Auto Update Harga di bulan April 2016 for Big Brake Kit AP RACING a
Results 1 to 10 of 10
  • Short URL:  http://modifika.si/628805
    cipondoh-tangerang
    5 Mths 3 Wks 13 Hrs 41 Secs
    Auto Update Harga di bulan April 2016 for Big Brake Kit AP RACING and BREMBO.
    We bring genuine big brake kit BREMBO and AP RACING ,we supply for INDONESIA and MALAYSIA market, and many installation in customer car & dealer wanted.
    *****AP Racing made in UNITED KINGDOM*********
    -CP7600 caliper 4 pot ,AP disbrake 295mm floating slotted ,AP brake pad APF 404,HEL Brake hose harga 24 jt(black caliper) dan harga 25,5 jt (red caliper ) applikasi utk velg 15-16 inch.
    -CP 5200 caliper 4 pot , AP discbrake floating slotted 330mm, AP brake pad APF 404, HEL brake hose dengan harga 29 jt (black caliper) dan 30,5 jt (red caliper) applikasi utk velg 17 inch.
    -CP 5040 race caliper 4 pot pro5000+, AP discbrake floating slotted 330mm, AP brake pad APF 402, HEL brake hose harga 36 jt. (applikasi utk velg 17 inch).
    -CP 9040 caliper 6 pot , AP disbrake 355mm floating slotted , AP brake pad APF 404, HEL brake hose harga 36 jt (black caliper) dan 37,5 jt( red caliper) applikasi utk velg 18inch
    *dengan discbrake floating slotted 362mm harga 39 jt.(applikasi utk velg 19 inch).
    -CP 5060 race caliper 6 pot pro5000+, AP disbrake 355mm floating slotted , AP brake pad APF 402, HEL brake hose harga 42 jt. (applikasi utk velg 18inch)
    *dengan discbrake floating slotted 362mm harga 45 jt.(applikasi utk velg 19 inch).
    **** BREMBO Made in ITALY ********
    -Brembo GT 4 pot,brembo brake pad, alumunium brake hose with center bell plug & play alumunium and adaptor.
    *Dengan floating drilled discbrake 355mm harga 39 Jt.(velg minimal 18 inch)
    *Dengan floating drilled discbrake 380mm harga 42 Jt.(velg minimal 19 inch)
    ---extra 4 jt apabila dipasang ke caliper belakang karena pembuatan center bell besar --------
    -BREMBO 17Z caliper 6 pot,BREMBO brake pad,with center bell plug & play alumunium and adaptor dengan discbrake floating drilled 355mm & brake hose harga 38 jt.(velg minimal 18 inch).
    -BREMBO 19Z 6 pot ,BREMBO brake pad with center bell plug & play alumunium , and adaptor dengan discbrake 380mm floating drilled harga 44 jt.(velg minimal 19inch)
    **dengan floating drilled disbrake 405mm harga 46 jt. (velg minimal 20 inch).
    -BREMBO GT 6 pot.BREMBO brake pad GT,Brake hose with center bell plug n play alumunium dan adaptor.
    **Dengan Discbarake Floating Drillet 380 MM(Buat Velg Minimal 19 INCH ) Harga 50 Jt.
    -BREMBO REAR PORSCHE New CAYENNE Caliper (For Rear Use Only),Brembo Brake Pad With Discbrake 345MM Floating Drilled Harga 35 JT.(velg minimal 18 inch)
