SPEED'Z PERFORMANCE Authroized for supply AP RACING world leader stock in huge quantity for stockiest so make the Stock in very good price.
We always develop for the update AP Racing stock start from 15 inch wheels to 22 inch using World-Radical and for Brembo Grand Turismo start from wheels 17inch to 21 inch.
We supply for INDONESIA Exclusive market, and many installation in customer car & dealer wanted for area not in Jakarta.
Please come and see Stock and many application before buy and all is in stock.
AP RACING MADE IN UNITED KINGDOM
(NEW!!)-----RACE CALIPER PRO5000+ R-----(NEW !!)
-CP9444 race caliper 4 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose,Center hub and bolt+adaptor
**dengan discbrake 280mm(min velg 15 inch) harga 32 jt.
** dengan discbrake 295mm(min velg 16 inch) harga 34 jt.
-CP9440 race caliper 4 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose,Center hub and bolt+adaptor
**dengan discbrake 330mm(min velg 17 inch) harga 38 jt.
-CP9660 race caliper 6 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose ,Center hub and bolt +adaptor
**dengan discbrake 355mm (velg min 18 inch) harga 47 jt .
**dengan discbrake 362mm (velg min 19 inch) harga 48 jt .
**dengan dicsbrake 370mm (velg min 19 inch) harga 49 jt.
**dengan discbrake 380mm (velg min 19-20 inch) harga 50 jt.
-CP9665 race caliper 6 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose ,Center hub and bolt +adaptor
**dengan discbrake 362mm (velg min 19 inch) harga 49 jt .
**dengan dicsbrake 370mm (velg min 19 inch) harga 50 jt.
**dengan discbrake 380mm (velg min 19-20 inch) harga 51 jt.
**dengan discbrake 390mm (velg min 20 inch) harga 52 jt.
UPDATE PRICE BIG BRAKE KIT AP RACING JUNE 2017
-CP7600 caliper 4 pot ,AP disbrake floating slotted ,AP brake pad APF 404, Brake hose,Center hub and bolt+adaptor.
**dengan discbrake 285mm(min velg 15 inch) harga 24 jt .
**dengan discbrake 295mm(min velg 16 inch) harga 25.5 jt.
-CP 5200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, Brake hose ,Center hub and bolt+adaptor.
**dengan discbrake 330mm(min 17 inch) harga 28 jt.
-CP 9200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, Brake hose ,Center hub and bolt+adaptor.
**dengan discbrake 330mm(min 17 inch) harga 30 jt.
-CP5040 race caliper 4 pot pro5000+, AP discbrake floating slotted, AP brake pad APF 402, Brake hose ,Center hub and bolt+adaptor.
**dengan discbrake 330mm(min velg 17 inch) harga 36 jt.
-CP9040 caliper 6 pot , AP disbrake floating slotted , AP brake pad APF 404, Brake hose ,Center hub and bolt+adaptor.
**dengan discbrake 355mm(min velg 18 inch) harga 36 jt.
**dengan discbrake 362mm(min velg 18-19 inch) harga 37.5 jt.
-CP5060 race caliper 6 pot pro5000+, AP disbrake floating slotted , AP brake pad APF 402, Brake hose ,Center hub and bolt+adaptor.
**dengan discbrake 355mm (velg min 18 inch) harga 45 jt.
**dengan discbrake 362mm (velg min 18-19 inch)harga 46.5 jt.
NEW and ready stock AP RACING World RADI-CAL Caliper new design futuristic and with new model Floating J-Hook design .
-CP 8520 Radi-Cal caliper 6 pot,AP floating J-hook , AP brake pad APF 404, Brake hose,Center hub and bolt+adaptor.
** AP discbrake floating Curved Groove 370mm (velg min 18 inch) harga 45 jt.
**dengan discbrake floating J-hook 370mm (velg min 18 inch) harga 45 jt .
**dengan discbrake floating J-hook 380mm (velg min 19 inch) harga 46 jt.
**dengan discbrake floating J-hook 390mm (velg min 20 inch) harga 47 jt.
**dengan discbrake floating J-Hook 410mm (velg min 21 inch)
harga 49 jt.
-CP8530 Radi-Cal caliper 4 pot,AP discbrake floating slotted ,AP brake pad APF404, Brake hose ,Center Hub and bolt+adaptor.
**dengan discbrake Floating J-hook 360 mm(velg minimal 18 inch)harga 38 jt.
**dengan discbrake floating J-hook 380 mm(velg minimal 19 inch) harga 40 jt.
**dengan discbrake floating J-Hook 400mm(velg minimal 20 inch) harga 42 jt.
Brembo Grand Turismo Made In ITALY
-Brembo GT 4 pot,brembo brake pad, alumunium brake hose with center bell plug n play alumunium and adaptor.
*Dengan floating drilled discbrake 355mm harga 40 Jt.(velg minimal 18 inch)
*Dengan floating drilled discbrake 380mm harga 42 Jt.(velg minimal 19 inch).
-BREMBO GT 6 pot,brembo brake pad ,Brake hose with center bell plug n play alumunium dan adaptor.
**Dengan Discbarake Floating Drillet 380mm(Buat Velg Minimal 19 INCH ) Harga 50 Jt.
New and just coming in stock
-BREMBO GT 8 pot,brembo brake pad ,Brake hose with center bell plug n play alumunium dan adaptor.
**Dengan Discbarake Floating Drillet 380 MM(Buat Velg Minimal 20 inch ) Harga 50 Jt.
**Dengan Discbrake Floating Drilled 405Mm(Buat Velg Minimal 21-22 Inch) Harga 52 Jt.
Dapetkan potongan setiap pembelian Big Brake Kit depan + belakang extra 3 jt (extra pemotongan for customer)
SPEED'Z PERFORMANCE
Green Lake City Ruko CBD Blok L No: 7
Cipondoh-Tangerang 11750
Mobile no/Whatsapp : 081382077777 (Hanz SpeedZ)
www.speedzperformance.com
Instagram : speedz77777
Twitter: speedz77777
