(ask) DATA JEROAN MESIN & TRANSMISI 4G63T VR-4
Results 1 to 8 of 8
  • Short URL:  http://modifika.si/81930
    4 Hrs 46 Mins 12 Secs
    Mau minta tulung kalo ada yang punya data jeroan mesin & transmisi 4G63T mitsubishi galant VR-4
    THANKIU SBLMNYA.....
    SMG
    5 Hrs 56 Mins 54 Secs
    Quote Originally Posted by fibri View Post
    Engine Specifications :
    BASIC CAR : GALANT VR4 ( COMPETITION ONLY )
    AIR INTAKE : Stainless 3" intake piping / K&N air filter
    INTAKE MANIFOLD : Buschur Racing 3" Sheet Metal Intake Manifold
    THROTTLE BODY : Accufab Racing 75mm TB
    SPARKPLUG WIRE : 8.55 Magnecore
    IGNITION AMP : Cranecams Fireball HI-6DI2
    INJECTORS :Nippodenso 720cc/min
    FUEL PUMP : SX External Fuel Pump
    FUEL FILTER : SX Slim Line Fuel Filter + SX60 Micron Stainless Filter
    FUEL REGULATOR : SX Fuel Regulator + JEG Gauge
    FUEL Re-WIRE KIT : Buschur Racing Kit
    FUEL RAIL : Venom Fuel Rail
    FUEL FITTINGS : Russel Braided Hose -6an & -8an
    FUEL MODS : Buschur Racing Fuel Tanks Sumps
    TURBOCHARGER : FORCED PERFORMANCED 550HP ( 50 Trims )
    TURBO OIL FEED : Buschur Racing S.S Turbo oil supplied feed line
    CYLINDER HEAD : FFWD Competition Level4 Cyrogenic terated
    SOLID LIFTERS : Adjustable Concepts Racing titanium lifters
    STROKER KIT : FFWD Custom 2.4liter stroker kit ( Ross/Crower ) Racing pistons 8.5 : 1
    BUTCHERED CRANCKSHAFT SPECS
    Engine mounts : Prothane
    Engine Bearings : Clevitte 77
    Intake / Exhaust Valves : Ferrea 1mm oversize S.S
    Swirl Polished Valves
    Spring Valves : Webcams dual spring valves
    Retainers : Webcams titanium
    Camshaft : HKS 264 Intake / 272 Exhaust
    Camgears : Venom Fangs
    U/Drive Pulleys : Un orthodox Racing
    Balanced shaft : Balanced shaft removal kit
    Head Gasket : HKS 1.2 mm Stopper type
    Head Studs : ARP
    Main Studs : ARP
    Conrod Studs : ARP
    Oil catch tank : Greedy
    BOV : HKS SSQV
    Intercooler : Greedy R-Specs FMIC 600mm*300mm*75mm
    Intercooler piping : Greedy
    Hose / Rubber and clamps : Fluidyne / Perma cooler
    Radiator Fans : Flex A lite Slim fans
    NOS including power shot noozle kit 50-100hp
    EXHAUST
    Exhaust manifold : Buschur Racing ported Dumb tube Kit
    Wastegate : 40 mm HKS Red
    O2Housing : Buschur racing
    Downpipe : Buschur racing + Flex
    Muffler : RPI
    SUSPENSION
    Swaybar : Whiteline Front Bar 22mm / rear Bar 20 mm
    Bushings : Energy Suspension
    Coil over Kit : Drummond 50mm Adjustable
    DRIVETRAIN
    Shift Fork : Evo3 Billet
    Shifter : Energy still
    Limited Slip diff : Quaife Front
    DIFFERENTIAL
    Gearbox : EVO3
    GearSets : Custom Double Synchros 1st-5th Gearsets
    1st -------2.571
    2nd-------1.600
    3rd-------1.160
    4th-------0.862
    5th-------0.617
    Input shafts : Evo 3
    Shift rail : Evo3
    Flywheel : JUN Aluminium
    Clutch : ACT 2600Lbs MB1 XTR
    Clutch Disc : ACT 6 Puck race cooper ceramic disc
    Flooring : Galant VR4 4WD
    TARGET : 700WHP UP..
    CUKUP GA???
    APA KEGEDEAN TUH HP NYA??
    NGA JELAS SIH KALO NANYA...
    HOHOHOHOHO
    Waduh.....gede amat.
    Sorry bos maksudnya spek standartnya aja...
    1 Wk 3 Days 13 Hrs 22 Mins 35 Secs
    galant vr-4 bukan nya 6a13tt? kalo ga salah 4g63t tu masih punya eterna zr-4, masih 4 silinder... maap ya kalo salah...
    SMG
    Quote Originally Posted by -RockeR- View Post
    weleh bos... orang dia nya nanya yg galant vr4 yg eterna...
    untuk info juga nih...
    Galant VR4 pertama tuh ya eterna tapi turbo and 4wd...
    dimaapin kok ... tenang aja
    SMG
    wah liat di internet aja bro buat spek nya
    gue attach neh tapi kalo nga keliatan ya nasib yah... hhehehe
    cukup nga sih??
    Suroboyo rek
    Speknya om Herman yah?
    SMG
    Quote Originally Posted by soluna_nyeleneh View Post
    ngawur ae... hehehhee
    specnya temen gue
    kota lumpia
Venom 300x250 MBtech
  1. cari mesin 4G63T 'halfcut'/ mesin lngkap 4wd
    By alvo89 in forum Jual Beli Mesin Lainnya
    Last Post: 6th August 2011, 19:05
  2. Replies: 1
    Last Post: 19th October 2010, 22:54
  3. Replies: 98
    Last Post: 27th July 2010, 13:55
  4. [ASK] Bikin Kenceng tanpa ubah jeroan mesin
    By RicX288 in forum Diskusi Mesin
    Last Post: 8th May 2009, 07:18
  5. mesin GTI isi dalem jeroan GSR 1.8
    By dodisutanto in forum Diskusi Mesin
    Last Post: 16th May 2008, 01:36
