Auto Update Harga di bulan April 2016 for Big Brake Kit AP RACING and BREMBO.
We bring genuine big brake kit BREMBO and AP RACING ,we supply for INDONESIA and MALAYSIA market, and many installation in customer car & dealer wanted.
*****AP Racing made in UNITED KINGDOM*********
-CP7600 caliper 4 pot ,AP disbrake 295mm floating slotted ,AP brake pad APF 404,HEL Brake hose harga 24 jt(black caliper) dan harga 25,5 jt (red caliper ) applikasi utk velg 15-16 inch.
-CP 5200 caliper 4 pot , AP discbrake floating slotted 330mm, AP brake pad APF 404, HEL brake hose dengan harga 29 jt (black caliper) dan 30,5 jt (red caliper) applikasi utk velg 17 inch.
-CP 5040 race caliper 4 pot pro5000+, AP discbrake floating slotted 330mm, AP brake pad APF 402, HEL brake hose harga 36 jt. (applikasi utk velg 17 inch).
-CP 9040 caliper 6 pot , AP disbrake 355mm floating slotted , AP brake pad APF 404, HEL brake hose harga 36 jt (black caliper) dan 37,5 jt( red caliper) applikasi utk velg 18inch
*dengan discbrake floating slotted 362mm harga 39 jt.(applikasi utk velg 19 inch).
-CP 5060 race caliper 6 pot pro5000+, AP disbrake 355mm floating slotted , AP brake pad APF 402, HEL brake hose harga 42 jt. (applikasi utk velg 18inch)
*dengan discbrake floating slotted 362mm harga 45 jt.(applikasi utk velg 19 inch).
**** BREMBO Made in ITALY ********
-Brembo GT 4 pot,brembo brake pad, alumunium brake hose with center bell plug & play alumunium and adaptor.
*Dengan floating drilled discbrake 355mm harga 39 Jt.(velg minimal 18 inch)
*Dengan floating drilled discbrake 380mm harga 42 Jt.(velg minimal 19 inch)
---extra 4 jt apabila dipasang ke caliper belakang karena pembuatan center bell besar --------
-BREMBO 17Z caliper 6 pot,BREMBO brake pad,with center bell plug & play alumunium and adaptor dengan discbrake floating drilled 355mm & brake hose harga 38 jt.(velg minimal 18 inch).
-BREMBO 19Z 6 pot ,BREMBO brake pad with center bell plug & play alumunium , and adaptor dengan discbrake 380mm floating drilled harga 44 jt.(velg minimal 19inch)
**dengan floating drilled disbrake 405mm harga 46 jt. (velg minimal 20 inch).
-BREMBO GT 6 pot.BREMBO brake pad GT,Brake hose with center bell plug n play alumunium dan adaptor.
**Dengan Discbarake Floating Drillet 380 MM(Buat Velg Minimal 19 INCH ) Harga 50 Jt.
-BREMBO REAR PORSCHE New CAYENNE Caliper (For Rear Use Only),Brembo Brake Pad With Discbrake 345MM Floating Drilled Harga 35 JT.(velg minimal 18 inch)
**Discbrake 380Mm Floating Drilled HARGA 38 JT.(velg minimal 19 inch).
-BREMBO 4POT Model 7L6 (For Rear use only ),BREMBO Brake Pad With Discbrake 345MM Floating Discbrake Harga 33 JT.(velg minimal 18 inch)
**Discbrake 380MM Floating Drilled Harga 36 JT.(velg minimal 19 inch).
$$$$$---untuk pembelian big brake kit depan+belakang dapetkan potongan harga 3 jt-----$$$$$
For Order Call/Whatsapp:
081382077777-085882077777(HANZ SPEEDZ)
SPEEDZ PERFORMANCE
Green Lake City Ruko CBD Blok L no:7
Tangerang 11750
