Luxman CM-6000
Results 1 to 10 of 24
Thread: Luxman CM-6000
  • Short URL:  http://modifika.si/61048
    Batavija
    9 Hrs 14 Mins 30 Secs
    Luxman CM-6000
    iseng ni
    ada yg punya or ada yg pernah denger blm?
    jadi ga cuma bodykit n velg look JDM, tp audio juga ga mau kalah donk, makin JDM bleh
    PangkaL Paha
    2 Wks 5 Days 2 Hrs 7 Mins 58 Secs
    pernah liad di pasang di eloysion ..
    keren pak..
    Batavija
    Quote Originally Posted by b2okane View Post
    keren pak..
    seri ini??
    gile dmane tuh?
    elysion sape bro?
    PangkaL Paha
    luxman pokoknya..
    gatau seri apa...
    Batavija
    luxman pokoknya..
    gatau seri apa...
    ini seri lama bro, gedenya ampir sama ma mc4000 kayanya
    panjang n berat gitu deh
    nyoo_hks@yahoo.co.id
    bantuin gambarnya.. sory klo salah..
    Attachment 27048
    Attachment 27049
    Attachment 27050
    Attachment 27096
    Features Luxman's high-class CM-6000 (50W watts x 6) car audio power amplifier. Treble quality is actualized under various audio environment, the 50W 6 channel power amplifier gives you powerful bass, high quality sound and sharpens the sound. Independence volume loading 200W 3 channel also use of bridging connection Specifications Continual effective ability:50W x6ch(4ohms), 200W x3ch(4ohms,MONO) Input impedance:NORMAL(LOW), 0.5V/20K ohms(HIGH), 2.0V/3.1Kohms, DIRECT 0.5V/25K ohms S/N ratio:Above 105dB (IHF-A revision and input short circuit and DIRECT) Total harmonic wave distortion: 0.005% or less (4 ohms, 1kHz and DIRECT) / 0.008 Below (4 ohms, 20 - 20,000 Hz DIRECT) Frequency characteristic: 20 - 20,000Hz (+ 0, - 0.2dB and DIRECT) / 5 - 100,000Hz (+ 0, 0.2dB and DIRECT) Damping factor: 100 or more (4ohms, 1kHz and DIRECT) Battery voltage: DC12V Electric power consumption: 27.6W (2.6A, signalless) 552W (46.0A, 4ohms, rated output) Size: 670W x 76H x302D mm Weight: 12.6kg (substance
    Singapore
    2 Wks 23 Hrs 29 Mins 1 Sec
    Dahsyat neh power keren banget kabel nya di bungkus gitu mantap..
    P01RS / FA3FR / ABYSS NOBELLA PROJECT X / FA3 SUB /SR TESLA SERIES
    SQ ENTHUSIAST
    http://www.modifikasi.com/showthread...R-FUN-By-SQ_UP
    Batavija
    thnx bro HKSsound
    lbh nice lg kalo mau ngasih gue
    hehehe kayaknya emang power mantab nih
    thanks cendolnya .. bonus speseifikasi ama pic hasil klo dipasang di mobil .
    gambar saya ambil dr int juga..
    PangkaL Paha
    Quote Originally Posted by HKSsound View Post
    diem2 ada transaksi cendol bawah tanah nih
  1. FS : LUXMAN CM 4000 & LUXMAN CM 4050
    By D7755 in forum Power Amplifier
    Last Post: 10th January 2013, 21:06
  2. wts HID intersys H1 6000 K, & H11 6000 K
    By 189 in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 27th May 2012, 09:18
  3. WTT - Luxman CM-6000 ama power dibawahnya
    By malv16 in forum Power Amplifier
    Last Post: 22nd May 2011, 23:10
