Ultimate Detailing Machine Car Polisher by Porter Cable
Results 1 to 10 of 38
  • Short URL:  http://modifika.si/79155
    http://www.detailermart.com
    3 Days 9 Hrs 25 Mins 56 Secs
    Kit includes:
    - Ultimate Detailing Machine Car Polisher by Porter Cable (110 volt)
    The Ultimate Detailing Machine by Porter Cable car polisher and auto buffer does more than just polish paint! It's Nothing Like an Ordinary Car Polisher!
    If you have previously owned a car polisher that made a lot of noise and vibrated your hands, but did little for your car’s finish, you will appreciate the Ultimate Detailing Machine by Porter Cable. Most consumer grade car polishers don’t have enough power, have a very small orbit (often less than 1/8 inch), and have limited accessories. The Ultimate Detailing Machine by Porter Cable shatters these limitations.
    The Ultimate Detailing Machine Car Polisher shatters the limitations of consumer grade “car polishers” and "auto buffers":
    • This car polisher has GOBS of POLISHING POWER!
    • A speed for every task!
    • Interchangeable polishing, buffing and cleaning accessories!
    Polish Swirls & Scratches Away Like Magic!
    Your time is valuable. That's why we built the Ultimate Detailing Machine with more power. The Ultimate Detailing Machine car polisher blasts through swirl marks and fine scratches better than any other consumer polisher available. An average car can be thoroughly polished in about an hour.
    How Does the Ultimate Detailing Machine Work?
    The Ultimate Detailing Machine operates by orbiting the polishing pad around a center spindle while the pad freely spins on its own axis. A counterweight on the opposite side of the center spindle dampens vibration for smooth operation.
    The tool head action, often called orbital, prevents the creation of holograms (symmetrical buffing marks), paint burns and other forms of paint damage often associated with high-speed buffing machines. When used with proper care, the Ultimate Detailing Machine’s design virtually eliminates the possibility of paint damage.
    The polishing action of the Ultimate Detailing Machine by Porter Cable closely mimics that of circular hand polishing. Imagine being able to make 2,500 to 6,000 tight hand circles in a single minute and you’ll have a pretty good idea of how the Ultimate Detailing Machine by Porter Cable does its job. It works just like your hand, only at super-human speed!
    - Sonus SwirlBuster Polish & Pad (16oz polish)
    A premium swirl remover car polish that:
    • Gently massages away swirl marks
    • Fills remaining defects with Acrylic resin
    • Protects paint for months!
    Black, red and midnight blue car owners rejoice! Finally, a car polish can gently remove swirl marks, immediately improve paint appearance, and protect the paint finish for months!
    Sonus SwirlBuster Polish is a premium swirl remover and gloss enhancing car polish specifically formulated for the needs of modern clearcoat paint.
    This polish is not a heavy compound that abrasively cuts away a significant layer of paint. Use of compounds on clearcoat is a last resort action. Compounds thin the clearcoat, reducing depth of shine.
    On first use, Sonus SwirlBuster Polish rounds over the hard edges of swirl marks and fine scratches to reduce the random light reflections. The Acrylic resins in the polish backfill the low spots to further reduce their appearance. Unlike the silicone fillers found in many polishes and hand glazes, the Acrylic resins in SwirlBuster will not easily wash away.
    After a second use, SwirlBuster polish further massages away the swirl marks and begins to increase natural surface gloss. The Acrylic resins hide even more of the remaining defects and make the paint look darker and more reflective.
    After the third use, your swirl marks are completely gone and your paint finish will look like an infinite pool of water. All the while, your paint looks great and you have not reduce clearcoat thickness or the serviceable life of your car's paint.
    Sonus SwirlBuster Polish is the only product of its kind. No other polish provides the same immediate or long term benefits to your paint:
    • Gentle removal of swirl marks with several uses... Won't thin your clearcoat!
    • Immediate appearance improvement that won't wash away!
    • Long-term paint protection!
