P SIX DSP MK2 HELIX
Results 1 to 10 of 10
  • Short URL:  http://modifika.si/643149
    Ajibarang
    1 Mth 1 Wk 4 Days 2 Hrs 22 Mins 47 Secs
    P SIX DSP MK2 HELIX
    misi suhu2,...
    ada yg udah pernah pake P SIX DSP MK2 HELIX ?
    bagaimana kualitas dan lain lain nya ?
    http://www.audiotec-fischer.de/lng/en/p-six-dsp-mk2.html
    terima kasih suhu...
    pemula
    Kelapa Gading
    1 Wk 3 Days 14 Mins 50 Secs
    ikut nimbrung.. procesor dengan power 120 watt per channel..
    Alpine W520E, audison bit ten, 3 way vox amt, mosconi as100.4, jl audio 1000.1, sub impulse, vermouth black curse, Art Nouvau Signature RCA
    Semarang - Medan PP
    2 Wks 12 Hrs 50 Mins 37 Secs
    dapat honda ..........honda beat
    Ajibarang
    Sepertinya jarang yang pake yahh...
    Hahahah....
    Gosipnya proc Helix nya bagus, tapi ga tau kalo yg digabung ama power
    pemula
    2 Wks 5 Days 19 Hrs 10 Mins 58 Secs
    Buat angkat apa an ni speakernya?
    Ajibarang
    New “Ultra HD Class D” concept which combines the high-end sound quality of class AB technology with the benefits of class D amplifiers
    Full audio bandwidth up to more than 40 kHz thanks to 96 kHz sampling rate
    Cutting-edge, extremely powerful “fixed point” Audio DSP with 64 Bit resolution and 1.2 billion MAC operations per second
    24 Volts compatible without the need to make any changes to the unit
    Six speaker outputs with up to 230 Watts RMS into 2 Ohms
    Two processed RCA outputs
    Inputs: 6 x RCA, 6 x Highlevel with up to 20V RMS input sensitivity, optical SPDIF input
    Smart highlevel input with ADEP circuit
    HELIX Extension Card slot (HEC) for additional input / output modules like Bluetooth® Audio Streaming
    Compact design with low heat dissipation thanks to *extraordinary efficiency
    Automatic Remote switch
    Special features:
    Ultra HD Class D amplifier technology with 96 kHz sampling rate
    The HELIX P SIX DSP MK2 is the first Class D amplifier with integrated DSP on the market that runs at 96 kHz sampling rate. Therefore the audio bandwidth is no longer limited to 22 kHz, but allows an extended frequency response to more than 40 kHz. The higher sampling rate has only been possible by implementing the latest DSP and amplifier chip sets.
    The result: a Class D-amplifier with an unprecedented sound quality.
    Ready for 24 V
    It is possible to operate the P SIX DSP MK2 with a supply voltage of 12 Volts or 24 Volts (e.g. as usual in trucks) without the need to make any changes to the unit. In both operating modes the amplifier will have equal performance characteristics. This guarantees maximum flexibility for numerous applications.
    The latest generation of OE car radios incorporates sophisticated possibilities of diagnosing the connected speakers. If an usual amplifier will be hooked up failure messages and loss of specific features (e.g. fader function) are often the result - but not with the P SIX DSP MK2.
    The new ADEP circuit (Advanced Diagnostics Error Protection) avoids all these problems without loading the speaker outputs of the OE radio during high volumes unnecessarily.
    Power Save Mode
    The Power Save Mode is incorporated in the basic setup. It allows to significantly reduce the power consumption of the P SIX DSP MK2 and connected amplifiers once there’s no input signal present for more than 60 seconds. Please note that in many up-to-date cars with “CAN” or any other internal bus structures it may happen that the radio remains “invisibly” turned on for up to 45 min. even after leaving the car! Once the “Power Save Mode“ is active the remote output (Rem Out) and the internal amplifier stages will be turned off. The HELIX P SIX DSP MK2 will reactivate the remote output and the internal amplifier stages within a second if a music signal is applied. It is possible to either modify the turn-off time of 60 sec. or completely deactivate the “Power Save Mode” via the DSP PC-Tool software.
