APRIL 2017 (NEW!!)-----RACE CALIPER PRO5000+ R-----(NEW !!)
  • Short URL:  http://modifika.si/642782
    cipondoh-tangerang
    5 Mths 3 Wks 3 Days 9 Hrs 10 Mins 23 Secs
    -CP9444 race caliper 4 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose,Center hub and bolt+adaptor
    **dengan discbrake 280mm(min velg 15 inch) harga 32 jt.
    ** dengan discbrake 295mm(min velg 16 inch) harga 34 jt.
    -CP9440 race caliper 4 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose,Center hub and bolt+adaptor
    **dengan discbrake 330mm(min velg 17 inch) harga 38 jt.
    -CP9660 race caliper 6 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose ,Center hub and bolt +adaptor
    **dengan discbrake 355mm (velg min 18 inch) harga 47 jt .
    **dengan discbrake 362mm (velg min 19 inch) harga 48 jt .
    **dengan dicsbrake 370mm (velg min 19 inch) harga 49 jt.
    **dengan discbrake 380mm (velg min 19-20 inch) harga 50 jt.
    -CP9665 race caliper 6 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose ,Center hub and bolt +adaptor
    **dengan discbrake 362mm (velg min 19 inch) harga 49 jt .
    **dengan dicsbrake 370mm (velg min 19 inch) harga 50 jt.
    **dengan discbrake 380mm (velg min 19-20 inch) harga 51 jt.
    **dengan discbrake 390mm (velg min 20 inch) harga 52 jt.
    UPDATE BIG BRAKE KIT AP RACING APRIL 2017
    -CP7600 caliper 4 pot ,AP disbrake floating slotted ,AP brake pad APF 404, Brake hose,Center hub and bolt+adaptor.
    **dengan discbrake 285mm(min velg 15 inch) harga 24 jt .
    **dengan discbrake 295mm(min velg 16 inch) harga 25.5 jt.
    -CP 5200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 330mm(min 17 inch) harga 28 jt.
    -CP 9200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 330mm(min 17 inch) harga 30 jt.
    -CP5040 race caliper 4 pot pro5000+, AP discbrake floating slotted, AP brake pad APF 402, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 330mm(min velg 17 inch) harga 36 jt.
    -CP9040 caliper 6 pot , AP disbrake floating slotted , AP brake pad APF 404, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 355mm(min velg 18 inch) harga 36 jt.
    **dengan discbrake 362mm(min velg 18-19 inch) harga 37.5 jt.
    -CP5060 race caliper 6 pot pro5000+, AP disbrake floating slotted , AP brake pad APF 402, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 355mm (velg min 18 inch) harga 45 jt.
    **dengan discbrake 362mm (velg min 18-19 inch)harga 46.5 jt.
    NEW and ready stock AP RACING World RADI-CAL Caliper new
    design futuristic and with new model Floating J-Hook design .
    -CP 8520 Radi-Cal caliper 6 pot,AP floating J-hook , AP brake pad APF 404, Brake hose,Center hub and bolt+adaptor.
    ** AP discbrake floating Curved Groove 370mm (velg min 18 inch) harga 42 jt.
    **dengan discbrake floating J-hook 370mm (velg min 18 inch) harga 42 jt .
    **dengan discbrake floating J-hook 380mm (velg min 19 inch) harga 43 jt.
    **dengan discbrake floating J-hook 390mm (velg min 20 inch) harga 45 jt.
    **dengan discbrake floating J-Hook 410mm (velg min 21 inch)
    harga 47 jt.
    -CP8530 Radi-Cal caliper 4 pot,AP discbrake floating slotted ,AP brake pad APF404, Brake hose ,Center Hub and bolt+adaptor.
    **dengan discbrake Floating J-hook 360 mm(velg minimal 18 inch)harga 37 jt.
    **dengan discbrake floating J-hook 380 mm(velg minimal 19 inch) harga 38 jt.
    **dengan discbrake floating J-Hook 400mm(velg minimal 20 inch)
    harga 40 jt.
    FOR ORDER CALL/WHATSAPP
    081382077777 - 082312077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    CENTRAL DISTRIBUTOR PERFORMANCE PARTS
    GREEN LAKE CITY RUKO CBD BLOK L NO 7
    CIPONDOH-TANGERANG 11750
    www.speedzperformance.com
    instagram:speedz77777
    Twitter: speedz77777
    cipondoh-tangerang
    harga 47 jt.
    harga 40 jt.
