UPDATE PROMO BIG BRAKE KIT AP RACING AND BREMBO - Page 2
Page 2 of 8 FirstFirst 123456 ... LastLast
Results 11 to 20 of 74
  • Short URL:  http://modifika.si/622231
    cipondoh-tangerang
    5 Mths 3 Wks 13 Hrs 41 Secs
    PROMO AKHIR TAHUN UNTUK PRODUCT DIBAWAH INI :
    SAFE BRAKE PRO RS
    -TOYOTA INNOVA HARGA 2.350 JT
    -TOYOTA VIOS/YARIS HARGA 2.250 JT
    -HONDA CIVIC EG/EK HARGA 2.5 JT
    -HONDA CIVIC FD1/FD2 HARGA 2.6 JT
    -HONDA JAZZ I-VTEC GE8 HARGA 2.850 JT
    -MITSUBISHI PAJERO SPORT HARGA 3.2 JT
    -MITSUBISHI PAJERO SPRT DAKKAR HARGA 3.5 JT
    PIVOT
    -TURBO TIMER HARGA 700 RIBU
    -RAIZIN+GROUND HARGA 900 RIBU
    -MEGA RAIZIN+GROUND HARGA 1.750 JT
    -3DRIVE TYPE FLAT WITH HARNESS HARGA 2.5 JT
    -2 IN 1 BOOST METER WITH DIGITAL HARGA 2.750 JT
    CP PISTON
    -MITSUBISHI EVO 3-9 OS 0.5MM HARGA 10.5 JT
    -MITSUBISHI EVO 3-9 OS 0.5MM STROKER 100 HARGA 10.5 JT
    -MITSUBISHI EVO 3-9 OS 1MM STROKER 100 HARGA 10.5 JT
    -SUBARU EJ20 OVERSIZE 0.5MM HARGA 11JT
    -SUBARU EJ25 OVERSIZE 0.5MM HARGA 11 JT
    -HONDA D16 OS 2.5MM COMP 13.5(CUSTOM) HARGA 11.5 JT
    -TOYOTA 4AG16VALVE OS 0.5MM HIGH COMP HARGA 11 JT
    ISKY
    -306-S NON VTEC VALVE SPRING HARGA 2.250 JT
    -506-S VTEC VALVE SPRING HARGA 2.250 JT
    TOMEI
    -CUSTOM CAMSHAFT 4G93 280 LIFT 11 HARGA 14.5 JT
    -TOYOTA PROCAM 4AG 16VALVE 304 LIFT 11 HARGA 8.5 jt
    -TOYOTA PONCAM 4AG 20VALVE HARGA 10.5JT
    -EXHAUST MANIFOLD SUBARU SINGLE SCROLL(EQUAL LENGTH) HARGA 12.5 JT
    -EXHAUST MANIFOLD SUBARU TWIN SCROLL(EQUAL LENGHT) HARGA 13.5 JT
    -TURBO SUCTION HOSE HARGA 3.750 JT
    COMETIC GASKET
    -NISSAN S13 OVERHAUL KIT HARGA 5.750 JT
    -NISSAN S14 OVERHAUL KIT HARGA 5.750 JT
    -NISSAN S15 OVERHAUL KIT HARGA 5.750 JT
    -NISSAN RB 25 OVERHAUL KIT HARGA 7.5 JT
    -TOYOTA SUPRA 2 JZ OVERHAUL KIT HARGA 7.5 JT
    -SUBARU GRB 2008+ OVERHAUL KIT HARGA 9.5 JT
    MSD IGNITION
    -KABEL BUSI HONDA ACCORD HARGA 1.5 JT
    -COIL HVC-2 6 SERIES HARGA 3.5 JT
    -COIL HVC-2 7 SERIES HARGA 3.5 JT
    -COIL HVC PRO HARGA 3 JT
    -COIL MITSUBISHI TWIN HARGA 1.5 JT
    -COIL SUBARU TWIN HARGA 1.5 JT
    -DISTRIBUTOR CAP KIT INTEGRA HARGA 1.5 JT
    -DISTRIBUTOR CAP KIT B SERIES HARGA 1.5 JT
    -DISTRIBUTOR CAP KIT D SERIES HARGA 1.5 JT
    -DISTRIBUTOR CAP KIT B18 TYPE-R HARGA 1.5 JT
    -COIL SS BLASTER2 W/BALLST &HARDWARE HARGA 1.5 JT
    -COIL SS BALSTER 2 HIGH PERFORMANCE HARGA 1.350 JT
    -COIL BLASTER SS HARGA 1.250 JT
    -DIGITAL 6 AL HARGA 4 JT
