Cusco Front Strubar (FSB) and Rear Strutbar (RSB)
  • Short URL:  http://modifika.si/576105
    Keb. Baru, South Jakarta
    1 Mth 4 Days 2 Hrs 24 Mins 31 Secs
    Lightbulb Cusco Front Strubar (FSB) and Rear Strutbar (RSB)
    Ok, another review from me... as usual I'll try to keep this simple and easy...
    Length of use: 3 months moreless
    Mark X has been showing yaw tendency repeteadly on its aft (back of its chassis) most likely originated by its chassis flex. Coilover, unfortunately, is not able to completely cure the yaw issue but the installation does help somewhat but by having rear strutbar this yaw problem is moreless gone.. You gotta retorque everything after several week/months/kms of usage as the metals are seated...
    Just abit of an advice, please do not be cheap in buying a strutbar. You really got to be concern on the material and construction. You got to buy the one which was made specifically for your car else you are risking damaging your chassis. Ada duit ada barang...
    Front
    Rear
    The good:
    • Fit and finish is superb!
    • Plug and play
    • Build quality
    • The rear strutbar has an option to use a quick release. I went ahead with this option.. It is actually using a latch system on the hinges instead of normal bolts for a quick install/uninstall
    The bad:
    • Instructions are written in Japanse
    • Price. Again, this is the downside of modding scene here in Indonesia..
    The ugly:
    • Nothing really
    2 Wks 4 Days 8 Hrs 21 Mins 13 Secs
    tq for sharing..
    21 Hrs 14 Mins 13 Secs
    wah, masih baru
    Quote Originally Posted by andri_boeaja View Post
    tq for sharing..
    Likewise, thank you for reading oom
GT Radial Venom 300x250
  1. Replies: 55
    Last Post: 1st May 2013, 10:29
  2. wts : Front & Rear Strutbar CUSCO ORIGINAL GD3
    By removeauto in forum Bursa Kaki Lainnya
    Last Post: 5th December 2012, 19:39
  3. WTS Front and Rear Strutbar Ferio
    By julioverdy in forum Jual Beli Mesin Lainnya
    Last Post: 4th December 2012, 00:30
  4. Replies: 1
    Last Post: 31st October 2011, 22:30
  5. yooo juall strutbar js racing and rear strutbar js racing gd3 seken
    By ockydinata in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 3rd August 2010, 18:13