    SPEEDZ PERFORMANCE
    cipondoh-tangerang
    Brembo Grand tourismo start from wheels 17inch to 21 inch.
    we supply for INDONESIA Exclusive market, and many installation in customer car & dealer wanted for area not in Jakarta.
    Please come and see Stock and many application before buy and all is in stock.
    -Brembo GT 4 pot,brembo brake pad, alumunium brake hose with center bell plug n play alumunium and adaptor.
    *Dengan floating drilled discbrake 355mm harga 40 Jt.(velg minimal 18 inch)
    *Dengan floating drilled discbrake 380mm harga 42 Jt.(velg minimal 19 inch).
    -BREMBO GT 6 pot,brembo brake pad ,Brake hose with center bell plug n play alumunium dan adaptor.
    **Dengan Discbarake Floating Drillet 380mm(Buat Velg Minimal 19 INCH ) Harga 50 Jt.
    New and just coming in stock
    -BREMBO GT 8 pot,brembo brake pad ,Brake hose with center bell plug n play alumunium dan adaptor.
    **Dengan Discbarake Floating Drillet 380 MM(Buat Velg Minimal 20 inch ) Harga 50 Jt.
    **Dengan Discbrake Floating Drilled 405Mm(Buat Velg Minimal 21-22 Inch) Harga 52 Jt.
    Dapetkan potongan setiap pembelian Big Brake Kit depan + belakang extra 3 jt (extra pemotongan for customer)
    SPEED'Z PERFORMANCE
    Green Lake City Ruko CBD Blok L No: 7
    Cipondoh-Tangerang 11750
    Mobile no/Whatsapp : 081382077777 (Hanz SpeedZ)
    Instagram : speedz77777
    cipondoh-tangerang
    From 1999 Untill now Bring and Develop Performance Engine Parts.
    SPEED'Z PERFORMANCE for supply Engine performance Parts world leader stock in huge quantity for stockiest so make the Stock in very good price.
    ARP BOLTS
    BMW:M42/44 HARGA 3.750 JT ,M50/52 HARGA 4.750 JT ,S50 HARGA 4.750 JT,M10 HARGA 3.750 JT
    HONDA:B18C GSR HARGA 3.2 JT ,B16A HARGA 3.250 JT, B20 WITH B16 HEAD HARGA 3.2 JT, D16Y HARGA 3 JT , D16 NON VTEC HARGA 3 JT ,-H22 HARGA 3.4 JT,-H23 HARGA 3.4JT,-K20 HARGA 3.5 JT,-R18 HARGA 4 JT,L15 HARGA 4 JT
    MITSUBISHI
    -EVO 1-3 HARGA 3JT
    -EVO 4-9 HARGA 3 JT
    NISSAN
    -SR20 S13 HARGA 3.2 JT
    -SR20 S14/15 HARGA 3.2 JT
    -RB20/25 HARGA 4.750 JT
    -RB26 HARGA 4.750 JT
    SUBARU
    -EJ HARGA 3.5 JT
    TOYOTA
    -4AG HARGA 3 JT
    -3SGTE HARGA 3.2 JT
    -2JZGTE HARGA 4.750 JT
    -1NZFE HARGA 4 JT
    FLYWHEEL BOLT
    -HONDA D-SERIES HARGA 1.5 JT
    -HONDA B-SERIES HARGA 1.5 JT
    -TOYOTA 4AG HARGA 1.5 JT
    -TOYOTA 3SGTE HARGA 1.5 JT
    -TOYOTA 2JZGTE HARGA 2 JT
    -MITSUBISHI EVO HARGA 1.5 JT
    WHEELS STUD
    -HONDA HARGA 1.5 JT/SET
    -MITSUBISHI HARGA 1.5 JT/SET
    -SUBARU HARGA 1.5 JT/SET
    -TOYOTA HARGA 1.5 JT/SET
    FASTENER ASSEMBLY LUBRICANT
    -20 OZ HARGA 800 RIBU
    POWER ENTERPRISE TIMMING BELT KEVLAR
    -BF211 SUBARU EJ20 HARGA 2.5 JT
    -BN211 NISSAN RB20/25/26 HARGA 2.2 JT
    -BT111 TOYOTA 4AGZE HARGA 2.250 JT
    -BT121 TOYOTA 4AGE/16 HARGA 2.250 JT
    -BT131 TOYOTA 4AG AE111 HARGA 2.250 JT
    -BT221 TOYOTA 3SG HARGA 2.4 JT
    -BT222 TOYOTA 3SGTE HARGA 2.350 JT
    -BT211 TOYOTA 1JZ HARGA 2.350 JT
    -BT311 TOYOTA 2 JZ HARGA 2.350 JT
    -BM211 MITSUBISHI 4G63 HARGA 2,4 JT
    -BH141 HONDA D16 SOHC HARGA 2.2 JT
    -BH121 HONDA B16 DOHC HARGA 2.2 JT
    -BH111 HONDA B18C DOHC HARGA 2.2 JT
    -BH211 HONDA H22 DOHC HARGA 2.2 JT
    -BH221 HONDA B20 DOHAC HARGA 2.4 JT
    PERMA COOL
    -69195 oil cooler kit universal remote system 200 hp for NA harga 4.5 jt .
