Introducing Abyss A-7 Headunit
Results 1 to 10 of 36
  • Short URL:  http://modifika.si/7467
    Jakarta, Indonesia
    Abyss A-7 Headunit --> RRP Rp 35,000,000.00
    The first and the only SACD headunit in the market
    24bit/96kHz DAC System
    power supply: DC 12V (11~16V), test voltage 14.4V, (-)negative ground, Less than: 2.0A
    Bass: ± 12db(100Hz). Mid : ± 9dB(1kHz), Treble : ± 12dB (10kHz)
    pre-amp output voltage : 5V (CD mode 1kHz, OdB)
    pre-amp output impedance: 1KΩ
    W X H X D: 178X50X155(mm), Weight: 1.4kg
    FM stereo radio
    Frepuency range: 87.50~108.00MHz , Usable sensitivity: 11.0dBf (1.25μV,75Ω)
    50dB Usable sensitivity : 15.2dBf(1.6μV,75Ω)
    : 30Hz~15kHz (± 3dB), Altrnate channel , Selectivity :75dB
    Stereo separation : 35dB(1kHz), Image response, Ratio: 75dB, IF response ratio : 100dB
    Signal to noise ratio :60dB
    AM Radid
    Frepuency range : 522~ 1629 kHz, Usable sensitivity: 26dB
    CD PLAY
    Sampling frequncy: 8times oversampling, D-A Converter: 24bit/96kHz DAC system
    Pick-up type: Astigma 3-beam, Light Source: Semicondutor laser
    Wave Length: 780mm, Frepuency range: 20Hz~20kHz (± 1kHz), S/N RATIO: 96dB
    THD: 0.01%(1KHz), WOW & FLUTTER: Below measurable limits, Channel Separation: 75dB
    ... BEYOND THE HIGH END ...
    31 Mins 1 Sec
    pengen tp iiiihhhh....serem bos harganya.... :smt017
    Jakarta, Indonesia
    The price is a little bit pricy... however it worths every single penny that you spent... you will never listen to any headunits as analogue as Abyss A-7... In addition, this baby is the first SACD headunit available in the market...
    Batavija
    9 Hrs 14 Mins 30 Secs
    Quote Originally Posted by abyss_international
    boleh minta tolong di jelaskan SACD headunit ini maksudnya apa...
    Thnx alot abyss international :smt001
    apa bedanya sama dct1/mcintosh/hu analog lainnya ?
    Jakarta, Indonesia
    dexza:
    Kan ada beberapa macem CD... ada yang CD biasa, ada yang HDCD, XRCD dan SACD... SACD membutuhkah player khusus yang bisa ngejalanin SACD... dan hasil suara yang dihasilkan lebih baik dibandingkan dengan format format lainnya
    Jakarta, Indonesia
    mr_speak:
    Saya gak pernah pake McIntosh jadinya gak bisa comment untuk barang tersebut... tetapi personally saya ada Denon DCT1 terpasang dimobil saya... DCT1 masih tergolong agak digital karena controll bass dan treblenya pun masih digital... kalo A-7 controll bass, treble etc etc ada controller sendiri... hasil quality suaranya pun sudah saya coba bandingkan dan memang suaranya analogue banget...
    DCT1 belom ada D/A Converter... tetapi A-7 sudah build in D/A Converter... kalo mau bilang harga A-7 mahal sih bisa tergolong FAIR PRICE... karena kalo kita bandingkan dengan DCT1, harga retailnya berkisar di 21jt... dan kalo beli D/A Converter yang bagus sudah sektiar 10jt... at the end harganya juga gak beda beda jauh... A-7 sudah dilengkapi dengan fungsi SACD tetapi DCT-1 tidak ada...
    Kalo kita liat value for money, A-7 lebih value for money dibandingkan dengan yang lainnya...
    Itu semua analisa saya, kalo ada yang keberatan saya mohon maaf...
    boss abyss int, hu ini ada control EQ n time allignment ga? atau masih perlu controller terpisah?
    HX-D2
    3 Way MPs + Excel
    Aliante 12"
    Powered by Valve SQ Refs
    CEC Belt Drive
    CEC 5300
    Vienna Hydan Grand
    Jakarta, Indonesia
    ming2st:
    Kalo udah pake embel embel EQ, TA, X-O udah gak jadi analogue lagi donk... headunit bener bener FLAT... kalo mau pake processor saya recommend pake BSS atau DBX untuk hasil yang lebih maximal... kalo mau adu quality dengan F#1 saya berani adu... tapi beli processornya agak engap juga... rangenya diantara 15jt-20jt untuk processor... processor tersebut dipakai di professional recording company atau home audio...
    kalo mau yang lebih murah pake Behringer...
    Batavija
    dexza:
    oh gitu, kirain ada penemuan baru yg mungkin beda bgt
    anywei yhnx bgt untuk penjelasanya
    :smt003
  1. FS: Headunit OEM s2000 JDM Asli + Headunit Pioneer
    By mobilcepet in forum Head Unit & Processor
    Last Post: 21st June 2011, 11:28
  2. For sale ABYSS MINI AA 4ch & ABYSS 1.5k Monoblok
    By Morenahama_autoparts in forum Power Amplifier
    Last Post: 12th May 2011, 12:39
