SOLDDDDDDDDD : kabel reLay bosch[tQyu modcom]
Results 1 to 10 of 24
  • Short URL:  http://modifika.si/58651
    Duren Sawit Jakarta Timur
    Smile SOLDDDDDDDDD : kabel reLay bosch[tQyu modcom]
    maw jual kbel relay merk bosch[BOOKED]
    msh bgs
    70-80%lah
    gw bli dr bos Ju**,ga bisa alasany krn ini buat toyota(kijang,inova,yaris,vios,dll) n panther
    pkokny ini relay khusus bwt mbil2 yg pke 3 reLay
    gw bLi dr bos Ju** kondisiny cm ad 2 relay
    jd gw tmbhn 1 lgi relayny pke bosch(hrgany 22500)
    klo maw bli sndri gpp ko,tpi kondisny cm 2 relay
    klo mo pke hella 20rb
    ni kondisi barangny
    liad baik2 relay yg terpsg
    dsitu ad 3 slot,tpi cm ad 2 slot
    ini pic gw ambil dr bos Ju**
    skr d kabel relayny ud gw tmbhn relay 1 lgi merk bosch!
    hrga 35rb(ex.ongkir)
    n blm trmasuk tmbhn relay 1 biji lgi
    klo maw liad d atas hrgny
    maw hella ap bosch
    teliti sblm mbeli
    gw bli dr bos Ju"" kurang info n dia g taw ini 2 relay ap 3 relay!
    n gw awalny jg kurang ngrti sblm mbeli
    tpi stlah mbeli gw skr ud ngrti
    ayo2 d beli
    hot item
    pnambah terang lmpu halogen lw!
    pke forch,wurth,GE,philips smua lmpu halogen jd lbh terang
    arus lbh teratur!
    uuuuuuuuuuuuuuuup
    ayo dibeli2
    brang bgs
    sayang d stream gw g bsa
    jd hrs bli bru lgi de
    120rb!
    hiks3x
    4 Hrs 50 Mins 16 Secs
    kalo buat city bisa gak yah..g juga gak ngerti 2 apa 3 relay
    ga bisa bos bwt city
    klo bwt city 2 relay kek nwcity gw pke
    merk bosch jg
    td gw maw pke ini bwt stream 2003
    gw pkir beda sama city gw tnyata smua hondaaa sama jenisny
    pke yg 2 relay
    hehee
    klo pny toyota slhkan dbeli2
    ayo2 d beli
    bwt mbil yg jnis 3 relay
    g kalah terang dbdg sama MX boster for headlamp
    sama hella sama bgsny
    2 mbil gw ud pke kbel relay bosch pny ko!
    jaminan mutu de!
    ayo2
    uuuuuuuuuuuuuuuuuuuuuuuuppppppppppppppppppp
    altezza_zita@yahoo.com/satyrwebstore@yahoo.com
    5 Days 10 Hrs 36 Secs
    honda pake yg 2 relay bro
    www.satyrwebstore.web.id - automotive online store since 2006
    Osram, Forch, DS, Wealthy, K&N, Michelin, Denso, NGK, NWB, Castrol, Mobil, Shell, Aral, Total, etc
    ya gw ud tlanjur bli
    lgian org yg jual kga ngrti ni brg 2relay ato 3relay
    ysdah
    brg bru smpe rmh VIA TIKI gw jual lgi!
    hehehee
    Honoured Member
    Internazionale Milano
    2 Wks 3 Days 4 Hrs 45 Mins 16 Secs
    gw make nih...
    iyah jd mantab dah lampunya jd lebih terang...
    ayo di beli2
MBtech GT Radial
  1. Kabel Set Lampu 2 Relay & 3 Relay , Kabel Set Klakson , Kabel Otomotif AVSS
  2. WTS Relay set lampu BOSCH 2 & 3 relay,kondisi 99%.
    By corol63412 in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 8th November 2012, 09:08
  3. {WTS} Kabel Relay Bosch MAX 7
    By kwa.accesories in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 19th June 2012, 23:12
  4. WTA Osram All Season + Kabel Relay Bosch
    By Triton848 in forum Diskusi Aksesoris
    Last Post: 1st July 2009, 10:44
  5. [BOOKEEED]:kabel relay bosch+bohlam wurth H4 xenon
    By Riefki in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 30th September 2008, 19:11
