audison LRx 4.1k
Results 1 to 10 of 26
  • Short URL:  http://modifika.si/7823
    1 Hr 25 Mins 58 Secs
    audison LRx 4.1k
    Pro para master dan suhu dan juga Roy di OS.
    ini ada power baru dari audison, katanya sih baru banget dan masih sedikit yg pake. Kalo ga keberatan tolong di ulas dong.
    Nih gw kasih nomor telp importirnya RPM 021-70518008, atau kalo ada yang mau coba pake dulu terus komentar disini. thanx ya...
    Power Supply
    Power supply voltage: 11 ÷ 15 VDC
    Idling current: 1.8 A
    Idling current when off: 0.02 mA
    Consumption @ 14.4 VDC (Max Musical Power): 95 A
    Amplifier stage
    Distorsion - THD (1kHz @ 4Ω): 0.04%
    Bandwidth (-3dB): 4 ÷ 80 kHz
    S/N Ratio(A weighted @1 V): 100 dB
    Damping factor (1kHz @ 4Ω): 120
    Input sensitivity: 0.3 ÷ 5 VRMS
    Input impedance: 15kΩ
    Speaker-In sensitivity: 1.4 ÷ 24VRMS
    Speaker-In impedance: 5kΩ
    Load impedance: 4 ÷ 1 Ω
    Nominal output power (RMS)
    NP @ 12VDC, THD 0.3%: 125W x 2 + 135W x 2 (4 Ω)
    Output power (RMS) @14.4 VDC, THD 1%:
    4 Ch 130W x 2 (4Ω) + 140W x 2 (4Ω)
    4 Ch 230W x 2 (2Ω) + 250W x 2 (2Ω)
    4 Ch 130W x 2 (4Ω) + 250W x 2 (2Ω)
    4 Ch 130W x 2 (4Ω) + 400W x 2 (1Ω)
    4 Ch 200W x 2 (4Ω) + 350W x 2 (1Ω)
    3 Ch 130W x 2 (4Ω) + 500W x 1 (4Ω)
    3 Ch 130W x 2 (4Ω) + 800W x 1 (2Ω)
    3 Ch 230W x 2 (2Ω) + 500W x 1 (4Ω)
    3 Ch 200W x 2 (2Ω) + 700W x 1 (2Ω)
    Other functions
    Remote In: 7÷15 VDC - 1 mA
    Remote Out: 12 VDC - 50 mA
    Speaker On: Amp ON with amplified signal
    Fuse (AFS): 100 A
    Remote sub volume: Active with B ch. Lo-pass 24dB L+R
    Adjustment: +5 ÷ -5dB
    Filters
    Input Bypass/Hi-pass 50÷5kHz @ 12 dB/Oct.
    Output Bypass/Hi-pass/Lo-pass 50÷5kHz @ 12/24 (mono) dB/Oct.
    Subsonic OFF/20/30 Hz @ 24 dB/Oct.
    Active with B ch. @ 24 L+R
    Max size (inches): 7?13/16 x 21?3/16 x 2?1/4
    Weight: 11.9 lb
    bandung
    2 Hrs 41 Mins 35 Secs
    keren2.. btw harganya kisaran brp nih??
    harga sekitar 7-8jtan.
    Ada yang mau beli dan coba dulu supaya bisa sharing pengalaman hehehe...
    guys, ada yang uda pernah pake blom power ini? sharing dunk... penasaran nih ... thanx
    South Jakarta
    6 Days 9 Hrs 17 Mins 43 Secs
    Quote Originally Posted by igun98
    Harganya mahal juga ya...
    Ruzh
    B124BUS
    W202.01.014
    1 Wk 6 Days 15 Hrs 59 Mins 38 Secs
    tumben nich audison keluar power 4 ch, yg wattnya rada 2 gede, biasanya power audison 4 /6 chnya wattnya kecil2 semua, =p
    makanya gw penasaran banget nih, skrng lg ngincer itu, cuma supaya ga nyesel dikemudian hari mau cari info dulu sebanyak-banyaknya.
    Woooiii..... ada yang uda pake bloomm...?? cerita donk...
    beyond: nah itu dia yang bikin penasaran.
    tapi sich kayanya, warna suaranya tetep seperti audison yg dulu2, mellow2 khas audison, he3x, cuma karena wattnya agak besar, mungkin dynamicnya lebih baik, =p
    ada lagi yg mau share?? ...
  1. ******jual satu pasang Audison VR 209 sama Audison VR 404 XR **********
    By audiocarsundajaya in forum Power Amplifier
    Last Post: 8th October 2012, 18:06
  2. Replies: 64
    Last Post: 9th June 2011, 22:07
  3. Replies: 0
    Last Post: 16th February 2011, 07:41
  4. Replies: 2
    Last Post: 14th February 2011, 21:37
  5. Replies: 21
    Last Post: 24th December 2009, 23:08