    -DIGITAL 6AL-2 HARGA 4.750 JT
    -7AL-3 HARGA 10 JT
    TOGA HIGH PRESSURE OIL PUMP
    - D16 HARGA 4 JT
    -B16 HARGA 4.5 JT
    -H22 HARGA 5 JT
    DRIVESHAFTSHOP
    -AXLES D-SERIES LEVEL O HARGA 8.5 JT
    -AXLES B-SERIES LEVEL 0 HARGA 8.5 JT
    -DRIEVSHAFT CARBON 1000 HP EVO 4-8 HARGA 20 JT
    DC SPORT
    -YARIS HEADER HARGA 3.5 JT
    CUSCO STRUTBAR
    -OIL CATCH TANK HARGA 1.650 JT
    -SUBARU 2008+ HARGA 2.6 JT
    -SUBARU/TOYOTA FT 86 HARGA 2.6 JT
    GREDDY
    -ULTIMATE WITH HARNESS LONG HARGA 10.5 JT
    -MAP SENSOR HARGA 2.5 JT
    -PROFEC BOOST CONTROLLERE HARGA 6.5 JT
    -INFOMETER TOUCH HARGA 6.250 JT
    ETC
    -GENUINE WALBRO FUEL PUMP 255LPH HARGA 1.8 JT
    -GENUINE BOSCH 044 OUTANK FUEL PUMP HARGA 3.750 JT
    -BLOW OFF HKS SQV4 GENUINE HARGA 3.750 JT
    FOR ORDER CALL/WHATSAPP: 081382077777 (HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    JALAN BIAK NO 48-48A
    JAKARTA PUSAT10150
  2. #12
    cipondoh-tangerang
    SAFE BRAKE PRO RS
    PIVOT
    CP PISTON
    ISKY
    TOMEI
    COMETIC GASKET
    MSD IGNITION
    -7AL-3 HARGA 10 JT
    - D16 HARGA 4 JT
    -B16 HARGA 4.5 JT
    -H22 HARGA 5 JT
    DRIVESHAFTSHOP
    DC SPORT
    CUSCO STRUTBAR
    GREDDY
    ETC
    SPEEDZ PERFORMANCE
    JAKARTA PUSAT10150
  3. #13
    cipondoh-tangerang
    +++++Update Promo big brake kit Ap racing and Brembo+++++
    We bring genuine big brake kit brembo and AP racing,we supply for INDONESIA and MALAYSIA market and many installation in customer car.
    __-AP Racing made in UNITED KINGDOM -__
    *New RADI-CAL(New Design)*
    -CP 8520 new RADI-CAL caliper 6 pot ,AP discbrake 355 Mm floating slotted ,AP brake pad APF 404,AP brake hose harga 40 jt (black) dan harga 41,5 JT (red)
    *AP discbrake 362 mm floating Slotted 43 Jt.
    *AP discbrake 380Mm floating Slotted 46 JT.
    -CP 8530 new RADI-CAL caliper 4 pot,AP discbrake 330mm floating slotted , AP brake pad APF 404. AP brake hose harga 33jt (Black) dan harga 34,5 jt(Red)
    *AP discbrake 345mm floating slotted harga 36jt.
    *AP discbrake 355mm Floating slotted harga 39 jt.
    -CP7600 black caliper 4 pot , AP disbrake 295mm floating slotted .AP brake pad APF 404 .Brake hose harga 25 jt.
    -CP 5200 black caliper 4 pot , AP discbrake floating slotted 330mm, AP brake pad, APF 404, brake hose dengan harga 29 jt dan 30,5 jt apabila red caliper.
    -CP 5040 race caliper 4 pot, AP discbrake floating slotted 330mm, AP brake pad APF 402, brake hose harga 36 jt.
