Bekas JUAL Power amp Audison LR250 & MMATS 2100
Results 1 to 8 of 8
  • Short URL:  http://modifika.si/592163
    16 Hrs 15 Mins 27 Secs
    Location : Jakarta. Contact : 0818 76 11 92 (whatsapp, sms, call)
    WTS used masing2 1 unit :
    Power amp Audison LR250 SUPERCURRENT 2ch, Rp 2,75jt.
    FEATURES Supercurrent series : Two-channels amplifiers with compact
    dimensions and excellent musical performances.
    The outstanding features of their sophisticated circuitry are: "FRONT END" stages
    realised with two complementary differential stages, polarized by two low noise constant
    current sources.
    The final stage configuration is made of an inverted triplet at pure symmetry.
    The power amplifier is realized by a parallel of transistors with current capacity of 15
    Amperes each. The PWM MOSFET power supply has been particularly designed to supply
    the amplification stages with high currents. These features allow to drive very low loads.
    In fact this series of amplifiers has been called Supercurrent for their easiness in driving
    loads with 1 Ohm nominal impedance when they are connected in stereo and 2 Ohms
    nominal impedance when they are connected in bridge mono.
    TECHNICAL DATA
    POWER SUPPLY 11 15 VDC
    IDLING ABSORPTION 0.8 A
    MAX ABSORPTION (Nominal Pwr) 16 A
    CONT. NOMINAL POWER (Tol. +10%; -5%)
    2 Ch x 4 Ohms; 0.3% THD; 12 VDC 50 W (RMS)
    CONT. OUT POWER (2 Ch x 4 Ohms; 13.8 VDC) 60 W (RMS)
    CONT. OUT POWER (2 Ch x 2 Ohms; 13.8 VDC) 105 W (RMS)
    CONT. OUT POWER (2 Ch x 1 Ohm; 13.8 VDC) 150 W (RMS)
    MONO OUT POWER (4 Ohms; 13.8 VDC) Bridge 210 W (RMS)
    MONO OUT POWER (2 Ohms; 13.8 VDC) Bridge 300 W (RMS)
    TRI-MODE CONNECT. (4 Ohms) 60 + 60 + 210 (W RMS - pulse)
    DISTORTION THD (1 KHz; 90% Nominal Pwr) 0.06 %
    BANDWIDTH (-3 dB; Nominal Pwr) 4 Hz -75 KHz
    DAMPING FACTOR (4 Ohms) 120
    RISE TIME 4.5 S
    S/N RATIO 100 dBA
    INPUT SENSITIVITY 0.15V - 1.5V
    INPUT IMPEDANCE 15 KOhms
    OUTPUT IMPEDANCE Stereo 1 - 2 - 4 - 8 Ohms
    OUTPUT IMPEDANCE Mono 2 - 4 - 8 Ohms
    REMOTE IN 3 - 15 VDC
    REMOTE OUT 12 VDC
    MUTE IN 3 - 15 VDC
    MUTE OUT 12 VDC
    DIMENSIONS (WxHxD) 175 x 50 x 290 mm (6.89 x 1.97 x 11.42 inch)
    Power amp MMATS 2100, 2 X 100Watt (transistor model TO3), Rp 2,75jt.
    up....up....
    up...up...
    up...up....
    up..up....
    up...up....
    UP...UP...
    up...up....
  1. Jual : Power Amplifier Audison SRX 3
    By d3cibel in forum Power Amplifier
    Last Post: 24th May 2012, 16:13
  2. Jual : Power Monoblock Audison LRX 400.1
    Last Post: 29th September 2011, 11:15
  3. Jual :Power Amplifier Audison VRX 300.4EX.1
    Last Post: 3rd June 2011, 19:17
  4. Replies: 4
    Last Post: 15th February 2010, 22:17
  5. Replies: 48
    Last Post: 5th December 2009, 21:51
