (diluar paket), khusus di thread ini, pokoknya ada potongan harga / bonus dari harga normal selama 7 hari ini.
    Sebelah tetangga
    9 Hrs 37 Secs
    DIPILIH AJA DEH
    sisipin kalo ini masih ready stock.
    paket dibawah ini gak termasuk dalam 7 x 24 jam.
    cuma gue sisipin disini aja selama stok masih ada :
    Critical Mass (Mass Engineering) MONOBLOK 1100 watts
    Harga Rp. 900.000,-
    Concept HZ 12" Rp. 650.000,- DVC
    Capasitor Bank Concept 1.0 Farad, Rp. 300.000,-
    Ambil keduanya (Mono + Sub) hanya membayar Rp. 1.400.000,-
    Atau 3 item tersebut hanya membayar Rp. 1.650.000.-
    Sebelah tetangga
    9 Hrs 37 Secs
    CONCEPT ZT 12 INCH - Call only for serious buyer
    Quote Originally Posted by jonideep
    iye barang lu banyak banget, ga ada rencana buka cabang aja jon, di bandung gitu?
    Sebelah tetangga
    9 Hrs 37 Secs
    loe gile .. jauh jauh aje ... jakarta aja gue ngap ngapan ! kembang kempis.
    Administrator
    9 Mths 3 Days 8 Hrs 38 Mins 16 Secs
    down down down..
    eh salah.. up up up
    Sebelah tetangga
    9 Hrs 37 Secs
    kucing !!!
    Cipete, SoutH Of JakaRtA.
    1 Day 21 Hrs 37 Mins 39 Secs
    Bos Jon, minta spek Concept HZnya dunks.. bTw, Bos Jon punya toko ya? mending gw maen ksana aja deh biar enak liat2 barangnya.. kaya nya stok nya bos Jon ada byk nih
Venom 300x250 GT Radial
  1. Replies: 7
    Last Post: 2nd August 2012, 21:21
  2. Uji dengar Audio sebelum beli
    By Bdwi in forum Diskusi Head Unit & Processor
    Last Post: 17th May 2009, 22:54