    Start-Stop capability
    The switched power supply of the HELIX P SIX DSP MK2 assures a constant internal supply voltage even if the battery’s voltage drops to 6 Volts during engine crank.
    Automatic Digital Signal Detection
    Switching from analog input to the digital input is done automatically as soon as a signal is detected on the Optical Input. This feature can be deactivated in the DSP PC-Tool software. Alternatively you can use an optional remote control for manual switching between analog and digital inputs.
    RMS power
    - Channel A - F @ 4 Ohms 120 Watts per channel (≤ 1% THD+N)
    - Channel C - F @ 2 Ohms 230 Watts per channel (≤ 1% THD+N)
    Inputs 6 x RCA / Cinch
    6 x Highlevel speaker input
    1 x Optical SPDIF (12 - 96 kHz)
    1 x Remote In
    Input sensitivity RCA / Cinch 2 - 4 Volts or 4 - 8 Volts
    Highlevel 5 - 10 Volts or 10 - 20 Volts
    Outputs 6 x Speaker
    2 x RCA / Cinch
    2 x Remote Out
    Output voltage RCA 3 Volts RMS
    Frequency response 20 Hz - 44,000 Hz
    DSP resolution 64 Bit
    DSP power 295 MHz (1.2 billion MAC operations per second)
    Sampling rate 96 kHz
    Signal converters A/D: BurrBrown
    D/A: BurrBrown
    Signal-to-noise ratio (A-weighted) 105 dB (digital input)
    100 dB (analog input)
    Distortion (THD) < 0.008 %
    Damping factor > 100
    Input impedance RCA / Cinch 64 kOhms
    Input impedance highlevel 13 Ohms or 64 kOhms
    Operating voltage 10.5 - 32 Volts (max. 5 sec. down to 6 Volts)
    Additional features Control Input, USB, HEC slot, Automatic Remote switch
    pemula
    Ajibarang
    Quote Originally Posted by Sq77 View Post
    prosesor built in power
    bisa buat angkat speaker 6 buah
    6 x 120 watt 4ohm
    pemula
    Bekasi-Cikarang
    3 Mths 1 Wk 19 Hrs 15 Mins 36 Secs
    nubie pernah seting utak atik pny tmn buat angkat satori 2way dikasi hu 9016,ok suaranya.........clean galak khas jerman
    sony xb100bt-zapco z150.2-custom passive diy-satori 2way-sb29swnrx-rca diy-sr tesla quad-flux 4awg-acrolink 4040f
    Tes Denger Klik Disini
    1 Day 22 Hrs 20 Mins 43 Secs
    Suhu suhu semua. Ada yang tau beli nya dimana? Kisaran harga berapa ya? Buat ngangkat 3way scanspeak dengan HU 9017
    soerabaya kota rek
    4 Wks 11 Hrs 36 Mins 17 Secs
    Mantap tuh, harga 12,75 jt.. saya kenal distributornya yg di jakarta
    venture dd2, venture dd6.5, venture dd10, audison connection main power,zapco lx 150.6, zapco z500.2, van den hul magnum, van den hul orchid..
  1. HELIX DSP
    By S.U.4ever in forum Diskusi Crossover
    Last Post: 26th April 2013, 17:02
  2. wts : barang masa kini nan cerdas helix proc c dsp
    By Garu in forum Head Unit & Processor
    Last Post: 6th February 2013, 20:29
  3. HELIX C-DSP PROSESOR 8 CHANELL MADE IN GERMAN
    By Kutulompat in forum Bursa Audio Lainnya
    Last Post: 10th January 2013, 20:50
  4. HELIX C-DSP PROSESOR 8 CHANELL MADE IN GERMAN
    By Kutulompat in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 5th December 2012, 20:26
  5. WTS Power Helix H500 mk2(5ch), Cuma 2,75jt- ( SOLD!!!)
    By ric_signature in forum Power Amplifier
    Last Post: 19th November 2009, 18:41
