AEM 21-699C Cold Air Intake
AEM Cold Air Intake System
5.0 ( 3 reviews )
Increased horsepower
Tuned and dyno-tested to improve acceleration and engine sound
Low restriction aluminum tubing
Easy to install using commonly available tools
Air filter lasts up to 100,000 miles before cleaning is required (depending on driving conditions)
Washable and reusable oil-free filter media
AEM Lifetime Limited Warranty
The AEM 21-699C Performance Cold Air Intake System produces horsepower and torque gains by replacing your vehicle’s restrictive factory air filter and air intake housing. This air intake system was designed, tuned and dyno-tested to fit specific Mini Cooper S and S Clubman models. Air enters the system through an oversized AEM Dryflow synthetic washable air filter for outstanding air flow, filtration and performance. The air filter is protected by a heat shield and a replacement air box with a fully opened hood scoop which is designed to reduce intake air temperature and increase horsepower. The intake tubing is constructed from mandrel-bent aluminum featuring a durable gunmetal gray powder coated finish. This air intake system was developed to accommodate the engine’s factory emissions control devices including the mass air flow sensor as well as a replacement AEM filter minder gauge. The cylinder shaped AEM Dryflow air filter is made from an oil-free, synthetic filter media that can be used for up to 100,000 miles before cleaning is needed (depending on driving conditions). The air intake system is backed by AEM's Lifetime Limited Warranty. Some AEM air intakes are not legal for sale or use in California and other states adopting California emission standards while others are 50 state legal. View the 21-699C vehicle applications to determine the legal status for each vehicle.
[More Information on AEM Cold Air Intake Systems]
AEM 21-699C Product Specifications
Estimated Horsepower Gain 14.14 HP @ 5400 RPM
Air Filter Color Red
Air Filter Height 7.5 in (191 mm)
Air Filter Material Non-woven Synthetic
Air Filter Outlet Shape Round
Clamp Material Stainless Steel
Clamp Style Regular
Clamps Included 5
Color Gunmetal Gray
Couplers Included 1
Intake Pipe Color / Finish Gunmetal Gray
Mounting Hardware Included Yes
Product Box Height 16.75 in (425 mm)
Product Box Length 24.38 in (619 mm)
Product Box Width 18.38 in (467 mm)
Product Style AEM Cold Air Intake System
Replacement Filter 21-2027D-HK
Street Legal In All US States Yes
TUV Approved (Europe) No
Weight 12.2 lb (5.5 kg)
Horsepower gains based on similar vehicle dynamometer test. Results will vary.
2010 MINI COOPER S CLUBMAN 1.6L L4 F/I - w/Mass Air Street Legal In All US States: Yes
CARB EO Number: D-670-21 TUV Approved (Europe): No
2010 MINI COOPER S 1.6L L4 F/I - w/Mass Air Street Legal In All US States: Yes
2009 MINI COOPER S 1.6L L4 F/I - w/Mass Air Street Legal In All US States: Yes
2008 MINI COOPER S 1.6L L4 F/I - w/Mass Air Street Legal In All US States: Yes
2007 MINI COOPER S 1.6L L4 F/I - w/Mass Air Street Legal In All US States: Yes
FOR ORDER
SPEEDZ PERFORMANCE
JALAN BIAK NO 48-48A
JAKARTA PUSAT 10150
081382077777(HANZ SPEEDZ)
