All about polishing machine (orbital, dual action, rotary etc)
Page 1 of 16 12345 ... LastLast
Results 1 to 10 of 152
  • Short URL:  http://modifika.si/64700
    Cawang
    2 Mins 28 Secs
    Buat temen2 yang mao ngomongin mesin-mesin coba didiskusikan disini ya... Thanks
    Nirwana
    ask
    kl buat nubie recommendnya pake mesin yg gimana boz thanks....
    Cawang
    2 Mins 28 Secs
    mesin dual action. contohnya PC 7424 atau yang uda tersedia di meguiars g 220
    ɐʇɹɐʞɐɾ
    12 Hrs 9 Mins 19 Secs
    mesin orbital buat poless wax gimana
    15 Hrs 45 Mins 1 Sec
    Selama ini sih cuma pake orbital yang beli di ace...Bener2 gak ngebantu tuh...Bikin tangan cepet pegel & kesemutan...
    34 Mins 20 Secs
    rotary dewalt bueeerrrraaaaaattttt! hehe..
    dewalt sih boleh berat... powernya dong...
    belum lagi tekanan beratnya itu buat ngilangin scratch. mantap...
    -Way KampanG-
    1 Hr 21 Mins 46 Secs
    pusing sayah banyak bener rotary yg bagus,tp yg cocok di hati sama dompet blm nemu:confused:
    ya udah, ini deh dibantuin, biar liatnya gak pusing dan bisa langsung bandingin...
    The Porter Cable 7424 Orbital Polisher is simply a wonderful machine. It doesn't matter if you're a first time user or a skilled enthusiast, this machine will give you professional-looking results the very first time you use it. The 7424 Polisher is easy to use and safe for all fiberglass, metal, paint and clear coat finishes. It will not create swirls and can not harm or remove paint or clear coats. It will allow you to apply a polish and liquid wax or sealant in a fraction of the time it would take by hand and create an unbelievable shine. We offer the Porter Cable 7424 Basic Polisher which is the stock machine as it comes from the factory and the 7424 Ultimate Detailing Machine which includes a backing plate and a professional foam pad. If you want a complete kit with everything look at our 7424 Ultimate Detail Machine & Pad Kit for detailing automobiles and our 7424 RV/Marine Kit for detailing boats and RV's.
    Meguiars G-110 / G-220 Dual Action Polisher is the result of a project that started two years ago with a clean sheet of paper. The G-110 weighs in at 5.5 lbs, comes with a 5 inch Hook-and-Loop Backing Plate and has a 4.2 amp motor. It has a speed range of 2560 to 6700 OPM (oscillations per minute). Meguiars G-110 comes with one of the best bail-style handles in the industry. This handle can be locked in a number of positions allowing the operator to always have the optimum front-and-back grip for any polishing task. Like the Porter Cable 7424, the G-110 is an orbital machine that will not create swirls or remove paint.
    The Flex XC3401VRG is a true dual-action machine. With this polisher, the pads do have a forced circular motion, they rotate or "cut". Plus, as the pads rotate, they oscillate, or move, in a random pattern. Hence the name, dual action. This machine has a very solid "feel", like it could operate all day without stopping (which it probably does in some plants). It never feels strained or "near the edge". I feel it will do 90% of what a pure circular polisher can do with the safety of the random oscillations to prevent swirls. A case of having your cake and eating it too!
    The Makita BO6040 Two Mode Polisher has an orange knob on the left side of the machine which switches it from a random orbital motion to a circular motion! When switched to the circular mode, the pad is still oscillating in a random pattern. In other words, while it's in a forced, circular cutting motion, the pad is still "jiggling". This gives an added measure of safety against putting swirls in the finish when compounding in the circular mode. This is a safe dual-action polisher making it great for enthusiasts with limited machine experience.
    If you're old enough to have a little gray in your hair, you may recognize this as the old Black & Decker Model 6138, one of the finest polishers ever made. When Black & Decker put their premium grade products under the DeWalt name, the 6138 became the DeWalt DW849. Seasoned professionals swear the DW849 is simply the finest polisher ever built. "Bullet-proof," "Indestructible" and "runs forever" are often heard descriptions when talking to DW849 owners. A ball-bearing motor assembly and heat-tempered, precision-cut gears gives the DeWalt a feel of solid, controlled power.
    The Makita 9227 offers an electronic speed control (0-3000 rpm) that maintains a constant speed under varying load conditions. This means you can add a little pressure while working out a paint blemish without having the polisher stall or slow down. The large 10 amp. motor works effortlessly for high speed polishing and slow speed wax/protectant application yet the entire unit weighs only 6.6 lbs. A large wrap around handle provides excellent two-hand control for working over edges or into tight corners. This is a serious, high-speed, rotary polisher for the skilled enthusiast or professional detailer.
    This is a sweetheart of a machine combining the best features of the DeWalt 849 and Makita 9227. It offers the heavy duty construction of the DeWalt with the powerful 10 amp. motor and front, bail handle of the Makita. The German Flex LK603VVB circular polisher is one tough machine. Flex, if you're not familiar with the name, is a world leader in polishing machine technology being the innovator of the variable speed trigger. The LK603VVB, for all its ruggedness, weighs in at 8 lbs. making it comfortable for long term use. The front, loop handle (called a bail handle) is preferred by most operators and can be offset on either the right or left side to accommodate left handed users.
    We found this Vector Professional Circular Polisher at the NACE show, the trade organization for the collision, paint and body shop industry. This is one sweetheart of a polisher. It is made in China but has a German-like feel of quality and craftsmanship. The molded housing is very comfortable to grip and the oversize trigger features a "soft start" which builds speed gradually to the speed limit set on the speed control. This greatly reduces turn-on splatter. The Vector weighs in at a manageable 7 lbs and is the quietest polisher I have ever used. I can be polishing away and still hear my workbench radio!
    A number of our customers have compressed air in their garage or business and have asked for a pneumatic, random orbital polisher. The polisher we like the best is the XLB-6 Buffer from National Detroit. Made in the USA , the XLB Buffer uses heavy duty, oversize bearings in a motor assembly made of steel and aluminum. It has nearly 1/2 inch of orbit for aggressive, high speed polishing. (By comparison, the Porter Cable 7424 has an orbit of only 3/32 inch.) The XLB can remove swirls, spots and scratches that would normally require a circular polisher yet still offers a swirl-free, random orbital motion. This is the most aggressive random orbital polisher on the market yet it is surprisingly smooth. It's the ideal polishing tool for professional detailing shops where speed and volume work is required.
    Nah ini gw post biar tambah bingung buat yang lagi bingung. biar mantap bagi yang masih nimbang-nimbang dan monggo dibeli bagi yang belum punya mesin.
    oh iya di Indo ada juga mesin ini:
    Master Mike's
    Hitachi SP18VA
    Master Andi's
    Black & Decker WP1300K
    :smt030:smt030:smt030
Tekiro Mega Glodok Kemayoran
  1. [ASK] Perbedaan Orbital, Dual Action dan Rotary Polisher
    By devilshouse81 in forum Diskusi Perawatan Mobil (Exterior & Interior)
    Last Post: 24th December 2014, 22:16
