SOLD - GREDDY ULTIMATE Complete Kit
Results 1 to 10 of 24
  • Short URL:  http://modifika.si/77665
    Komplek Ruko Gading Kirana Utara Blok G 10 No. 37 Kelapa Gading Permai 021.4587.6330
    49 Mins 33 Secs
    Guys,
    Mo Jual neiy ..
    Greddy Ultimate Complete Kit dah berikut harness.
    Kalo yg mo tau bisa apa aja nih barang, please read the following:
    e-Manage Utimate
    The GReddy e-manage Ultimate is as close to a stand-alone management system as you can get while maintaining the best features of a "piggy-back" engine management; an economical price, the usage of existing sensors, the ability to easily alter factory settings and not having to tune from scratch. But unlike the original e-manage, the Ultimate is more refined, requiring specific application usage (which we are constantly adding application updates that you can download FREE via greddy.com, Tech WebPages.) The benefit of this is, the included PC-based USB "Ultimate Support Tool" allows for even finer tuning capabilities, improved flexibility in fuel & ignition control and adds impressive data-logging qualities to make tuning quicker and easier. The increased number of input and output ports of the Ultimate, along with new built-in adapters add many new options to the unit. In addition to standard e-manage airflow-based adjustments, the Ultimate version includes new and upgraded features. The Parameter Set-up, tab menu format of the Ultimate has improved direct Map control for adding and subtracting Fuel and Ignition. The ability to switch between 2 preset tuning Maps (i.e. Street or Race program) via externally mounted toggle switches. There are Maps for Individual cylinder adjustment for both Fuel and Ignition. There are also options to convert injection and ignition systems (i.e. group or sequential injection and group or individual fire ignition.) An Airflow Output Map option even allows for airflow meter elimination. And when used with a wideband A/F Meter, the Air Fuel Target Map can self-tune an Injector base tuning Map, to speed up initial tuning. There are also built-in Boost, Rev and Speed Limiter-Cut features. To create super smooth operation, there are various fine tuning Correction Maps to adjust for Throttle Acceleration, Vehicle Speed, Water Temp, Intake Temp, Auto Trans Shift, Anti Engine Stall, and Idle. To further aid in tuning, e-manage Ultimate’s improved integrated Monitoring, Map Tracing and Datalogging features far exceed any other piggyback controller on the market. Even when not connected to the software, 8 channels of datalogging (at 20msec intervals) can be recorded and stored to be reviewed later. With the Support Tool connected, over 30 channels can be covered. Other new features include: Improved RPM recognition, Warning Settings, Password Protection for individual tuning Maps, NVCS (Nissan), VTEC (Honda), O2 Feed-back, Clean Fouled Plugs, and numerous others in future updates. Ideal for optimizing and fine-tuning for performance products like Exhaust, Air Intake, Intercoolers, Boost Controllers, and Turbochargers, the e-manage Ultimate fills the gaps between conventional piggyback and expensive stand-alone engine managements. All installation and tuning should only be made by a trained technician with proper air/fuel monitoring tools. (Some or all functions may not be compatible with some applications.)
    Minat?
    Lgs tlp 0811.820.501
    AUTOFEVER
    Kompleks Ruko Gading Kirana Utara Blok G10 No. 37
    Kelapa Gading Permai - Jakarta Utara
    Phone: 021.4587.6330 - autofever.finalstage@yahoo.com
    4 Days 15 Hrs 25 Mins 20 Secs
    mw lepas brp bos?harness tuk mbl apa nih?
    49 Mins 33 Secs
    harness nya universal ..
    harga dan pertanyaan teknis, lgs telp aja ya ..
    AUTOFEVER
    1 Day 10 Hrs 48 Secs
    dilepas berapa pak? thx
    black CRV 2.0 2008 AT
    pm harganya boss..
    sekalian ama instalasi ya..thanks
    49 Mins 33 Secs
    sorry bro, pertanyaan teknis dan harga Lgs tlp 0811.820.501 ya ... thx a lot
    AUTOFEVER
    KELAPA GADING
    2 Days 11 Hrs 22 Mins 33 Secs
    heheheh nice item come on
    ORIDO AUTOPARTS
    JDM USED PARTS collector
    +6285921334419
    Pin 27AAAE5A
    49 Mins 33 Secs
    Booked dan sdh di DP ... sementara ini ..
    AUTOFEVER
    KELAPA GADING
    Quote Originally Posted by autofever View Post
    wow mantaff ko mike....
    ORIDO AUTOPARTS
    +6285921334419
    Pin 27AAAE5A
    KOTA LUMPIA
    1 Hr 7 Mins 35 Secs
    sik asyik, tar lagi punya greedy e manage ultimate nih, thank bos mike dan bos bernard
MBtech Venom 300x250
  1. WTS: Greddy Ultimate
    By ed7 in forum Jual Beli Mesin Lainnya
    Last Post: 7th March 2012, 14:09
  2. Replies: 11
    Last Post: 7th June 2010, 01:09
  3. Replies: 70
    Last Post: 29th March 2010, 16:07
  4. WTS. Greddy e-manage Ultimate (SOLD)
    By jerbond150 in forum Jual Beli Mesin Lainnya
    Last Post: 13th November 2009, 00:06
  5. WTS GREDDY ULTIMATE (SOLD THX 2 MODCOM)
    By mike_777 in forum Jual Beli Mesin Lainnya
    Last Post: 29th April 2009, 00:23