    -CP 9040 black caliper 6 pot , AP disbrake 355mm floating slotted , AP brake pad APF 404, brake hose harga 36 jt dan 37,5 jt apabila red caliper.
    *dengan discbrake floating slotted 362mm harga 39 jt.
    **** BREMBO Made in ITALY ****
    -Brembo GT 4 pot,Br,brembo brake pad,brake hose with center bell plug & play alumunium and adaptor.
    *Dengan discbrake floating drilled 330mm harga 36 Jt.
    *Dengan floating drilled discbrake 355mm harga 39 Jt.
    *Dengan floating drilled discbrake 380mm harga 42 Jt.
    -BREMBO 17Z 6 pot,BREMBO brake pad,with center bell plug & play alumunium and adaptor dengan discbrake floating drilled 355mm harga 38 jt.
    -BREMBO 19Z 6 pot ,BREMBO brake pad with center bell plug & play alumunium , and adaptor dengan discbrake 380mm floating drilled harga 44 jt.
    **dengan floating drilled disbrake 380mm harga 46 jt.
    -BREMBO GT 6 pot.BREMBO brake pad GT,Brake hose with center bell plug n play alumunium dan adaptor.
    **Dengan Discbarake Floating Drillet 380 MM(Buat Velg Minimal 19 INCH ) Harga 50 Jt.
    -BREMBO REAR PORSCHE New CAYENNE Caliper (For Rear Use Only),Brembo Brake Pad With Discbrake 345MM Floating Drilled Harga 35 JT.
    **Discbrake 380Mm Floating Drilled HARGA 38 JT.
    -BREMBO 4POT Model 6 (For Rear use only ),BREMBO Brake Pad With Discbrake 345MM Floating Discbrake Harga 33 JT.
    **Discbrake 380MM Floating Drilled Harga 36 JT.
    For Order Call/Whatsapp:081382077777/085882077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    JAKARTA PUSAT 10150
  4. #14
    cipondoh-tangerang
    PROMO SPEED'Z PERFORMANCE DI BULAN JANUARY UNTUK PRODUCT DIBAWAH INI :
    HARGA APABILA PEMBELIAN PAKET HARGA MASIH BISA NEGO
    ARP BOLTS
    BMW:M42/44 HARGA 3.750 JT ,M50/52 HARGA 4.750 JT ,S50 HARGA 4.750 JT,M10 HARGA 3.750 JT
    HONDA:B18C GSR HARGA 3.2 JT ,B16A HARGA 3 JT, B20 WITH B16 HEAD HARGA 3.2 JT, D16Y HARGA 3 JT , D16 NON VTEC HARGA 3 JT ,-H22 HARGA 3.4 JT,-H23 HARGA 3.4JT,-K20 HARGA 3.5 JT,-R18 HARGA 4 JT,-L15 HARGA 4 JT
    MITSUBISHI
    -EVO 1-3 HARGA 3JT
    -EVO 4-9 HARGA 3 JT
    NISSAN
    -SR20 S13 HARGA 3.2 JT
    -SR20 S14/15 HARGA 3.2 JT
    -RB20/25 HARGA 4.750 JT
    -RB26 HARGA 4.750 JT
    SUBARU
    -EJ HARGA 3.5 JT
    TOYOTA
    -4AG HARGA 3 JT
    -3SGTE HARGA 3.2 JT
    -2JZGTE HARGA 4.750 JT
    -1NZFE HARGA 4 JT
    FLYWHEEL BOLT
    -HONDA D-SERIES HARGA 1.5 JT
    -HONDA B-SERIES HARGA 1.5 JT
    -TOYOTA 4AG HARGA 1.5 JT