    TRANSGO
    -RE5R05A-HD2 HARGA 5.5 JT
    SUPERTECH
    -BLOCK GUARD D-SERIES HARGA 1.850 JT
    -BLOCKGUARD B16 HARGA 1.850 JT
    -BLOCK GUARD B20 HARGA 2 JT
    -VALVE SPRING KIT D16A HARGA 5.5 JT
    -VALVE SPRING TOYOTA 4AG16 VALVE HARGA 5.5 JT
    -VALVE OVERSIZE TOYOTA 4AG 16 VALVE HARGA 5.5 JT
    -VALVE OVERSIZE TOYOTA 4AG 20VALVE HARGA 6.5 JT
    -VALVE SPRING KIT NISSAN SR 20 DET HARGA 7 JT
    -VALVE OVERSIZE BMW M42/44 HARGA 7.5 JT
    -VALVE OVERSIZE BMW M50/52 HARGA 11.5 JT
    -VALVE SEAL TOYOTA,HONDA,NISSAN,MITSUBISHI,SUBARU HARGA 50 RIBU/PCS
    -VALVE GUIDE TOYOTA,HONDA,NISSAN,MITSUBISHI,SUBARU
    HARGA 150 RIBU/PCS
    SPRK-H100-DR/BM BMW DUAL VALVE SPRING KIT HARGA 10.5 JT
    -SPRK-H2416 HONDA CRZ 1.5L LEA SINGLE VALVE SPRING KIT HARGA 6.5 JT
    -SPRK -TC25D TOYOTA 4AG 16V DUAL VALEVE SPRING KIT HARGA 7.5 JT
    -BLOCK GUARD FOR HONDA D15B-D16Z-D16Y SINGLE CAM HARGA 1.8 JT
    -BLOCK GUARD FOR HONDA B16A/B18C/B18A/B18B HARGA 1.850 JT
    -BLOCK GUARD FOR HONDA B20 HARGA 1.850 JT
    -VALVE GUIDE INTAKE HONDA B/H SERIES 5.5MM STEAM MANGANESE BRONZE HARGA 2.4 JT
    EXEDY CLUTCH
    HONDA
    - JAZZ TYPE ORGANIC 5 JT
    - JAZZ TYPE METAL 5.250 JT
    - DC5 TYPE-R 5.750 JT
    - PRELUDE H22 5.5 JT
    - ACCORD F22 5.5 JT
    - NEW JAZZ CUSTOM METAL 5.750 JT
    - NEW JAZZ TYPE METAL 6.250 JT
    - B16/B18 5.5 JT
    - D17/D16 NON VTEC ESTILO 5.750 JT
    - D16 VTEC/FERIO 5 JT
    - CIVIC FD1/R18 6.5 JT
    - S2000 HYPERSINGLE 17.5 JT
    - DC5 TYPE-R HYPERSINGLE 17.5 JT
    MITSUBISHI
    - MIRAGE 4G92/4G93 HARGA 5.5 JT
    - GALANT VR-4 NON TURBO 2.0L HARGA 6.5 JT
    - EVO 1-3 HARGA 6.5 JT
    - EVO 4-6 HARGA 7.5 JT
    - EVO 7-10 HARGA 8.5 JT
    - GALANT VR-4 TURBO 2.5L HARGA 8.5 JT
    - EVO 4-9 TWIN PLATE HARGA 26.5 JT
    MAZDA
    - BP 6 TURBO HARGA 4.5 JT
    TOYOTA
    - 3SGE HARGA 6.5 JT
    - 3SGTE HARGA 7.5 JT
    - SUPRA 5 SPEED HARGA 7.5 JT
    - STARLET TURBO HARGA 5.5 JT
    - 1ZZ-FE HARGA 5.5 JT
    - 2ZZ-GE HARGA 5.5 JT
    - GREAT COROLLA HARGA 5.5 JT
    - YARIS HARGA 5.5 JT
    - FT86/GT86 HARGA 6.5 JT
    - 1JZ HYPERSINGLE 16.5 JT
    - 2JZGTE TWIN PLATE HARGA 26.5 JT
    SUZUKI
    - SWIFT HARGA 5.5 JT
    SUBARU
    - GC8/GDA5 SPEED 6.5 JT
    - GDB/GRB 6 SPEED HARGA 7.5 JT
