Seas Lotus RS165/1 just arrived
Results 1 to 10 of 27
  • Short URL:  http://modifika.si/60553
    www.belanjaaudio.com
    8 Hrs 12 Secs
    The Reference set RS165F is a High End mobile audio separate speaker kit with tremendous details and power.
    http://belanjaaudio.com/product.php?by=brand&view=Seas
    Woofer RW165/1
    * Heavy copper rings mounted above and below the T-shaped pole piece, to reduce non linear and modulation distortion and to increase overload margin.
    * Precision cast and surface treated magnesium cone, acting like a piston. Worldwide, SEAS is the only manufacturer to offer this technology.
    * Black anodised aluminium voice coil former for increased power handling.
    * H2 lead out wire for reduced resonances and roping problems.
    * A solid brass phase plug/satin chrome surface enhances the performance of the copper rings and improves heat conduction away from the pole piece.
    * Extremely stiff and stable injection moulded metal basket to keep the critical components in perfect alignment.
    * Magnet system with bumped back plate makes room for extreme coil excursions.
    * Rubber cup around the magnet system for protection and reducing enclosure refl ections.
    * Gold plated terminals mounted on a stiff glass fi bre reinforced plate to reduce contact resistance and improve reliability.
    Tweeter RT27F
    * An optimally shaped 27mm diaphragm which gives well-controlled behaviour through the entire high frequency band. This diaphragm is produced from SONOTEX, a proprietary material developed and manufactured only by SEAS.
    * The SONOTEX process pre-coats the fabric 4 times with a damping/sealing material, resulting in excellent acoustic performance and consistency.
    * New modern front plate with wider mounting diameter.
    * A substantial injection-moulded rear chamber, with complex internal shape and reinforcing ribs, which eliminate unwanted chamber resonances and refl ections and improve heat transfer.
    * Low viscosity magnetic fl uid which provides excellent cooling of the voice coil while maintaining a low resonance frequency. Efficient neodymium magnet system
    Crossover RX2,5L RX2,5H
    * Low crossover frequency for optimal stereo image.
    * Hand selected electronic parts with strict tolerances and highest quality.
    * 2 unit network for easy placement in cars.
    * Tweeter adjustable
    * Side open boxes for best cooling.
    * Boxes easy to disassemble for easy service and if desirable to use print boards without boxes if limited space for placement.
    * Rugged terminals for use with high quality cables.
    * Air core inductors for low loss resistance.
    * True 6 dB plus notch fi lter and true 12dB high-pass with 3 step tweeter adjustment.
    Online Shopping For Car Audio & Video
    Latest news on BelanjaAudio.Com , visit our thread
    http://www.modifikasi.com/forumdisplay.php?f=190
    Showroom : Jl. Mayjen Sungkono 176 - 178 , Ruko Grand Sungkono B-3 , Surabaya
    Call/SMS @ 081 856 0866, YM: infobelanja@yahoo.co.id, FB: www.facebook.com/belanja.audio
    PangkaL Paha
    2 Wks 5 Days 2 Hrs 40 Mins 54 Secs
    weks keren nih kyaknya..
    ditunggu review yg udah make dahhh
    5 Days 4 Hrs 55 Mins 23 Secs
    Tweeternya dijual sendiri aja bos, diganti R7000!
    Sorry, narsis modenya ga bisa di-off-kan. :smt003
    JOIN THE UnSCAC'S!!!!
    New Avexis FU6s on:
    E-MAIL: unscac@yahoo.com
    Whatsapp, Cell : 082141139097
    Line: Hwely
    Please DON'T sent via PM!!!
    8 Hrs 12 Secs
    Bos , kalau dijual terpisah , sarung tangannya Seas ikut tweeter atau midbass nya ?
    Quote Originally Posted by belanjaaudio View Post
    Ikut kamu lha, katanya bagus? potong 300rb deh.
    New Avexis FU6s on:
    Line: Hwely
    8 Hrs 12 Secs
    Bos Unscac , sarung tangan itu penting terutama untuk tweeter mahal yang warnanya silver
    entar kalau kena bolot , dikira jual R7000 2nd ????
    Enggak apa-apa bos, kalau ada bolotnya aku hapus pake penghapus steadler, enggak sampe 3rb sebiji, daripada beli sarung 300rb. Kasih U aja deh,
    New Avexis FU6s on:
    Line: Hwely
    8 Hrs 15 Mins 36 Secs
    koq pakai sarung tangan?mao bedah ato mao nyemir rambut?
    PangkaL Paha
    Quote Originally Posted by hardedge99 View Post
    mo rally kali pak....
    14 Hrs 14 Mins 25 Secs
    one word wowwwwwwwwwwwww
    suaranya kyk apa yak?
NGK Busi
  1. Replies: 1
    Last Post: 29th July 2012, 21:00
  2. Seas Lotus RS165/1 On Sale
    By belanjaaudio in forum Diskusi Speaker
    Last Post: 11th May 2010, 17:35
  3. Replies: 15
    Last Post: 21st February 2010, 18:39
  4. WTA speaker-nobelium 6.2 vs mp5 vs seas lotus rs165/1
    By tony10121986 in forum Diskusi Speaker
    Last Post: 19th January 2010, 18:57
  5. tanya pendapat seas lotus reference dengan seas excel
    By robert in forum Diskusi Speaker
    Last Post: 13th September 2006, 22:20