    -TOYOTA 3SGTE HARGA 1.5 JT
    -MITSUBISHI EVO HARGA 1.5 JT
    WHEELS STUD
    -HONDA HARGA 1.5 JT/SET
    -MITSUBISHI HARGA 1.5 JT/SET
    -SUBARU HARGA 1.5 JT/SET
    -TOYOTA HARGA 1.5 JT/SET
    FASTENER ASSEMBLY LUBRICANT
    -20 OZ HARGA 800 RIBU
    POWER ENTERPRISE TIMMING BELT KEVLAR
    -BF211 SUBARU EJ20 HARGA 2.5 JT
    -BN211 NISSAN RB20/25/26 HARGA 2.2 JT
    -BT111 TOYOTA 4AGZE HARGA 2.250 JT
    -BT121 TOYOTA 4AGE/16 HARGA 2.250 JT
    -BT131 TOYOTA 4AG AE111 HARGA 2.250 JT
    -BT221 TOYOTA 3SG HARGA 2.4 JT
    -BT222 TOYOTA 3SGTE HARGA 2.350 JT
    -BT211 TOYOTA 1JZ HARGA 2.350 JT
    -BT311 TOYOTA 2 JZ HARGA 2.350 JT
    -BM211 MITSUBISHI 4G63 HARGA 2,4 JT
    -BH141 HONDA D16 SOHC HARGA 2.2 JT
    -BH121 HONDA B16 DOHC HARGA 2.2 JT
    -BH111 HONDA B18C DOHC HARGA 2.2 JT
    -BH211 HONDA H22 DOHC HARGA 2.2 JT
    -BH221 HONDA B20 DOHAC HARGA 2.4 JT
    PERMA COOL
    -19128 electric fan 8 inch harga 1.850 jt.
    -19122 electric fan 12 inch harga 2.150 jt .
    -19126 electric fan 16 inch harga 2.450 jt .
    -1010 transmision cooler kit for compact car harga 1.5 jt.
    -1011 transmission cooler kit for compact car harga 1.650 jt.
    -1012 transmission cooler kit for medium car harga 1.9 jt .
    -1013 transmission cooler kit for full size car harga 2 jt.
    -1300 heavy duty transmission coooler kit harga 2.150 jt.
    -69195 oil cooler kit universal remote system 200 hp for NA harga 3.750 jt .
    -10195 oil cooler kit universal with remote system 300 hp for turbo or modified NA engine harga 4.250 jt.
    TRANSGO
    -SK340 HARGA 2 JT
    -340-HD2 HARGA 2.5 JT
    -RE5R05A-HD2 HARGA 5.5 JT
    SUPERTECH
    -BLOCK GUARD D-SERIES HARGA 1.8 JT
    -BLOCK GUARD B20 HARGA 2 JT
    -VALVE SPRING TOYOTA 4AG16 VALVE HARGA 4.5 JT
    -VALVE OVERSIZE TOYOTA 4AG 16 VALVE HARGA 4.750 JT
    -VALVE OVERSIZE TOYOTA 4AG 20VALVE HARGA 6 JT
    -VALVE SPRING KIT NISSAN SR 20 DET HARGA 7 JT
    -VALVE OVERSIZE BMW M42/44 HARGA 7.5 JT
    -VALVE OVERSIZE BMW M50/52 HARGA 11.5 JT
    EXEDY CLUTCH
    -HONDA NEW JAZZ HARGA 6 JT
    -HONDA D17/D16 ESTILO HARGA 6 JT
    -HONDA D16 VTEC/FERIO HARGA 5 JT
    -MITSUBISHI EVO 1-3 HARGA 6.5 JT
    -MITSUBISHI EVO 7-9 HARGA 8.5 JT
    -MITSUBISHI MIRAGE 4G92/4G93 HARGA 5.750 JT
    -MAZDA BP 6 TURBO HARGA 4.5 JT
    -TOYOTA YARIS HARGA 5.5 JT
    -SUZUKI SWIFT HARGA 5 JT
    -SUBARU HARGA 7.5 JT
    SAFE BRAKE PRO RS
    NGK SPARK PLUG
    -IRIWAY 7/8/9 HARGA 1,1 JT/SET