    - BRZ HARGA 6.5 JT
    - GDB/GRB HYPERSINGLE HARGA 16.5 JT
    NISSAN
    - S13/14 HYPERSINGLE HARGA 16.5 JT
    - S15 HYPERSINGLE HARGA 16.5 JT
    - RB25 TWIN PLATE HARGA 26JT
    SAFE BRAKE PRO RS
    -TOYOTA INNOVA HARGA 2.350 JT
    -TOYOTA VIOS/YARIS HARGA 2.250 JT
    -HONDA CIVIC EG/EK HARGA 2.5 JT
    -HONDA CIVIC FD1/FD2 HARGA 2.6 JT
    -HONDA JAZZ I-VTEC GE8 HARGA 2.850 JT
    -MITSUBISHI PAJERO SPORT HARGA 3.2 JT
    -MITSUBISHI PAJERO SPRT DAKKAR HARGA 3.5 JT
    NGK SPARK PLUG
    -Spark Plug G-POWER PLATINUM harga 200 ribu
    -Spark Plug IRIDIUM IX BKR6EIX-11 harga 550 ribu
    -Spark Plug IRIDIUM IX BCPR6EIX-11 harga 550 ribu
    -Spark Plug IRIDIUM IX LFR6AIX-11 harga 550 ribu
    -Spark Plug IRIDIUM IX DCPR7EIX-11 harga 650 ribu
    -Spark Plug IRIDIUM DF6H-11A harga 1 jt
    -Spark Plug LASER IRIDIUM DILZKAR6A11 harga 1 jt
    -Spark Plug IRIWAY 7/8/9 harga 1 jt
    -Spark Plug IRIDIUM MAX LFR7AIX-P For SUBARU 2008+ harga 1.250 jt
    -Spark Plug RACING COMPETITION R7434-10 harga 2.5 jt
    PIVOT
    -OB Monitor harga 3 jt
    -RCX Rev Counter harga 1.650 jt
    -TURBO TIMER HARGA 700 RIBU
    -MEGA RAIZIN+GROUND HARGA 1.750 JT
    -3DRIVE TYPE FLAT WITH HARNESS HARGA 2.5 JT
    -2 IN 1 BOOST METER WITH DIGITAL HARGA 2.750 JT
    -Tacho ProGauge harga 2.5 JT
    PERFORMANCE ANALYSIS
    -EXHAUST WRAP 1X50 FEET(VOLCANO WRAP) HARGA 950RIBU
    -EXHAUST WRAP 2X50 FEET(VOLCANO WRAP) HARGA 1.050 JT
    -TURBO SHIELD (PEMBUNGKUS TURBO )T3 HARGA 2.2 JT
    -TURBO SHILED (PEMBUNGKUS TURBO )T4 HARGA 2.450 JT
    -TURBO SHIELD T3 +EXHAUST WRAP KIT HARGA 2.8 JT
    -TURBO SHIELD T4 +EXHAUST WRAP KIT HARGA 2.950 JT
    ISKY
    -306-S NON VTEC VALVE SPRING HARGA 2.5 JT
    TOMEI
    -MUFFLER TITANIUM SUBARU 08+ HATCHBACK HARGA 17 JT
    -CUSTOM CAMSHAFT 4G93 280 LIFT 11 HARGA 14.5 JT
    -TOYOTA PROCAM 4AG 16VALVE 304 LIFT 11 HARGA 8.5 jt
    -TOYOTA PONCAM 4AG 20VALVE HARGA 10.5JT
    -EXHAUST MANIFOLD SUBARU SINGLE SCROLL(EQUAL LENGTH) HARGA 12.5 JT
    -EXHAUST MANIFOLD SUBARU TWIN SCROLL(EQUAL LENGHT) HARGA 13.5 JT
    -TURBO SUCTION HOSE HARGA 3.750 JT
    COMETIC GASKET
    -HONDA HEAD GASKET D-SERIES HARGA 2.4 JT
    -HONDA HEAD GASKET B-SERIES HARGA 2.4 JT
    -HONDA HEAD GASKET H-SERIES HARGA 2.4 JT