    The Ultimate Detailing Machine DAS SwirlBuster™ Foam Polishing Pad cuts through swirl marks and oxidation like nothing you’ve ever seen yet is safe and easy to use. Use with your favorite “swirl remover” car polish on the Ultimate Detailing Machine by Porter Cable or Porter Cable 7424 car polisher to knock out unsightly swirl marks and bring your car’s paint back to its full shine potential.
    The DAS SwirlBuster polishing pad cuts like a light compounding pad, yet polishes out to a flawless finish. Depending on the cut of the polish you use, the DAS SwirlBuster pad can aggressively remove swirls and other minor imperfections or bring back the full gloss potential of your car’s paint.
    The exclusive DAS Polish Pocket™ allows you to load more polish on the pad for longer polishing without polish sling. You and your car stay clean, avoiding a lengthy cleanup after polishing.
    To remove more severe clear coat damage, including minor scratches and water spot damage, spot treat first using the DAS ScratchBuster Pad.
    Velcro Backing Plate: 4.75" to 5.75" (4.75" recommended)
    Diameter: 6"
    Thickness: 1.25"
    Polish: Use a swirl remover polish to remove swirl marks, oxidation and minor insect/bird damage.
    - Sonus SFX-1 Polish and SFX-1 Spot pad with flexplate (8oz Polish)
    Sonus SFX-1 Car Polish Removes:
    • Scratches and heavy swirl marks.
    • Heavy oxidation and paint stains.
    • Damage from brirds and water spots
    Restores damaged, oxidized and abused paint! Removes paint scratches and heavy swirl marks.
    When the appearance of your paint deteriorates from exposure or damage, you need a polish that will quickly, yet gently, remove the damaged paint to reveal a fresh, brilliant finish. This is exactly why we created Sonus Restore (SFX-1).
    Sonus SFX-1 is a cutting polish designed to remove heavy oxidation caused by exposure to the elements (sun and weather) and finish marring created by chemical fallout, hard water etching, contact scuffing, surface scratches or the ravages of poor detailing tools.
    1. Repairs surface scratches
    2. Removes heavy swirl marks and oxidation
    3. Clearcoat safe!
    Engineered to work with a dual-action polisher to safely to remove swirls and paint damage.
    A fast-action, swirl-free machine polishing pad for trouble-free repair of damaged, weathered and neglected paint. Use with Sonüs Restore (SFX-1) or other compounds and paint cleaners designed to remove 1200 grit sanding marks. Only use with a dual-action polisher or a rotary buffer in conjunction with a 5” to 6” flexible Velcro backing plate.
    WARNING: This pad feels soft but can be aggressive when used at speeds in excess of 700 RPM (rotary) or 3000 OPM (dual-action). To prevent paint burns or removing excessive paint film thickness, work at slower machine speeds. Keep machine moving and check your work often.
    - Sonus microfiber buffing bonnets and polishing towels (2each)
    The Sonus Microfiber Buffing Bonnet is the easy way to remove polish and wax residue and bring out a radiant, high-gloss finish.
    The polishing advantage of our edgeless microfiber towel is now available in the Sonus Microfiber Buffing Bonnet for your Porter Cable Polisher. Our Microfiber Buffing Bonnets can be used after polishing to remove light polish residues. These bonnets are superb for removing single-step products like Klasse All-In-One and Autoglym Super Resin Polish.
    The Microfiber Buffing Bonnet has just the right texture to apply a super thin layer of Klasse High Gloss Sealant Glaze or Autoglym Extra Gloss Protection, which require a very light coating for easy removal and best gloss. The Microfiber Buffing Bonnet fits over any 6-7 inch foam pad.
    Polish your car like a pro! The Sonus Der Wunder Polishing Towel is a microfiber fabric with a flush edge binding for scratch-free paint care. It's a premium glass towel, too!
    The most common complaint with first generation microfiber polishing cloths is the edge binding that keeps the towel from fraying and unraveling. Until now, all microfiber towels were surge bound (thread looped around the edge) or bound with a fabric edging that’s stitched to the towel. Unless the binding is made with exceptional quality, they may create micro-fine scratches. This could be very frustrating when polish to remove scratches. The solution is this new generation polishing cloth from Sonüs, the Der Wunder Polishing Towel. Look at these features:
    • Non-hemmed edge – Will not scratch!
