APEXI N1 DAMPER ESTILO
  • Short URL:  http://modifika.si/79588
    1 Wk 3 Days 6 Hrs 44 Mins 11 Secs
    DIIJUAL APEXI N1 DAMPER BEKAS ESTILO
    BARU DIPAKAI 3 BULAN ...... KEADAAN 99%.....
    Apexi N1 Damper Coilovers
    Apexi N1 Damper Systems provide awesome driver feedback and response, as well as a high level of tuning flexibility. Born from the grueling N-1 Endurance Race Series, the Apexi N-1 Dampers feature adjustable spring perches and adjustable lower collars so that ride height can be changed without affecting the length of the damper stroke. The shock absorber is a gas-charged, short-case, short-stroke, monotube design that can be fine-tuned with its 13-step ride adjustment settings. With the proper equipment and technical knowledge, the dampers can be disassembled, revalved and rebuilt to suit the requirements of hardcore suspension gurus. The Apexi N1 Damper system also includes high-performance upper pillow mounts (unless indicated otherwise) to complete this comprehensive damper system. Apexi N-1 Damper Systems use the highest quality materials and are manufactured in-house at our Fuji, Japan factory to tightly monitor quality control and ensure years of reliable service.
    RP.17.500.000
    HUB 0813.8965.0000
    JAGOAN SETTING SUSPENSI INI BOZ TAQWA.... SAMA SEPERTI YANG DIPAKAI FITRA ERI...
    KALAU SETTINGAN PAS... GAK ADA YANG BISA KALAHIN YAKIN....
    GOOOD FOR STREET RACE.... PERFECT FOR CIRCUIT RACE
  1. fs:hood damper/shock kap mesin estilo genio ferio
    By Japanese STOCKER in forum Jual Beli Mesin Lainnya
    Last Post: 23rd February 2011, 12:30
  2. wtb engine damper d-series vtec estilo
    By crossable99 in forum Jual Beli Mesin Lainnya
    Last Post: 28th November 2010, 10:24
  3. FS: APEXI N1 Damper TYPE PRO Coilover for EG6
    By TON68 in forum Per & Shockbreaker
    Last Post: 25th July 2010, 13:11
  4. Replies: 4
    Last Post: 20th September 2008, 15:35