    -HONDA HEAD GASKET K-SERIES HARGA 2.4 JT
    -NISSAN S13/S14/S15 HEAD GASKET HARGA 2.4 JT
    -NISSAN RB20/RB25/RB26 HEAD GASKET HARGA 3.5 JT
    -TOYOTA 4AG 16 VALVE/20 VALVE HEAD GASKET HARGA 2.4 JT
    -TOYOTA 3SGTE HEAD GASKET HARGA 2.4 JT
    -MITSUBISHI EVO 1-9 HEAD GASKET HARGA 2.4 JT
    -TOYOTA 4EFTE HEAD GASKET HARGA 2.4 JT
    -TOYOTA 2JZ HEAD GASKET HARGA 2.4 JT
    -TOYOTA 1UZ HEAD GASKET HARGA 4.5 JT
    -SUBARU EJ20/EJ25 HARGA 2.6 JT
    -BMW M40/42 HEAD GASKET HARGA 2.8 JT
    -NISSAN S13 OVERHAUL KIT HARGA 5.750 JT
    -NISSAN S14 OVERHAUL KIT HARGA 5.750 JT
    -NISSAN S15 OVERHAUL KIT HARGA 5.750 JT
    -NISSAN RB 25 OVERHAUL KIT HARGA 7.5 JT
    -MITSUBISHI EVO 4-8 OVERHAUL GASKET HARGA 5.750 JT
    -TOYOTA SUPRA 2 JZ OVERHAUL KIT HARGA 7.5 JT
    -SUBARU GRB 2008+ OVERHAUL KIT HARGA 9.5 JT
    MSD IGNITION
    -KABEL BUSI HONDA ACCORD HARGA 1.5 JT
    -COIL HVC-2 6 SERIES HARGA 3.5 JT
    -COIL HVC-2 7 SERIES HARGA 3.5 JT
    -COIL HVC PRO HARGA 3 JT
    -COIL MITSUBISHI TWIN HARGA 1.5 JT
    -COIL SUBARU TWIN HARGA 1.5 JT
    -DISTRIBUTOR CAP KIT INTEGRA HARGA 1.5 JT
    -DISTRIBUTOR CAP KIT B SERIES HARGA 1.5 JT
    -DISTRIBUTOR CAP KIT D SERIES HARGA 1.5 JT
    -DISTRIBUTOR CAP KIT B18 TYPE-R HARGA 1.5 JT
    -COIL BLASTER SS HARGA 1.250 JT
    -DIGITAL 6AL-2 PROGRAMABBLE HARGA 5 JT
    -7AL-3 HARGA 10 JT
    -DISTRIBUTOR VW HARGA 5 JT
    TOGA HIGH PRESSURE OIL PUMP
    - D16 HARGA 4 JT
    -B16 HARGA 4.5 JT
    -H22 HARGA 5 JT
    DRIVESHAFTSHOP
    -AXLES D-SERIES LEVEL O HARGA 9 JT
    -AXLES B-SERIES LEVEL 0 HARGA 9 JT
    -DRIEVSHAFT CARBON 1000 HP EVO 4-8 HARGA 20 JT
    DC SPORT
    -YARIS HEADER HARGA 3.5 JT
    -HEADER BSERIES HARGA 6.5 JT
    CUSCO STRUTBAR
    -OIL CATCH TANK HARGA 1.650 JT
    -SUBARU 2008+ HARGA 2.6 JT
    GREDDY
    -ULTIMATE WITH HARNESS LONG HARGA 10.5 JT
    -MAP SENSOR HARGA 2.5 JT
    -BLUE WITH HARNESS HARGA 6 JT
    -PROFEC BOOST CONTROLLERE HARGA 6.5 JT
    -Infometer touch harga 6 JT
    ETC
    -GENUINE WALBRO FUEL PUMP 255LPH HARGA 1.8 JT
    -GENUINE BOSCH 044 OUTANK FUEL PUMP HARGA 3.750 JT
    SPEED'Z PERFORMANCE
  1. Replies: 40
    Last Post: 5th May 2013, 10:40
  2. NEW RACING SEAT BRIDE CUGA 2008
    By tradesonic in forum Diskusi Interior
    Last Post: 29th April 2008, 18:57
