Pre-amp tube
Thread: Pre-amp tube
  • Short URL:  http://modifika.si/81034
    Gading, Jakarta Utara
    1 Wk 20 Hrs 5 Mins 57 Secs
    Pre-amp tube
    Minta pencerahan pd teman2 skalian kalo dgn sistem saya saat ini kalo tambah preamp hasilnya ada improve yg signifikan gak????????? utk sementara mau pake preamp butler tube drive mr.x tubenya mullard 12ax7, kapasitor up grrade wima.
    Sistem di mobil saya saat ini:
    - Hu Sound Monitor CDT-450X and up grade sekring HI-FI Tuning hand made by Germany.
    - Speker full set Rs Audio type Pro 6''.
    - Sub Rs Audio paper 12''.
    - Kabel RCA front Acoustic Zein type WOW zero cristal.
    - Kabel RCA sub Monster Cable type 401 XLN.
    - Kabel speker and sub Acoustic Zein type CL3 12awg bi-wire.
    - Kabel power full Rs Audio 4awg silver coated.
    - Power front DLS Ultimate a3 twin mono.
    - Power sub Crossfire VR 604
    - Cap bank Helix 1Farad.
    - Stinger SPV 44.
    coba tanya donny sekalian, mobilnya kristo setau gw pake pre-amp dari home punya,di umpetin di bawah jok, tube juga. gw blom sempet dengerin perbandingannya sama pas ga pake. coba tanya dia aja sekalian, gimana pendapatnya.
    Thumbs up
    saya ud sharing banyak banget and minta pendapat ama pak cristonya langsung.......antara ganti power brax GE 2400 ma tambah preamp tube pilih mana. Ktnya mending tambah preamp menurut pendapat bapak!!! Rencana saat ini Head unit sound monitor ke preamp pake kabel rca 47 lab kan gak bth byk cm 1/2meter x 2 lalu preamp ke power pake kabel rca acoustic zein wow. sementara ada mr.x mau jual preamp-nya butler tube drive kapasitor ud diup grade wima lalu tube skrg ini pake mulard 12ax7 utk tube itu harus disesuaikan dulu dgn speker,hu ma power yg dipake jd hrs dicoba2 dulu tubenya byk ada sovtex,mulard,rca,telefunken kalo gak salah persamaan ecc 81/83 tube 12ax7.
    - Stinger SPV 44.
MBtech Mega Glodok Kemayoran
  1. Replies: 19
    Last Post: 11th July 2012, 21:48
  2. jual head unit Tabung(tube valve)+tube western electric
    By suhardy in forum Head Unit & Processor
    Last Post: 3rd November 2010, 09:29
  3. Replies: 6
    Last Post: 1st May 2010, 08:54
