UPDATE PROMO BIG BRAKE KIT AP RACING AND BREMBO
Results 1 to 10 of 74
  • Short URL:  http://modifika.si/622231
    cipondoh-tangerang
    5 Mths 3 Wks 13 Hrs 41 Secs
    +++++Update Promo big brake kit Ap racing and Brembo+++++
    We bring genuine big brake kit brembo and AP racing,we supply for INDONESIA and MALAYSIA market and many installation in customer car.
    __-AP Racing made in UNITED KINGDOM -__
    *New RADI-CAL(New Design)*
    -CP 8520 new RADI-CAL caliper 6 pot ,AP discbrake 355 Mm floating slotted ,AP brake pad APF 404,AP brake hose harga 40 jt (black) dan harga 41,5 JT (red)
    *AP discbrake 362 mm floating Slotted 43 Jt.
    *AP discbrake 380Mm floating Slotted 46 JT.
    -CP 8530 new RADI-CAL caliper 4 pot,AP discbrake 330mm floating slotted , AP brake pad APF 404. AP brake hose harga 33jt (Black) dan harga 34,5 jt(Red)
    *AP discbrake 345mm floating slotted harga 36jt.
    *AP discbrake 355mm Floating slotted harga 39 jt.
    -CP7600 black caliper 4 pot , AP disbrake 295mm floating slotted .AP brake pad APF 404 .Brake hose harga 25 jt.
    -CP 5200 black caliper 4 pot , AP discbrake floating slotted 330mm, AP brake pad, APF 404, brake hose dengan harga 29 jt dan 30,5 jt apabila red caliper.
    -CP 5040 race caliper 4 pot, AP discbrake floating slotted 330mm, AP brake pad APF 402, brake hose harga 36 jt.
    -CP 9040 black caliper 6 pot , AP disbrake 355mm floating slotted , AP brake pad APF 404, brake hose harga 36 jt dan 37,5 jt apabila red caliper.
    *dengan discbrake floating slotted 362mm harga 39 jt.
    **** BREMBO Made in ITALY ****
    -Brembo GT 4 pot,Br,brembo brake pad,brake hose with center bell plug & play alumunium and adaptor.
    *Dengan discbrake floating drilled 330mm harga 36 Jt.
    *Dengan floating drilled discbrake 355mm harga 39 Jt.
    *Dengan floating drilled discbrake 380mm harga 42 Jt.
    -BREMBO 17Z 6 pot,BREMBO brake pad,with center bell plug & play alumunium and adaptor dengan discbrake floating drilled 355mm harga 38 jt.
    -BREMBO 19Z 6 pot ,BREMBO brake pad with center bell plug & play alumunium , and adaptor dengan discbrake 380mm floating drilled harga 44 jt.
    **dengan floating drilled disbrake 380mm harga 46 jt.
    -BREMBO GT 6 pot.BREMBO brake pad GT,Brake hose with center bell plug n play alumunium dan adaptor.
    **Dengan Discbarake Floating Drillet 380 MM(Buat Velg Minimal 19 INCH ) Harga 50 Jt.
    -BREMBO REAR PORSCHE New CAYENNE Caliper (For Rear Use Only),Brembo Brake Pad With Discbrake 345MM Floating Drilled Harga 35 JT.
    **Discbrake 380Mm Floating Drilled HARGA 38 JT.
    -BREMBO 4POT Model 6 (For Rear use only ),BREMBO Brake Pad With Discbrake 345MM Floating Discbrake Harga 33 JT.
    **Discbrake 380MM Floating Drilled Harga 36 JT.
    For Order Call/Whatsapp:081382077777/085882077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    JALAN BIAK NO 48-48A
    JAKARTA PUSAT 10150
    www.speedzperformance.com
    http://www.facebook.com/speedzperformance
    cipondoh-tangerang
    SPEEDZ PERFORMANCE
    JAKARTA PUSAT 10150
    cipondoh-tangerang
    SPEEDZ PERFORMANCE
    JAKARTA PUSAT 10150
    cipondoh-tangerang
    SPEEDZ PERFORMANCE
    JAKARTA PUSAT 10150
    cipondoh-tangerang
    SPEEDZ PERFORMANCE
    JAKARTA PUSAT 10150
    cipondoh-tangerang
    SPEEDZ PERFORMANCE
    JAKARTA PUSAT 10150
    cipondoh-tangerang
    **BEST DEAL GENUINE AP RACING BIG BRAKE KIT FOR NOVEMBER**
    We bring genuine big brake kit AP racing,we supply for INDONESIA and MALAYSIA market and many installation in customer car.
