TIPS and Benefits Using Optimum Products
Results 1 to 10 of 14
  • Short URL:  http://modifika.si/76149
    http://www.detailermart.com
    3 Days 9 Hrs 25 Mins 56 Secs
    Quote from talex26 from Optimumforums.org:
    As derdave said ONR mixed as a detailer is for everyday use. That is how I use it and as such by living in SoCal I only actually have to wash my car once every 6 weeks at the most. 10-15 minutes a day and my car always looks like it was just waxed because of the three coats of opti-seal I initially applied.
    As for OID think of it as comparable to any high end instant detailer. OID is more about adding shine and slickness than removing dust. I never use it as a dust remover. I always apply it to a clean surface after washing or after ONR detailing because I gently rub it into the paint. If the car was dusty and I rubbed it into the paint I feel I would create some swirling over time. Maybe I'm just being overly cautious but caution eliminates swirls which eliminates a lot of extra work.
    Two little tricks that others including myself use is to, one, add a little OID to your ONR detail mixture for personal use (or for a final wipe down of a low end detail job). That really keeps your car shiny and slick on a daily basis. I find that daily use of pure OID eventually starts to streak due to buildup, but adding a little to the ONR works out nicely. Add 10 or 15% to the ONR detail mixture and see how it works for you.
    The other trick is to add some ONR to the OID. Some people have a problem with the 3 to 1 mixture streaking. I find that adding a little ONR detail mixture to the OID works out better than diluting OID to a 3.5 or 4 to 1 mixture as some suggest to combat streaking. So try the 3 to 1 and if you get streaking add 5 or 10% of ONR detail mixture and see what you think.
    here is also:
    I add about 10% or so of ONR to the standard OID water portion of the mixture. So in a 32 oz bottle I would mix 24 oz of distilled water and 8 oz of OID concentrate - and then add a little less than 2 ONR cap fulls ( .8 oz) of ONR. That works good for me here in California.
    I will add that weather may play a roll in what works. For instance humidity makes a big difference as either product - ONR by itself or the OID water/concentrate mixture are harder to wipe off than in non-humid conditions. As you know things just don't dry or wipe off as easily or quickly in humidity. Now OID being a heavier viscosity is harder to wipe off, or as I call it, rub into the paint. So when it is humid I end up adding more than 10% of ONR to the OID mixture so I don't have to spend a lot of extra time rubbing it in. You have to experiment to see what works for you in your area. Just add an additional half cap full at a time to a 32 oz bottle until you find something that works for you
    Some guys just add more water - like going 4 to 1 instead of the recommended 3 to 1. I like the ONR because it doesn't thin out the OID to the point of it 'running' when applied like more water does, plus the ONR is synergistic with the OID and I actually think it enhances the OID shine and that the product spreads out on the paint more evenly - thus less streaking. I mix in 10% even in neutral weather conditions and add more when it is humid.
    Have fun with it. It's a great product - - and very affordable. Smells good too, not that smell means anything when it comes to looks, but if you are detailing all day and have a choice or using 'chemical' smelling products or clean and nice smelling ones then the choice is easy all other things considered.
    Bandung Paris Van Java
    izin save yah....
    jgn lupa versi indonesianya yah :smt023
    Click Here..DETAILER GIRL
    depan komputer
    Haduh... basanya basa jerman.. nda ngerti sayah...
    2 Days 3 Hrs 1 Min
    bahase indonesianya please,berat nyernanya nih bos
    Unknown
    5 Days 4 Hrs 39 Mins 17 Secs
    translate please hehehehe
    35 Secs
    tranlate ancur
    Kutipan dari talex26 dari Optimumforums.org:
    Sebagai derdave berkata dicampur ONR sebagai detailer adalah untuk digunakan sehari-hari. Itu adalah bagaimana saya dan menggunakannya sebagai tersebut dengan tinggal di SoCal sebenarnya saya hanya perlu cuci mobil saya setiap 6 minggu sekali, paling banyak. 10-15 menit sehari dan mobil saya selalu terlihat seperti itu hanya karena wax dari tiga coats dari opti-cap saya pada awalnya diterapkan.
    Seperti berpikir untuk OID tersebut sebagai sebanding dengan yang tinggi akhir detailer instan. OID adalah lebih lanjut tentang penambahan bersinar dan mengeluarkan slickness dari debu. Saya tidak pernah menggunakannya sebagai debu kotor. Saya selalu berlaku ke permukaan setelah cuci bersih atau setelah ONR memperincikan karena saya perlahan menggosok sampai ke dalam cat. Jika mobil saya adalah berdebu dan digosok ke dalam cat saya merasa saya akan membuat beberapa tebaran dari waktu ke waktu. Mungkin saya hanya menjadi terlalu berhati-hati tetapi hati-hati menghilangkan swirls yang menghilangkan banyak bekerja ekstra.
