JL 1000/1 vs Arc 1500
Results 1 to 8 of 8
  • Short URL:  http://modifika.si/58757
    4 Hrs 41 Mins 16 Secs
    Teman2,
    buat yg pernah pake power diatas, bisa kasih input bagaimana comparisonnya power2 diatas utk angkat sub (mis.utk 1 JL 12W6v2 or JL 12W7)? dan juga info harga (baru maupun 2nd). Thanks.
    Spec JL 1000/1
    * Rated Power: 1000 watts RMS at 1.5 ohm - 4 ohms (at 11V-14.5V)
    * THD at RMS Power: <0.05% @ 4 ohm
    * S/N Ratio: >95dB below rated power
    * Frequency Response: 5Hz - 500 Hz
    * Damping Factor: >500 at 4 ohms /50Hz
    * Input Range switchable from 200mV-2V RMS
    to 800mV-8V RMS
    * Dimensions: 19.7"L x 9.25"W x 2.36"H
    Spec Arc 1500
    # Number of Channels 1 - Mono
    # RMS Power (4 ohms) 510 watts x 1 channel
    # RMS Power (2 ohms) 1000 watts x 1 channel
    # RMS Power (1 ohm) 1000 watts x 1 channel
    # Bridged RMS Power Not Bridgeable
    # Total RMS Power 1000 watts
    # Peak Power Output N/A
    # Minimum Impedance Unbridged 1 ohm
    # Minimum Impedance Bridged Not Bridgeable ohms
    # THD at Rated RMS Power 0.006%
    # Speaker Level Inputs Yes
    # Preamp Outputs Yes - Mono Lead
    # Built-in Crossover Yes - LP
    # High-Pass Crossover Frequency N/A
    # Low-Pass Crossover Frequency 30 - 250 Hz
    # Subsonic Filter 10 - 80 Hz
    # Signal-to-Noise Ratio 112 dB
    # Channel Separation N/A
    # Bass Boost 0 - 15 dB
    # Bass/Gain Remote Yes
    # Fan Cooled N/A
    # Fuse Rating
    pd indah - bintaro PP
    3 Days 48 Mins 26 Secs
    woow 2 2 nya barang bagus nih..mantep, berhubung belum pernah jajal jadi menunggu juga eheh
    Maaf saya newbie kk...
    4 Mins 9 Secs
    Quote Originally Posted by baksojoni View Post
    Teman2,
    Spec JL 1000/1
    to 800mV-8V RMS
    Spec Arc 1500
    # Fan Cooled N/A
    # Fuse Rating
    mnrt gua seh mendingan pake jl jg bro, biar semerek ama sub nya jd karakternya sama,
    Cipete, SoutH Of JakaRtA.
    1 Day 21 Hrs 37 Mins 39 Secs
    Gw pilih ARC aja ah
    Batavija
    9 Hrs 14 Mins 30 Secs
    bro baksojoni kayanya perbandingan agak timpang deh
    lbh cocok JL 1000/1 vs zapco ref 1100
    and Arc 1500 vs zapco ref 500.1
    West Jakarta
    13 Mins 52 Secs
    JL lah.. kalo mau jual 1000/1 pm gw yah... eheheh
    Quote Originally Posted by dexza View Post
    bro, mungkin gue salah, tapi Arc 1500 bukannya bisa sampai 1000 watt?
    Class A/B Monoblock Subwoofer Amplifier
    RMS Power Rating:
    4 ohms: 510 watts x chan.
    2 ohms: 1000 watts x chan.
    1 ohm: 1000 watts x chan.
    Remote bass boost control (0 - 18 dB @ 45Hz)
    Variable Bass Boost Frequency: 30Hz - 125Hz
    cheers.
    Batavija
    oo, g cuma menghitung di 4 ohm aja bro waktu itu
Venom 300x250 Tekiro
  1. Replies: 6
    Last Post: 9th September 2012, 11:11
  2. DiJual PWR ROCKFORD FOSGATE CLASS D 1000 WATT BD 1000.
    By awi hiki in forum Power Amplifier
    Last Post: 1st May 2012, 14:53
  3. WTB ARC Audio : 1500.DR / KAR 1000.2T --> CLOSED
    By hns_555 in forum Power Amplifier
    Last Post: 7th October 2009, 12:11
  4. Rockford 1000 bd vs JL 1000.1 untuk MMATS Procast
    By charlie kasim in forum Diskusi Power Amplifier
    Last Post: 9th May 2008, 00:22