    -CP 8520 new RADI-CAL caliper 6 pot ,AP discbrake 355 Mm floating slotted (min velg 18inch),AP brake pad APF 404, Hel brake hose harga 40 jt (black caliper ) dan harga 41,5 JT (red caliper),
    *AP discbrake 362 mm floating Slotted 43 Jt (min velg 19inch),
    *AP discbrake 380Mm floating Slotted 46 JT(min velg 19inch full).
    -CP 8530 new RADI-CAL caliper 4 pot,AP discbrake 330mm floating slotted (min velg 17inch), AP brake pad APF 404. Hel brake hose harga 33jt (Black caliper) dan harga 34,5 jt(Red caliper),
    *AP discbrake 345mm floating slotted harga 36 jt(min velh 18inch),
    *AP discbrake 355mm Floating slotted harga 39 jt(min velg 18inch full).
    -CP7600 black caliper 4 pot , AP disbrake 295mm floating slotted (min velg 16inch) ,AP brake pad APF 404 ,Hel Brake hose harga 25 jt(black caliper) dan harga 26,5 jt(red caliber).
    -CP 5200 black caliper 4 pot , AP discbrake floating slotted 330mm(min velg 17 inch), AP brake pad, APF 404, brake hose dengan harga 29 jt (black caliper) dan 30,5 jt (red caliper).
    -CP 5040 race caliper 4 pot, AP discbrake floating slotted 330mm(min velg 17 inch), AP brake pad APF 402, brake hose harga 36 jt (titanium colour).
    -CP 9040 black caliper 6 pot , AP disbrake 355mm floating slotted (min velg 18 inch), AP brake pad APF 404, Hel brake hose harga 36 jt (black caliber) dan 37,5 jt apabila (red caliper),
    *dengan discbrake floating slotted 362mm harga 39 jt(min velg 19 inch).
    GENUINE BIG BRAKE KIT BREMBO MADE IN ITALY
    We bring genuine big brake kit Brembo ,we supply for INDONESIA and MALAYSIA market and many installation in customer car.
    -Brembo GT 4 pot(grand turismo), Brembo brake pad, brake hose with center bell plug & play alumunium and adaptor.
    *Dengan discbrake floating drilled 330mm harga 36 Jt (min velg 17 inch),
    *Dengan floating drilled discbrake 345mm harga 38 Jt (min velg 18 inch)
    *Dengan floating drilled discbrake 355mm harga 39 Jt (min velg 18 inch full)
    *Dengan floating drilled discbrake 380mm harga 42 Jt(min vekg 19 inch)
    -BREMBO 17Z 6 pot, Brembo brake pad, Brake hose with center bell plug & play alumunium and adaptor dengan Brembo discbrake floating drilled 355mm harga 38 jt(min velg 18 inch).
    -BREMBO 19Z 6 pot ,BREMBO brake pad with center bell plug & play alumunium , and adaptor dengan floating drilled disbrake 380mm harga 46 jt (min velg 19 inch)
    -BREMBO GT6 pot (grand turismo) , Brembo brake pad GT, Brembo Brake hose with center bell plug n play alumunium dan adaptor.
    **Dengan discbrake floating drilled 355mm harga 48 Jt(min velg 18 inch),
    **Dengan Discbarake Floating Drillet 380mm Harga 50 Jt(min velg 19 inch),
    **Dengan Discbrake Floating Drilled 405Mm Harga 52 Jt(min velg 20 inch).
    -BREMBO REAR PORSCHE New CAYENNE Caliper (For Rear Use Only),Brembo Brake Pad and brembo brake hose With Discbrake 345MM Floating Drilled Harga 35 JT(min velg 17 inch),
    **Discbrake 380Mm Floating Drilled HARGA 38 jt(min velg 18 inch).
    -BREMBO 4POT Model 7AL6 (For Rear use only ),BREMBO Brake Pad and brembo brake hose With Discbrake 345MM Floating Discbrake Harga 33 JT(min velg 18 inch),
    **Discbrake 380MM Floating Drilled Harga 36 jt(min velg 19 inch).
    SPEEDZ PERFORMANCE
    JAKARTA PUSAT 10150
    cipondoh-tangerang
    SPEEDZ PERFORMANCE
    JAKARTA PUSAT 10150
    cipondoh-tangerang
    Tempat baru di tengah jakarta Speed'Z Cafe and Lounge menggunakan 3 konsep untuk ikon pertama yang membuat tempat cozzy untuk anda datangkan beserta dengan hidangan makanan yg menggugah selera indonesia food,oriental food dan western food.