    • No Residue Trail – Completely removes wax and polish residues
    • Polish & Wax Will Not Build-Up in the Toweling
    • Softer than cotton or fleece
    • Lint-free (great for glass cleaning!)
    • Machine washable & dryable
    • Safe for all paint finishes, including clearcoats!
    • Excellent glass cleaning towel
    • An excellent choice for interior cleaning
    I love this towel because it makes polishing and waxing so easy. The tight weave quickly cuts through dry polish and wax residue for fast, smear-free, crystal clear results. Use with the Sonus Der Wunder Applicator (made using the same material) for easy-on-easy-off hand polishing and waxing.
    The Sonus Der Wunder Polishing Towel is superb on glass. Use it with Sonus Vision glass cleaner for streak-free, crystal clear glass. If you have stubborn water spots or stains, try using Autoglym Glass Polish with a Sonus Der Wunder Polishing Towel. The results are amazing.
    Each towel comes with a 60 day unconditional guarantee. If you’re not happy with your Sonus Der Wunder Polish Towels, return them for a complete refund.
    Performance, safety and value, that’s Sonus!
    Made in Korea. 75/25 blend of Polyester/Polyamide. Package of two 16" by 16" towels.
    - Ultimate Detailing Machine 4.75" and 3.75" Velcro Backing Plates
    Sonus DAS FlexPlate increases machine buffing safety and comfort!
    The Sonüs DAS FlexPlate replaces the standard Porter Cable polishing pad allowing pads to be changed quickly and easily. The Sonus DAS FlexPlate requires only 0.15 pounds per square inch of pad pressure to begin flexing, offer better comfort (less hopping) and impoved polishing safety. With its unique 30 degree beveled edge, fully-laminated Velcro backing, and advanced polyurethane foam construction, the Sonüs DAS FlexPlate adds a new level of safety and quality. When used with 6” to 7” foam pads, the Sonüs DAS FlexPlate is perfectly balanced for use with the standard Porter Cable 7424.
    Use this 3.5 inch flexible, urethane backing plate to securely hold all 4-inch foam spot pads. This is the perfect size for spot repairs as it allows you to focus your polisher's energy on a small area. Your machine will achieve more work and you won't affect the surrounding paint.
    Works will all Porter Cable 6" dual-action polishers and sanders (e.g., PC7424).
    Use with Sonus SFX Spot Pads for paint repairs, polishing tight areas and waxing.
    Now AVAILABLE !!!!!
  2. Jayapoker
    underground
    16 Hrs 48 Mins 15 Secs
    alamak....PC!! sayang 110 volt harus pake trafo dong?
    duh...kepengen......
    brp-an bos david? PM ya?
    sukses buat detailermart..
    pm sent bro
    4 Mins 9 Secs
    Bos, klo polishernya doank bisa ndak? PM super duper nettnya yah...
    Klo cocok langsung kirim :p
    Klo ga gwe nyerah
    Thx
    keren neh boss, tp ada yang bisa ganti trafonya gak yah.....
    maksudnya ganti trafo?
    iya supaya nggak perlu pake step up lagi....
    1 Wk 2 Days 8 Hrs 49 Mins 7 Secs
    Bro David...sekarang harga DA berapa? Masih ada stock? Siapa tau ada budget....
    Pm sent bro
    50 Mins 43 Secs
    boz itu jual sepaket ya?
    btw, dollar turun ikut turun jg kaga?
    tlg pm hrgnya & klo UDM diganti rotary flex kena brp.
    Thx..
MBtech Venom 300x250
  1. PORTER-CABLE 7424XP US Ver.
    By Orlando_AD in forum Produk Perawatan Mobil
    Last Post: 26th October 2012, 20:16
  2. WTB > Dual Action Polisher merk Meguiars G110v2 ato Porter Cable 7424XP
    By Pro91 in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 12th February 2011, 12:54
  3. Fs - Mesin Poles Ultimate Detailing Machine !
    By rOeLez in forum Bursa Eksterior Lainnya
    Last Post: 30th October 2008, 00:11