    -IRIDIUM IX BKR6EIX-11 HARGA 550 RIBU/SET
    -IRIDIUM IX LFR6AIX-11 HARGA 550 RIBU/SET
    -IRIDIUM IX DCPR7EIX-11 HARGA 700 RIBU/SET
    -IRIDIUM LASER PLATINUM IZFR6-KIX HARGA 1,1 JT/SET
    PIVOT
    PERFORMANCE ANALYSIS
    -EXHAUST WRAP 1X50 FEET(VOLCANO WRAP) HARGA 750 RIBU
    -EXHAUST WRAP 2X50 FEET(VOLCANO WRAP) HARGA 950 RIBU
    -TURBO SHIELD (PEMBUNGKUS TURBO )T3 HARGA 2.2 JT
    -TURBO SHILED (PEMBUNGKUS TURBO )T4 HARGA 2.450 JT
    -TURBO SHIELD T3 +EXHAUST WRAP KIT HARGA 2.650 JT
    -TURBO SHIELD T4 +EXHAUST WRAP KIT HARGA 2.950 JT
    CP PISTON
    ISKY
    TOMEI
    COMETIC GASKET
    -HONDA HEAD GASKET D-SERIES HARGA 2.4 JT
    -HONDA HEAD GASKET B-SERIES HARGA 2.4 JT
    -HONDA HEAD GASKET H-SERIES HARGA 2.4 JT
    -HONDA HEAD GASKET K-SERIES HARGA 2.4 JT
    -NISSAN S13/S14/S15 HEAD GASKET HARGA 2.4 JT
    -NISSAN RB20/RB25/RB26 HEAD GASKET HARGA 3.5 JT
    -TOYOTA 4AG 16 VALVE/20 VALVE HEAD GASKET HARGA 2.4 JT
    -TOYOTA 3SGTE HEAD GASKET HARGA 2.4 JT
    -MITSUBISHI EVO 1-9 HEAD GASKET HARGA 2.4 JT
    -TOYOTA 4EFTE HEAD GASKET HARGA 2.4 JT
    -TOYOTA 2JZ HEAD GASKET HARGA 2.4 JT
    -TOYOTA 1UZ HEAD GASKET HARGA 4.5 JT
    -SUBARU EJ20/EJ25 HARGA 2.6 JT
    -BMW M40/42 HEAD GASKET HARGA 2.8 JT
    -MITSUBISHI EVO 4-8 OVERHAUL GASKET HARGA 5.750 JT
    MSD IGNITION
    -DIGITAL 6 AL HARGA 3.8 JT
    -7AL-3 HARGA 10 JT
    - D16 HARGA 4 JT
    -B16 HARGA 4.5 JT
    -H22 HARGA 5 JT
    DRIVESHAFTSHOP
    DC SPORT
    CUSCO STRUTBAR
    GREDDY
    ETC
    -GARRETH TURBO GT 28 AR.63 (CALL FOR PRICE)
    -SARD FUEL PRESS HARGA 1.650 JT
    -SKUNK2 ULTRA SERIES "STREET" INTAKE MANIFOLD PART NUMBER 307-05-0500 HARGA 7.5 JT
    DICARI DEALER LUAR KOTA UTK DISTRIBUSI DENGAN KERJASAMA DENGAN PEMBELIAN AWAL 200 JT DAN DEALER DENGAN PEMBELIAN AWAL 50 JT
    FOR ORDER CALL/WHATSAPP: 081382077777 / 085882077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    JAKARTA PUSAT10150
  5. #15
    cipondoh-tangerang
    M Sports Basic Kit
    his kit is required in addition to the front and rear M-Performance bumpers. Awesome Value which includes side skirts !
    for order call/whatsapp :081382077777 / 085882077777(hanz speedz)
  6. #16
    cipondoh-tangerang
    Auto Update promo January 2016 for Big Brake Kit AP RACING and BREMBO.
    We bring genuine big brake kit BREMBO and AP RACING ,we supply for INDONESIA and MALAYSIA market, many installation in customer car and dealer wanted.