    apakah anda susah mendapatkan beer premium?.di Speed'Z Cafe and Lounge kami menyiapkan semua beer premium yg selama ini susah anda dapatkan di daerah jakarta pusat. (Corona, Hoegarden, Budweiser, Stella Artois, Leffe Blonde, Erdinger, Sweet touch flavour, Diablo, Kilkeny).
    bosen dengan suasana cafe yg biasa saja?. kita menyediakan 9 Dart Machines game by Phoenix korea.(jadi anda bisa bermain online dart sendiri ataupun bermain dengan teman2 anda).
    tema di outdoor adalah 4 bangku dengan pesanan khusus yg besar untuk anda bersantai dilengkapi dengan BMB sound system dan projector LCD infocus.
    indoor lantai 1 dilengkapi dengan tema kayu diperuntukan untuk anda makan dan bersantai dengan support wi-fi yg super cepat berserta TV led 50 inch dengan sound system BMB.
    indoor lantai 2 dilengkapi dengan 3 sofa yg bisa membuat anda nyaman didukung dengan lounge dan DJ booth dengan sound system BMB lengkap dengan subwoofer yg membawa suasa santai,lengkap dengan live band(diadakan bila ada event dari sponsor).,projector big LCD monitor by infocus.
    kalau ingin bernyanyi kita menyediakan VIP room hanya ada 1 aja dengan harga 150K++/jam dan minimum pemakaian 2 jam atau dengan pilihan ke dua dengan mimium charge 1.5 juta (makanan dan minuman) sepuasnya dengan kapasitas room 8 orang maximal.
    cheers:
    Speedz Cafe and Lounge
    Jalan Biak no 48-48a
    Jakarta pusat 10150.
    for rsv: 08111776937-02199199777
    www.speedz-beerhouse.com
    cipondoh-tangerang
    BEST DEAL GENUINE BREMBO BIG BRAKE KIT FOR DECEMBER
    (DAPETKAN HARGA KHUSUS BUAT BULAN DESEMBER DAPETKAN HARGA PROMO)
    We bring genuine big brake kit BREMBO,we supply for INDONESIA and MALAYSIA market and many installation in customer car.
    -BREMBO 17Z 6 pot, Brembo brake pad, Brake hose with center bell plug & play alumunium and adaptor dengan Brembo discbrake floating drilled 355mm harga 37 jt(min velg 18 inch).
    -BREMBO 19Z 6 pot ,BREMBO brake pad with center bell plug & play alumunium , and adaptor dengan floating drilled disbrake 380mm harga 45 jt (min velg 19 inch)
    **Dengan discbrake floating drilled 355mm harga 47 Jt(min velg 18 inch),
    **Dengan Discbarake Floating Drillet 380mm Harga 49 Jt(min velg 19 inch),
    **Dengan Discbrake Floating Drilled 405Mm Harga 51 Jt(min velg 20 inch).
    -BREMBO REAR PORSCHE New CAYENNE Caliper (For Rear Use Only),Brembo Brake Pad and brembo brake hose With Discbrake 345MM Floating Drilled Harga 344 JT(min velg 17 inch),
    -BREMBO 4POT Model 7AL6 (For Rear use only ),BREMBO Brake Pad and brembo brake hose With Discbrake 345MM Floating Discbrake Harga 32 JT(min velg 18 inch),
    DICARI DEALER UNTUK LUAR KOTA DAN TEAM MOBIL UNTUK KERJASAMA DAN SUPPORT UNTUK TEAM BALAP.
    SPEEDZ PERFORMANCE
    JAKARTA PUSAT 10150
GT Radial NGK Busi
  1. ++PROMO BIG BRAKE KIT AP RACING AND BREMBO++
    By [speed'Z] in forum Diskusi Mesin
    Last Post: 15th October 2015, 22:48
  2. ++++PROMO BIG BRAKE KIT AP RACING AND BREMBO++++++
    By [speed'Z] in forum Diskusi Kaki-Kaki
    Last Post: 11th October 2015, 04:10
  3. BARU SPEEDZ PERFORMANCE RACING SUPPLIEST N STOCKIEST FOR BIG BRAKE KIT AP RACING
    By [speed'Z] in forum Jual Beli Mesin Lainnya
    Last Post: 17th December 2013, 14:46
  4. wts : big brake kit ap racing
    By bocile in forum Bursa Kaki Lainnya
    Last Post: 19th March 2012, 09:31
  5. FS: BBK [Big Brake Kit] AP Racing 6pot
    By Honda in forum Per & Shockbreaker
    Last Post: 24th December 2010, 23:34