    **Discbrake 380Mm Floating Drilled HARGA 38 JT.(velg minimal 19 inch).
    -BREMBO 4POT Model 7L6 (For Rear use only ),BREMBO Brake Pad With Discbrake 345MM Floating Discbrake Harga 33 JT.(velg minimal 18 inch)
    **Discbrake 380MM Floating Drilled Harga 36 JT.(velg minimal 19 inch).
    $$$$$---untuk pembelian big brake kit depan+belakang dapetkan potongan harga 3 jt-----$$$$$
    For Order Call/Whatsapp:
    081382077777-085882077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    Green Lake City Ruko CBD Blok L no:7
    Tangerang 11750
    cipondoh-tangerang
    SPEEDZ PERFORMANCE
    Tangerang 11750
    cipondoh-tangerang
    SPEEDZ PERFORMANCE
    Tangerang 11750
    cipondoh-tangerang
    SPEEDZ PERFORMANCE
    Tangerang 11750
    cipondoh-tangerang
    SPEEDZ PERFORMANCE
    Tangerang 11750
    cipondoh-tangerang
    SPEEDZ PERFORMANCE bring in ready stock AP RACING World RADI-CAL Caliper with new design disc brake J-Hook model And Curved Groove.
    CP 8520 caliper 6 pot,AP discbrake floating slotted , AP brake pad APF 404, Brake hose.
    **AP discbrake 380mm (velg minimal 19 inch) floating slotted harga 46 jt.
    **AP discbrake 400mm (velg minimal 20 inch) floating slotted harga 48 jt.
    Option use J-Hook disc brake floating
    **AP discbrake 370mm (velg minimal 18 inch)floating J-Hook harga 48 jt
    **AP discbrake 380mm (velg minimal 19 inch)floating J-Hook harga 50 jt
    **AP discbrake 390mm(velg minimal 20 inch)floating J-Hook harga 52 jt.
    CP8530 caliper 4 pot,AP discbrake floating slotted ,AP brake pad APF404, Brake hose .
    **AP discbrake 380mm floating slotted (velg minimal 19 inch) harga 42 jt.
    **AP discbrake 380 mm(velg minimal 19 inch) floating J-Hook harga 44 jt.
    **AP discbrake 390 mm(velg minimal 20 inch) floating J-Hook harga 46 jt.
    SPEEDZ PERFORMANCE
    Green Lake City Ruko CBD Blok L no 7
    Cipondoh-Tangerang.
    cipondoh-tangerang
    **AP discbrake 410mm(velg diats 20 inch) floating J-Hook harga 54 jt.
    **AP discbrake 400 mm(velg diatas 20 inch) floating J-Hook harga 48 jt.
    SPEEDZ PERFORMANCE
    Cipondoh-Tangerang.
    cipondoh-tangerang
    SPEEDZ PERFORMANCE bring in ready stock AP RACING World RADI-CAL Caliper with new design disc brake J-Hook Floating.
    CP 8520 Radi-Cal caliper 6 pot,AP discbrake floating slotted , AP brake pad APF 404, Brake hose.
    **AP discbrake 370mm (velg minimal 18 inch)floating J-Hook harga 47 jt
    **AP discbrake 380mm (velg minimal 19 inch)floating J-Hook harga 48 jt
    **AP discbrake 390mm(velg minimal 20 inch)floating J-Hook harga 49 jt.
    **AP discbrake 410mm(velg diats 20 inch) floating J-Hook harga 50.5 jt.
    CP8530 Radi-Cal caliper 4 pot,AP discbrake floating slotted ,AP brake pad APF404, Brake hose .
    **AP discbrake 360 mm(velg minimal 18 inch) floating J-Hook harga 42 jt.
    **AP discbrake 400 mm(velg diatas 20 inch) floating J-Hook harga 45.5 jt.
    dan utk pembelian depan belakang ada extra potongan 3 jt
    081382077777 (HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    Cipondoh-Tangerang.
    cipondoh-tangerang
    SPEEDZ PERFORMANCE
    Cipondoh-Tangerang.
    cipondoh-tangerang
    SPECIAL PRICE FOR AP RACING BIG BRAKE KIT
    (25 november-15 desember)
    -CP7600 caliper 4 pot ,AP disbrake floating slotted ,AP brake pad APF 404, Brake hose,Center hub +adaptor.
