bgus ndak spek power spt ini?
Results 1 to 10 of 24
  • Short URL:  http://modifika.si/6148
    jak bar
    8 Hrs 19 Mins 2 Secs
    - 4x200watts + 1x400watts max output power
    -5ch power amplifier
    -2ohm stable
    -bass & teble boost circuit
    - electronic protective circuit against short circuiting dc offset and excess temperature
    kijang merah ceper
    ya boleh lah hehehehehheehhhehe
    Jakarta - Singapore
    8 Hrs 28 Mins 32 Secs
    hehehehehehehehehe....
    pusink juga kalo info nya cuma segini...
    tapi lebih baik dengerin ajah dulu...
    Keep Smiling..!! Be Happy..!!
    8 Hrs 10 Mins 4 Secs
    wuuiiihhs.....power gajah nih. hehehehhehehehehe.....
    Berapa ohm tuh segitu watt nya??
    nah kalau ini?
    2x 130 Watts @ 4 ohm dengan harga 75 jt?
    jak bar
    Quote Originally Posted by BP
    iye spek nya kaya begini tapi merk kayanya ndak terkenal gitu merk " Johnnie Monitor" (JM)
    - 4x200watts + 1x400watts max. Output power
    - 2 OHM Stable
    - 5 CH Power Amplifier
    - Bass & Treble boost circuit
    - Infinitely adjustable high-pass and low-pass filter
    - Electronic protective circuit against short circuiting dc offset and excess temperature
    - Mute Switch for suppressing switch-on crackle interference
    - High efficiency mosfet power supply
    - power on & protection led indicators
    - Automatic switching on/off via car radio
    - Extra Heavy heatsink for better heat dissipation
    [/img][/list]
    gak semua yang lo denger itu bener , starburst cuma lu yang tau..... (jadi iklan deh gw)
    Manado
    11 Hrs 10 Mins 15 Secs
    Quote Originally Posted by abuncil
    - 2 OHM Stable
    [/img][/list]
    mending jgn deh
    kijang merah ceper
    hahahahahahahhahahahahahhahahaha
    birend
    hehehe.. mosting power JM itu yang buat avanza ya..
    kan udah dibeli.. ya enjoy aja..
  1. Tanya Spek Power
    By optimusprime in forum Diskusi Power Amplifier
    Last Post: 29th May 2011, 15:07
  2. (WTA) MAW NANYA POWER OPTIMA 3000D bgus gk?
    By hoe in forum Diskusi Power Amplifier
    Last Post: 24th April 2010, 23:00
  3. Replies: 8
    Last Post: 12th April 2010, 22:49
  4. tnya spek gw ini bgus ga??
    By blinkz in forum Diskusi Instalasi
    Last Post: 24th April 2008, 22:58
  5. pengen korek power dmana ya yg bgus?
    By sukiyaki in forum Diskusi Power Amplifier
    Last Post: 4th July 2007, 00:45
