Cari digital voltmeter
Results 1 to 10 of 11
  • Short URL:  http://modifika.si/7992
    7 Hrs 16 Mins 42 Secs
    Kalo cari voltmeter digital seperti di cap bank dimana ya?
    3 Hrs 59 Mins 45 Secs
    jatohnya mahal boss..mending beli capbank skalian kayaqnya....
    Makassar, Jakarta
    4 Days 17 Hrs 36 Mins 43 Secs
    beli voltmeter kaya autogauge aja
    4 Hrs 10 Mins 47 Secs
    iya tuh gw uda liat barangnya. kerenn, bisa gonta ganti lampunya lagi. ada 7 macem
    Autogauge kegedean Boss, udah gitu warnanya gonta ganti. Gw liat seperti yg di capbank itu kecil & gampang di sempilin di dashboard. Keperluannya hanya untuk monitor arus alternator mobil gw yg udah uzur.. Beli dimana ya?? Udah ubeg2 Harco tapi adanya yg untuk industri.. Whaaaak..!!
    Makassar, Jakarta
    itu merek brax.
    en harganya ngalahin sejumlah autogauge.
    biar ngirit cari yg volt meter jarum ajah...di harco glodok byk koq...
    itu nah... kapan itu udah sempet ubeg2 Harco, utk yg digital banyak tapi untuk industri.. ane seh pengennya yg digital, kecil, gampang di pasangnya..
    Jakarta 14240
    1 Hr 25 Mins 59 Secs
    Ada yang jual nich, modelnya kayak gini:
    *This meter can measure AC or DC voltages.
    *This meter can be powered by AC 20-260V, or DC 20-360V.
    *Programmable measuring range: 500V, 100V, 10V, 1V
    *Screw tighten contacts, no soldering job needed.
    *Input output ratio scalable.
    *DC voltage displayable range: -1999 to 9999.
    *AC voltage displayable range: 0 to 9999.
    *2 built-in Relays to control alarm or external devices/circuitry.
    *2 Red LED relay status indicators
    *Decimal point can be programmed to any position.
    *4 level of digital filtering avoid readout jumps up and down.
    atau yg model ini:
    Specification:
    Digits 4 1/2
    LED tube size(HxW) 9/16 x 3/8
    Range(V) -19.999 to 19.999
    Required Power (DC) 5V (+/- 10%)
    Resolution 0.001
    Decimal place Adjustable
    Dimension (LxHxD) 27/8 x 1 x 1
    Connection wires Pigtail included
    Resistors 7 included
    Digital filter function Yes
    Hold function Yes
    kalo mau tau detail, call aja...
    Yang ditunggu-tunggu..
    Mr VP udah kayak yellow pages aje neh..
    Sluuurp..
  1. Jual jam+voltmeter+termometer digital mobil
    By andiu in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 22nd February 2011, 19:33
