START 1-15 MARET DAPETKAN HARGA DIBAWAH UNTUK PEMBELIAN BIG BRAKE KIT AP RACING..
-CP7600 caliper 4 pot ,AP disbrake floating slotted ,AP brake pad APF 404, Brake hose,Center hub and bolt+adaptor.
**dengan discbrake 285mm(min velg 15 inch) harga 22.5 jt .
**dengan discbrake 295mm(min velg 16 inch) harga 23.5 jt.
-CP 5200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, Brake hose ,Center hub and bolt+adaptor.
**dengan discbrake 330mm(min 17 inch) harga 27 jt.
-CP 9200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, Brake hose ,Center hub and bolt+adaptor.
**dengan discbrake 330mm(min 17 inch) harga 29 jt.
-CP5040 race caliper 4 pot pro5000+, AP discbrake floating slotted, AP brake pad APF 402, Brake hose ,Center hub and bolt+adaptor.
**dengan discbrake 330mm(min velg 17 inch) harga 34 jt.
-CP9040 caliper 6 pot , AP disbrake floating slotted , AP brake pad APF 404, Brake hose ,Center hub and bolt+adaptor.
**dengan discbrake 355mm(min velg 18 inch) harga 34 jt.
**dengan discbrake 362mm(min velg 18-19 inch) harga 35.5 jt.
-CP5060 race caliper 6 pot pro5000+, AP disbrake floating slotted , AP brake pad APF 402, Brake hose ,Center hub and bolt+adaptor.
**dengan discbrake 355mm (velg min 18 inch) harga 43.5 jt.
**dengan discbrake 362mm (velg min 18-19 inch)harga 45 jt.
NEW and ready stock AP RACING World RADI-CAL Caliper new design futuristic and with new model Floating J-Hook design .
-CP 8520 Radi-Cal caliper 6 pot,AP floating J-hook , AP brake pad APF 404, Brake hose,Center hub and bolt+adaptor.
** AP discbrake floating Curved Groove 370mm (velg min 18 inch) harga 43 jt.
**dengan discbrake floating J-hook 370mm (velg min 18 inch) harga 43 jt .
**dengan discbrake floating J-hook 380mm (velg min 19 inch) harga 44 jt.
**dengan discbrake floating J-hook 390mm (velg min 20 inch) harga 46 jt.
**dengan discbrake floating J-Hook 410mm (velg min 21 inch)
harga 48 jt.
-CP8530 Radi-Cal caliper 4 pot,AP discbrake floating slotted ,AP brake pad APF404, Brake hose ,Center Hub and bolt+adaptor.
**dengan discbrake Floating J-hook 360 mm(velg minimal 18 inch)harga 37 jt.
**dengan discbrake floating J-hook 380 mm(velg minimal 19 inch) harga 39 jt.
**dengan discbrake floating J-Hook 400mm(velg minimal 20 inch)
harga 41 jt.
(NEW!!)-----RACE CALIPER PRO5000+ R-----(NEW !!)
-CP9444 race caliper 4 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose,Center hub and bolt+adaptor
**dengan discbrake 280mm(min velg 15 inch) harga 32 jt.
-CP9440 race caliper 4 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose,Center hub and bolt+adaptor
**dengan discbrake 330mm(min velg 17 inch) harga 38 jt.
-CP9660 race caliper 6 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose ,Center hub and bolt +adaptor
**dengan discbrake 355mm (velg min 18 inch) harga 47 jt .
**dengan discbrake 362mm (velg min 19 inch) harga 48 jt .
**dengan dicsbrake 370mm (velg min 19 inch) harga 49 jt.
**dengan discbrake 380mm (velg min 19-20 inch) harga 50 jt.
-CP9665 race caliper 6 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose ,Center hub and bolt +adaptor
**dengan discbrake 362mm (velg min 19 inch) harga 49 jt .
**dengan dicsbrake 370mm (velg min 19 inch) harga 50 jt.
**dengan discbrake 380mm (velg min 19-20 inch) harga 51 jt.
**dengan discbrake 390mm (velg min 20 inch) harga 52 jt.
FOR ORDER CALL/WHATSAPP
081382077777 - 082312077777(HANZ SPEEDZ)
SPEEDZ PERFORMANCE
CENTRAL DISTRIBUTOR PERFORMANCE PARTS
GREEN LAKE CITY RUKO CBD BLOK L NO 7
CIPONDOH-TANGERANG 11750
www.speedzperformance.com
instagram:speedz77777
Twitter: speedz77777
