Baru LED Indikator Volt, Suhu, Jam, dan Tanggal 4 in 1 untuk Mobil Anda
Results 1 to 10 of 10
  • Short URL:  http://modifika.si/605563
    16 Hrs 39 Mins 55 Secs
    LED Digital Car Clock, Voltmeter, Thermometer, and Date Automobile Electronic 12V Supply.
    HARGA Rp 150.000/pcs.
    1.Function :
    This car clock can show: Time \Date \Temperature \Voltage
    Five kinds of display Mode:
    1. Only display Time
    2. Only display Date
    3. Only display Temperature
    4. Only display Voltage
    5. Four kinds of display mode Loop displays
    2.Power :
    This car clock can be connected to the car 12V power supply,or connected to the cigarette lighter
    3.Settings
    There are two small buttons on the car clock
    Press the left button to select the item to be adjusted (number will blink),then press the right button to adjust the number
    In normal display mode,press the right button switch the display mode:1 -2 -3 -4 -5
    4.Save the settings
    After the car turned off,the car clock will continue working,If turned off the power,the car clock has a button batteries used to save settings
    www.GPmotorindo.com
    Your Automotive Solution
    Telp / SMS / WA : 0812 8888 2007
    Pin BB : 2AEC2C5E, 2B15D293
    Email : Temmy.hartadi@gmail.com
    Website : www.GPmotorindo.com
    PT.Gelora Perkasa Mandiri
    PERUMAHAN HARAPAN INDAH 2
    CLUSTER TAMAN SARI, BLOK HN5 No.35
    BEKASI UTARA.
    PROSES PEMESANAN:
    TENTUKAN JENIS SPARE PART DENGAN VIA:
    TELEPON 021-88882007
    SMS 081288882007
    EMAIL TEMMY.HARTADI@Gmail.com
    PM PRIVATE MASSAGE
    Pin BB 2B15D293
    CANTUMKAN NAMA, NOMOR TELEPON, ALAMAT PENGIRIMAN ANDA
    KUNJUNGI WEBSITE KAMI
    www.GPmotorindo.com
    Untuk konsultasi dan tanya jawab bisa langsung ke Yahoo Mesengger saya di Bopaxs_abzz007@yahoo.com
    Selamat Siang
  1. Replies: 660
    Last Post: 25th June 2015, 20:15
  2. Ask Velg dan Ban 18" untuk mobil Yaris
    By tenten in forum Diskusi Kaki-Kaki
    Last Post: 29th May 2015, 23:40
  3. ASK : Mencegah dan Mengatasi Semut Di Mobil Anda
    By Si_CuPuee in forum Diskusi Interior
    Last Post: 14th August 2012, 13:01
  4. JUAL Rollbar dan Tanduk Depan Untuk Mobil Double Cabin ! ! [BDG]
    By alekecil in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 11th March 2010, 07:59
  5. JUAL Rollbar dan Tanduk Depan Untuk Mobil Double Cabin ! ! [BDG]
    By alekecil in forum Bursa Eksterior Lainnya
