Speed'Z Performance is Triniti clutch authorized dealer in indonesi
Results 1 to 5 of 5
  • Short URL:  http://modifika.si/623080
    cipondoh-tangerang
    5 Mths 3 Wks 13 Hrs 41 Secs
    Speed'Z Performance is Triniti clutch authorized dealer in indonesia.
    For order call/whatsapp :081382077777(Hanz speedz)
    SPEEDZ PERFORMANCE
    Central Distributor Performance Parts, Racing Supplies & Modification.
    Jalan biak no:48-48A.JAKARTA PUSAT10150
    Facebook id:speedzperformance
    cipondoh-tangerang
    **BEST DEAL GENUINE AP RACING BIG BRAKE KIT FOR NOVEMBER**
    We bring genuine big brake kit AP racing,we supply for INDONESIA and MALAYSIA market and many installation in customer car.
    -CP 8520 new RADI-CAL caliper 6 pot ,AP discbrake 355 Mm floating slotted (min velg 18inch),AP brake pad APF 404, Hel brake hose harga 40 jt (black caliper ) dan harga 41,5 JT (red caliper),
    *AP discbrake 362 mm floating Slotted 43 Jt (min velg 19inch),
    *AP discbrake 380Mm floating Slotted 46 JT(min velg 19inch full).
    -CP 8530 new RADI-CAL caliper 4 pot,AP discbrake 330mm floating slotted (min velg 17inch), AP brake pad APF 404. Hel brake hose harga 33jt (Black caliper) dan harga 34,5 jt(Red caliper),
    *AP discbrake 345mm floating slotted harga 36 jt(min velh 18inch),
    *AP discbrake 355mm Floating slotted harga 39 jt(min velg 18inch full).
    -CP7600 black caliper 4 pot , AP disbrake 295mm floating slotted (min velg 16inch) ,AP brake pad APF 404 ,Hel Brake hose harga 25 jt(black caliper) dan harga 26,5 jt(red caliber).
    -CP 5200 black caliper 4 pot , AP discbrake floating slotted 330mm(min velg 17 inch), AP brake pad, APF 404, brake hose dengan harga 29 jt (black caliper) dan 30,5 jt (red caliper).
    -CP 5040 race caliper 4 pot, AP discbrake floating slotted 330mm(min velg 17 inch), AP brake pad APF 402, brake hose harga 36 jt (titanium colour).
    -CP 9040 black caliper 6 pot , AP disbrake 355mm floating slotted (min velg 18 inch), AP brake pad APF 404, Hel brake hose harga 36 jt (black caliber) dan 37,5 jt apabila (red caliper),
    *dengan discbrake floating slotted 362mm harga 39 jt(min velg 19 inch).
    For Order Call/Whatsapp:081382077777/085882077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    JALAN BIAK NO 48-48A
    JAKARTA PUSAT 10150
    cipondoh-tangerang
    GENUINE BIG BRAKE KIT BREMBO MADE IN ITALY
    We bring genuine big brake kit Brembo ,we supply for INDONESIA and MALAYSIA market and many installation in customer car.
    -Brembo GT 4 pot(grand turismo), Brembo brake pad, brake hose with center bell plug & play alumunium and adaptor.
    *Dengan discbrake floating drilled 330mm harga 36 Jt (min velg 17 inch),
    *Dengan floating drilled discbrake 345mm harga 38 Jt (min velg 18 inch)
    *Dengan floating drilled discbrake 355mm harga 39 Jt (min velg 18 inch full)
    *Dengan floating drilled discbrake 380mm harga 42 Jt(min vekg 19 inch)
    -BREMBO 17Z 6 pot, Brembo brake pad, Brake hose with center bell plug & play alumunium and adaptor dengan Brembo discbrake floating drilled 355mm harga 38 jt(min velg 18 inch).
    -BREMBO 19Z 6 pot ,BREMBO brake pad with center bell plug & play alumunium , and adaptor dengan floating drilled disbrake 380mm harga 46 jt (min velg 19 inch).
    -BREMBO GT6 pot (grand turismo) , Brembo brake pad GT, Brembo Brake hose with center bell plug n play alumunium dan adaptor.
    **Dengan discbrake floating drilled 355mm harga 48 Jt(min velg 18 inch),
    **Dengan Discbarake Floating Drillet 380mm Harga 50 Jt(min velg 19 inch),
    **Dengan Discbrake Floating Drilled 405Mm Harga 52 Jt(min velg 20 inch).
    -BREMBO REAR PORSCHE New CAYENNE Caliper (For Rear Use Only),Brembo Brake Pad and brembo brake hose With Discbrake 345MM Floating Drilled Harga 35 JT(min velg 17 inch),
    **Discbrake 380Mm Floating Drilled HARGA 38 jt(min velg 18 inch).
    -BREMBO 4POT Model 7AL6 (For Rear use only ),BREMBO Brake Pad and brembo brake hose With Discbrake 345MM Floating Discbrake Harga 33 JT(min velg 18 inch),
    **Discbrake 380MM Floating Drilled Harga 36 jt(min velg 19 inch).
    SPEEDZ PERFORMANCE
    JAKARTA PUSAT 10150
    cipondoh-tangerang
    SPEEDZ PERFORMANCE
    JAKARTA PUSAT 10150
    cipondoh-tangerang
    SPEEDZ PERFORMANCE
    JAKARTA PUSAT 10150
NGK Busi GT Radial
  1. EXEDY CLUTCH MAIN DEALER IN INDONESIA
    By [speed'Z] in forum Speed'Z Performance
    Last Post: 30th October 2016, 04:32
  2. OGURA CLUTCH AUTHORIZED DEALER
    Last Post: 5th October 2016, 16:55
  3. OS GIKEN CLUTCH AUTHORIZED DEALER IN INDONESIA
    Last Post: 5th October 2016, 16:44
  4. ATS/CARBONETIC CLUTCH INTERNATIONAL DEALER IN INDONESIA
    Last Post: 25th August 2016, 05:22
  5. BILLION AUTHORIZED DEALER IN INDONESIA
    Last Post: 20th November 2014, 13:12