    -CP7600 caliper 4 pot ,AP disbrake 295mm floating slotted ,AP brake pad APF 404,HEL Brake hose harga 24 jt(black caliper) dan harga 25,5 jt (red caliper ) applikasi utk velg 15-16 inch
    -CP 5200 caliper 4 pot , AP discbrake floating slotted 330mm, AP brake pad APF 404, HEL brake hose dengan harga 29 jt (black caliber) dan 30,5 jt (red caliper)applikasi utk velg 17 inch
    -CP 5040 race caliper 4 pot, AP discbrake floating slotted 330mm, AP brake pad APF 402, HEL brake hose harga 36 jt. applikasi utk velg 17 inch
    -CP 9040 caliper 6 pot , AP disbrake 355mm floating slotted , AP brake pad APF 404, HEL brake hose harga 36 jt (black caliper) dan 37,5 jt( red caliper) applikasi utk velg 18inch
    *dengan discbrake floating slotted 362mm harga 39 jt.applikasi utk velg 19 inch
    -Brembo GT 4 pot,brembo brake pad,brake hose with center bell plug & play alumunium and adaptor.
    *Dengan floating drilled discbrake 355mm harga 39 Jt.(velg minimal 18 inch)
    *Dengan floating drilled discbrake 380mm harga 42 Jt.(velg minimal 19 inch)
    -BREMBO 17Z 6 pot,BREMBO brake pad,with center bell plug & play alumunium and adaptor dengan discbrake floating drilled 355mm harga 38 jt.(velg minimal 18 inch)
    -BREMBO 19Z 6 pot ,BREMBO brake pad with center bell plug & play alumunium , and adaptor dengan discbrake 380mm floating drilled harga 44 jt.(velg minimal 19inch)
    **dengan floating drilled disbrake 405mm harga 46 jt. (velg minimal 20 inch)
    -BREMBO REAR PORSCHE New CAYENNE Caliper (For Rear Use Only),Brembo Brake Pad With Discbrake 345MM Floating Drilled Harga 35 JT.(velg minimal 18 inch)
    **Discbrake 380Mm Floating Drilled HARGA 38 JT.(velg minimal 19 inch)
    -BREMBO 4POT Model 6 (For Rear use only ),BREMBO Brake Pad With Discbrake 345MM Floating Discbrake Harga 33 JT.(velg minimal 18 inch)
    **Discbrake 380MM Floating Drilled Harga 36 JT.(velg minimal 19 inch)
    SPEEDZ PERFORMANCE
    JAKARTA PUSAT 10150
  7. #17
    cipondoh-tangerang
    SPEEDZ PERFORMANCE
    JAKARTA PUSAT 10150
  8. #18
    cipondoh-tangerang
    COMING IN STOCK FOR SUBARU BRZ OR TOYOTA FT86
    -CP PISTON LOW COMP
    -BC CONROD I-BEAM
    -ARP HEAD STUD
    -ARP MAIN STUD
    For info call/whatsapp :
    081382077777-085882077777(Hanz speedz)
    SPEEDZ PERFORMANCE
    Central Distributor Parts, Racing Supplies & Modification.
    Jalan biak no:48-48A,JAKARTA PUSAT10150
  9. #19
    cipondoh-tangerang
    ARP BOLTS
    MITSUBISHI
    -EVO 1-3 HARGA 3JT
    -EVO 4-9 HARGA 3 JT
    NISSAN
    SUBARU
    -EJ HARGA 3.5 JT
    TOYOTA
    -4AG HARGA 3 JT
    -3SGTE HARGA 3.2 JT
    -1NZFE HARGA 4 JT
    FLYWHEEL BOLT
    WHEELS STUD
    PERMA COOL
    TRANSGO
    -SK340 HARGA 2 JT
    SKUNK2
    -INTAKE MANIFOLD PRO FOR EVO 4-9 BLACK HARGA 9.750 JT
    -INTAKE MANIFOLD PRO FOR EVO 4-9 SILVER HARGA 9 JT
    -THROTTLE BODY FOR EVO 8-9 68MM BLACK HARGA 5.750 JT
    -THROTLE BODY FOR EVO 8-9 HARD ANODIZED/SILBER HARGA 5 JT
    SUPERTECH
    EXEDY CLUTCH
    SAFE BRAKE PRO RS
    NGK SPARK PLUG
    PIVOT
    CP PISTON
    ISKY
    TOMEI
    COMETIC GASKET
    MSD IGNITION
    -7AL-3 HARGA 10 JT
    - D16 HARGA 4 JT
    -B16 HARGA 4.5 JT
    -H22 HARGA 5 JT
    DRIVESHAFTSHOP
    DC SPORT
    CUSCO STRUTBAR
    GREDDY
    ETC
    SPEEDZ PERFORMANCE
    JAKARTA PUSAT10150
  10. #20
    cipondoh-tangerang
    Premium Cross-Drilled & Slotted Rotor Specifications
    Machined And Finished In Our USA Facility
    All Cross-Drilled and SLOTTED Brake Rotors are precision-machined and finished in our U.S. facility. Every rotor is inspected using the strictest quality control standards and checked for compliance with factory dimensional specifications. Our rotors are manufactured from premium-quality cast iron that meets or exceeds G3000/ISO9002,QS9000/VDA 6.1 specifications. Each rotor is double-disc ground and machine-mill balanced for optimal high-performance operation. We are so confident about the quality of our products that we offer the best warranty anywhere!
