gosip seputar pengganti 1ZZ-FE
Results 1 to 10 of 58
  • Short URL:  http://modifika.si/6290
    satyr
    mesin 1800 cc baru untuk corolla terbaru
    The upcoming replacement for the Toyota Corolla Altis here in Malaysia might see the introduction of a CVT transmission, thanks to a new pair of engine and transmission announced last month by Toyota as part of it’s efforts to revamp it’s gasoline engine and transmission line-up by the year 2010.
    The new engine is the 1.8 liter 2ZR-FE, which replaces the 1ZZ-FE in Toyota’s line-up. The 2ZR-FE has a few enhancements over the 1ZZ-FE found in our current Toyota Corolla Altis. For one, the new 2ZR-FE has Dual VVT-i which varies valve timing optimally for various engine speeds and loads on both the intake and exhaust valves. The previous 1ZZ-FE only has variable valve timing on the exhaust valves. Maximum torque has increased from 170Nm at 4,200 rpm to 175Nm at 4,400 rpm. Horsepower has increased from 132hp at 6,000 rpm to 136hp at 6,600 rpm. Fuel efficiency is supposed to be 5% higher compared to conventional engines.
    FYI : 1ZZ-FE di jepang hanya 132 hp (di indo NET nya 136 hp) karena adanya regulasi emisi. jadi 2ZR-FE dual VVT-i di indo sepertinya dapat menembus 140 hp NET. mesin ini untuk menyaingi R18A civic (140 hp)
    Ini baru spy info loh...
    info lengkap :
    _http://www.toyota.co.jp/en/news/06/0613.html
    _http://paultan.org/archives/2006/07/16/new-flagship-18-liter-powerplant-for-toyota/
    Paris van java
    Waduh,kayaknya bagus nih Tyr..
    Beneran Satyr asli Toyota Man..
    satyr
    hahaha...bisa aja si bos
    S.O.E.R.A.B.A.I.A
    2 Wks 1 Hr 6 Mins 40 Secs
    setuju!,OmSatyr memang profesornya Toyota,huehehe
    Jakarta Selatan
    di europe, yaris/echo ada yg kluar pake mesin ini nih.. gile benerr...
    satyr
    yah seperti biasa...line up kencang gak masuk indo. padahal corolla compressor aja ada tuh di europe
    ini yg gw demen......... dari taon 90-an, perseteruan Civic vs Corolla terus berlanjut sampe sekarang. 4A-FE sempat keok ama D16 (jaman-nya all new corolla & ferio), tapi D17 dihajar ama 1ZZ-FE (jaman-nya civic vt-i & altis)....... 1ZZ-FE keok ama R18A sejak all new civic di-launching...... nah sekarang altis mau ganti mesin 1ZR-FE (tapi "bajunya" belum ketauan & gw harap altis baru juga ganti "baju" yg lebih bagus), so perseteruan dimulai lagi :
    1ZR-FE 1800 cc Dual VVT-i 140 dk
    vs
    R18A 1800 cc SOHC i-VTEC 140 dk
    seru nih kayaknya......... :smt003
    satyr
    Quote Originally Posted by Super Bejo
    vs
    4A-FE keok ama D16A ? gak juga tuh bos.. liat aja torsinya D16A melempem gitu... 14.8 kgm @ 5500 rpm vs 15 kgm @ 4800 kgm - no offense -
    untuk 2ZR-FE sih blom tau hp nya yg buat pasar luar jepang brp
    jakarta timur
    9 Hrs 9 Mins 19 Secs
    wah..
    toyota kan masihnada mesin 2zz-ge???.. hilangkah itu??..
    vvtl-i??..
    timing sama liftnya bosa diatur??...
    satyr
    2ZZ-GE kan G head untuk sport
    kalo 2ZR-FE kan F head yg economic punya
GT Radial Venom 300x250
  1. Pengganti NSX ??? HSV 010 GT
    By Mr.Qq in forum Automotive
    Last Post: 23rd August 2013, 08:55
  2. Replies: 0
    Last Post: 31st August 2010, 11:38
  3. ~~GOSIP YG PALING HOT GITU LHOOOOOO0~~
    By F371X in forum Automotive
    Last Post: 4th June 2008, 09:50
  4. pengganti w7
    By plow in forum Diskusi Subwoofer
    Last Post: 29th April 2007, 16:45
  5. gosip cr-v baru, ad yg taw?
    By kurus in forum Diskusi Otomotif Lain-Lainnya
    Last Post: 22nd September 2006, 22:36