    Dua sedikit trik yang lain termasuk saya sendiri adalah untuk menggunakan, satu, tambahkan sedikit OID untuk Anda ONR detail campuran untuk penggunaan pribadi (atau untuk akhir menyapu bawah yang rendah akhir detail pekerjaan). Anda yang benar-benar menyimpan mobil mengkilat dan licin dalam hitungan hari. Saya menemukan bahwa penggunaan harian murni OID akhirnya mulai coret karena banget, tapi menambahkan sedikit ke ONR berhasil baik. Menambahkan 10 atau 15% ke campuran ONR detail dan melihat bagaimana ini bekerja untuk Anda.
    Trik yang lain adalah dengan menambahkan beberapa ONR ke OID. Beberapa orang memiliki masalah dengan 3-1 campuran streaking. Saya menemukan bahwa menambahkan sedikit ONR detail campuran ke OID berhasil lebih baik dari Diencerkan OID untuk 3,5 atau 4-1 sebagai campuran beberapa menyarankan untuk memerangi streaking. Jadi coba 3-1 dan jika Anda mendapatkan streaking menambahkan 5 atau 10% dari ONR detail campuran dan melihat apa pendapat Anda.
    35 Secs
    di sini juga:
    Saya menambahkan atau sekitar 10% dari ONR jadi standar untuk OID air dari campuran. Jadi dalam 32 ons botol Tolong gabungan dari 24 ons distilled air dan 8 ons dari OID berkonsentrasi - dan kemudian menambahkan sedikit kurang dari 2 ONR tutup fulls (,8 ons) dari ONR. Yang baik untuk saya bekerja di sini di California.
    Saya akan menambahkan bahwa cuaca Mei memutar datang beramai-ramai yang berhasil. Misalnya kelembaban membuat perbedaan yang sangat besar sebagai salah satu produk - ONR dengan sendirinya atau OID air / konsentrat campuran yang sulit untuk memukul mati daripada di non-kondisi lembab. Seperti yang Anda tahu hal-hal tidak kering atau menyapu aktif dengan mudah atau dengan cepat dalam kelembaban. Sekarang OID menjadi berat kelekatan lebih sulit untuk memukul off, atau sebagai panggilan saya itu, menggosok sampai ke dalam cat. Jadi bila saya lembab sampai akhir menambahkan lebih dari 10% dari ONR ke OID campuran sehingga saya tidak perlu menghabiskan banyak waktu tambahan senggolan itu Anda harus teliti percobaan untuk melihat apa yang bekerja untuk anda di wilayah Anda. Hanya menambah setengah tutup penuh sekaligus untuk sebuah botol 32 ons sampai Anda menemukan sesuatu yang bekerja untuk Anda
    Beberapa guys hanya menambahkan air - seperti pergi 4-1, bukan yang dianjurkan 3-1. Saya suka ONR karena tidak berkurang dengan OID ke jalur itu 'berjalan' ketika diterapkan seperti air tidak lebih, ditambah ONR adalah sinergis dengan OID dan saya benar-benar berpikir meningkatkan OID bersinar dan produk yang menyebar keluar pada cat lebih merata - streaking sehingga lebih sedikit. Saya campur dalam 10% bahkan dalam kondisi cuaca netral dan menambahkan lebih bila lembab.
    Bersenang-senang dengannya. It's a besar produk - - dan sangat terjangkau. Terlalu baik bau, bau yang tidak berarti apa-apa ketika datang untuk melihat, namun jika anda semua detail hari dan memiliki pilihan atau menggunakan 'kimia' berbau produk atau berbau bersih dan bagus maka pilihan yang mudah adalah semua hal-hal lain yang dianggap.
    depan komputer
    haduh.... pusing..
    google translate ya mas..
    BENEFITS using ONR: (especially during this Rainy Season)
    - Menghemat waktu, dengan feature tanpa bilasnya, maka waktu yang dipakai untuk membilas (10-15menit) tidak perlu terbuang..
    - Menghemat Penggunaan Air. Dengan penggunaan 2bucket method system, air yang dipakai hanya kurang lebih 8liter...
    - Aman untuk Lingkungan...
    - menetralisir kandungan mineral dalam air sehingga aman bagi permukaan cat dan kaca
    - Bisa digunakan untuk membersihkan interior dan kaca..
    - Dengan dillution ratio ONR : Aquadest (distilled Water) = 1 : 64 bisa digunakan sebagai clay lube, jadi dengan 1 botol ONR 32oz anda bisa membuat 64 liter clay lube :smt005
    - Dengan dillution ratio ONR : Aquadest (distilled Water) = 6oz : 128oz bisa digunakan sebagai Quick Detailer.. bayangkan 1 Botol ONR 32oz bisa jadi 20 botol quick detailer (approximately)
NGK Busi
  1. WTS : Products Ex Display and Used Products
    By CARTENS in forum Power Amplifier
    Last Post: 21st February 2011, 13:48