    Performance Full Curve Slot Design
    Each Performance Full Curve Slot is strategically machined off the edge of the rotor to dramatically improve braking performance by up to 30% over factory STOCK brake rotors. Our slot design removes water, dust, and debris whilst minimizing the heating of the pad surface. Slots that are machined in the center of the pad surface are inefficient and only collect dust. The edges of our slots are machine-rounded to achieve maximum degassing and dust removal.
    Chamfered Cross Drilled Holes
    Each Cross-Drilled hole is perfectly sized to allow for maximum ventilation without structurally weakening the brake rotors. Cross-Drilled Holes move air from the pad surface whilst reducing surface temperature, eliminating hot spots and warping. Each drilled hole is chamfered to eliminate stress cracks, as well as to provide long-lasting performance.
    Zinc Plating In Black or Silver
    Our Performance Rotors are Zinc Coated in Black or Silver. The Zinc Coating Process is an extensive hand-applied operation that is not sprayed on like inferior coatings. Each Performance Brake Rotor is immersed in different solution tanks throughout the coating process. The final result is a thick protective coating that will help prevent rusting and give you a great custom look.
    Guaranteed Fit And Installation
    Brake Performance Cross-Drilled and SLOTTED Brake Rotors are machined to the same fit and dimensions as your factory brake rotors. You can install them with no worries about factory fit or function. We recommend that you have a certified mechanic install them for proper break-in procedure. If you have any questions or need assistance choosing the correct brake rotor for your vehicle. We include detailed installation instructions and break-in procedures with every kit.
    Vehicle Recommendations
    Cross-Drilled and Slotted Brake Rotors are ideal for all domestic and foreign light and medium-duty Trucks, Cars and SUVs. They are ideal for all performance vehicles and European vehicles, as well as any vehicle experiencing warped brake rotors due to excessive heat. Cross- Drilled and Slotted rotors can be used for truck applications, but we recommend the Dimpled and Slotted Rotors because of their SUPERIOR rotor strength. See our comparison chart for application advantages between the different types of rotors
    Photo Disclaimer - The Product Photo is for display purposes only. Actual product may vary in size and bolt pattern. After you select your vehicle, click on the part number to see the actual dimensions.
    FOR INFO ORDER/APPLICATION
    SPEEDZ PERFORMANCE
    SPEEDZ PERFORMANCE
MBtech Venom 300x250
  1. ++PROMO BIG BRAKE KIT AP RACING AND BREMBO++
    By [speed'Z] in forum Diskusi Mesin
    Last Post: 15th October 2015, 22:48
  2. ++++PROMO BIG BRAKE KIT AP RACING AND BREMBO++++++
    By [speed'Z] in forum Diskusi Kaki-Kaki
    Last Post: 11th October 2015, 04:10
  3. BARU SPEEDZ PERFORMANCE RACING SUPPLIEST N STOCKIEST FOR BIG BRAKE KIT AP RACING
    By [speed'Z] in forum Jual Beli Mesin Lainnya
    Last Post: 17th December 2013, 14:46
  4. wts : big brake kit ap racing
    By bocile in forum Bursa Kaki Lainnya
    Last Post: 19th March 2012, 09:31
  5. FS: BBK [Big Brake Kit] AP Racing 6pot
    By Honda in forum Per & Shockbreaker
    Last Post: 24th December 2010, 23:34