    **dengan discbrake 285mm(min velg 15 inch) harga 22.5 jt .
    **dengan discbrake 295mm(min velg 16 inch) harga 24 jt.
    -CP 5200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, Brake hose ,Center hub +adaptor.
    **dengan discbrake 330mm(min 17 inch) harga 26.5 jt.
    -CP9200 caliper 4 pot (new model caliper), AP discbrake floating slotted, AP brake pad APF 404, brake hose ,Center hub +adaptor.
    **dengan discbrake 330mm(min 17 inch) harga 27.5 jt.
    -CP 5040 race caliper 4 pot pro5000+, AP discbrake floating slotted, AP brake pad APF 402, Brake hose ,Center hub +adaptor.
    **dengan discbrake 355mm(min velg 18 inch) harga 34 jt.
    -CP 9040 caliper 6 pot , AP disbrake floating slotted , AP brake pad APF 404, Brake hose ,Center hub +adaptor.
    **dengan discbrake 362mm(min velg 18-19 inch) harga 36 jt.
    -CP 5060 race caliper 6 pot pro5000+, AP disbrake floating slotted , AP brake pad APF 402, Brake hose ,Center hub+adptor.
    **dengan discbrake 355mm (velg min 18 inch) harga 40 jt.
    **dengan discbrake 362mm (velg min 18-19 inch)harga 42 jt.
    NEW and ready stock AP RACING World RADI-CAL Caliper new
    design futuristic and with new model Floating J-Hook design .
    -CP 8520 caliper 6 pot,AP floating J-hook , AP brake pad APF 404, Brake hose,Center hub+adaptor.
    ** AP discbrake floating Curved Groove 370mm (velg min 18 inch) harga 42 jt
    **dengan discbrake floating J-hook 370mm (velg min 18 inch) harga 42 jt
    **dengan discbrake floating J-hook 380mm (velg min 19 inch) harga 43 jt
    **dengan discbrake floating J-hook 390mm (velg min 20 inch) harga 44 jt.
    **dengan discbrake floating J-hook 410mm (velg minimal 21-22inch)harga 47 jt.
    -CP8530 caliper 4 pot,AP discbrake floating slotted ,AP brake pad APF404, Brake hose ,Center Hub+adaptor.
    **dengan discbrake Floating J-hook 360 mm(velg minimal 19 inch)harga 37 jt.
    **dengan discbrake floating J-hook 380 mm(velg minimal 20 inch) harga 39.5 jt.
    **dengan discbrake floating jJ-hook 400 mm(velg minimal 21 inch) harga 41.5 jt.
    FOR ORDER CALL/WHATSAPP
    081382077777 -082312077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    CENTRAL DISTRIBUTOR PERFORMANCE PARTS
    GREEN LAKE CITY RUKO CBD BLOK L NO 7
    CIPONDOH-TANGERANG 11750
    www.speedzperformance.com
MBtech Datsun 300x250
  1. UPDATE PROMO BIG BRAKE KIT AP RACING AND BREMBO
    By [speed'Z] in forum Speed'Z Performance
    Last Post: 25th February 2018, 03:40
  2. Penjualan mobil BMW Mencapai Angka Tertinggi di Bulan April
    Last Post: 16th July 2014, 08:47
  3. BARU SPEEDZ PERFORMANCE RACING SUPPLIEST N STOCKIEST FOR BIG BRAKE KIT BREMBO
    By [speed'Z] in forum Jual Beli Mesin Lainnya
    Last Post: 13th June 2014, 23:07
  4. BARU SPEEDZ PERFORMANCE RACING SUPPLIEST N STOCKIEST FOR BIG BRAKE KIT AP RACING
    Last Post: 17th December 2013, 14:46
  5. BARU SPEEDZ PERFORMANCE RACING SUPPLIEST N STOCKIEST FOR BIG BRAKE KIT BREMBO
    By [speed'Z] in forum Bursa Kaki Lainnya
    Last Post: 16th December 2013, 13:02
