WTS :Tube High end power HOme audio bekas test dengar...
Kami ingin memberitahukan bahwa Sistem Jual Beli Audio Mobil baru telah kami aktifkan
Untuk informasi lebih lengkap dapat dilihat di http://modifika.si/595332
Results 1 to 10 of 25
  • Short URL:  http://modifika.si/57564
    Giro Point
    8 Hrs 28 Mins 28 Secs
    As title ,mau jual poweer integrated tabung dengan budget middle kualitas high end spec sbb :
    4 x KT88 Stereo Tube Integrated Amplifier
    Sorry soldddddddd.........thx all yg udah nanya..
    • Awesome and powerful 65 watt per channel dual mono power amp. Two separate amps with two separate power supplies on one chassis.
    • Beautiful styling with bright copper lacquered chassis and huge potted transformers with curved aluminum tube cage
    • Front panel inputs to bypass internal preamp so you can use your own preamp or source directly to power amps
    • Switchable from 65 watts Ultralinear to 32 watts pure triode mode
    • Very powerful amplifier that will drive any speaker with authority. Great frequency extension and bass control.
    Input Power : 110V - 240V AVAILABLE
    Output Power : ultra-linear 2x 65W RMS, triode state 2x 45W RMS (8 ohm)
    Tubes : KT88x4 6SN7x4 12AX7x2
    INPUT : Integrated 0.3V Power 0.6V
    Frequency : 20Hz~100KHz (-1dB,10w/8 ohm)
    Signal/Noise Ratio : >8dB "A Weight"
    Harmonic Distortion : <0.5%(1KHz60W)
    Input impedance : 20Kohm
    Use Pressure : 110 V - 240V
    Consumption : 300W
    Load impedance : 8ohm or 4ohm
    Signal Inputs Level : >300mv
    Audio Input : 4 groups
    Audio Output : 2 groups
    Weight : 29kg
    Size Dimension :
    Width 390mm
    Height 190mm
    Depth 490mm
    Colour : Gold Body & Dark Green Power Supply
    Packing Includes : All the Tubes / Valve
    Standard 1.5m (5 ft) Power Cord
    Screw Driver
    Hex Key (Allen Key)
    serious only call : 02170769073/0811805167
    Bali-Surabaya
    Giro Point
    wew keren bantu up dulu
    Giro Point
    6 Days 3 Hrs 38 Mins 33 Secs
    brapa duit nih?
    Giro Point
    2 Hrs 26 Mins 17 Secs
    bisa dibantu price nya berapa bro ?
    Giro Point
    bro bro sekalian ,,ini ampli tabung udah dibandinggin dgn yang merk lain yg outputnya 45w /ch,hrg pasar 12 jt,tp tidak doublepower suply..
    sedangkan ini 65w /chanel ,harga yang pasti dibawah hrga itu,,thanks
    bos nakamichi dan pals cek pm..
    Giro Point
    up dulu.....
    L 111 P
    Giro Point
    2 Days 50 Mins 7 Secs
    keren nih powernya
    nyoo_hks@yahoo.co.id
    Giro Point
    Quote Originally Posted by philipz View Post
    keren nih powernya
    di ambil aja boss... buat di rumah si boss..
    Giro Point
    hehehe..iya boss ,denger dulu juga boleh ...
    sharing 2 dulu gitu ...
    ( o )V( o )
    Giro Point
    13 Hrs 21 Mins 59 Secs
    barang yang amat sangat mantafffff :smt007 :smt007 :smt007
  1. Home Audio : Tube Pre + Power Amp Cary
    By gpaudio in forum Home Electronics
    Last Post: 17th August 2013, 07:15
  2. home audio high end = Sonic Frontier Power 3
    By iwanjogja in forum Bursa Audio Lainnya
    Last Post: 17th November 2012, 05:07
  3. Home Audio : Tube Pre + Power Amp Cary
    By gpaudio in forum Bursa Audio Lainnya
    Last Post: 23rd June 2012, 05:21
  4. WTS Home Audio: Power Tube Manley Reference Compact 160 (updated)
    By ketupatSayur in forum Bursa Audio Lainnya
    Last Post: 9th March 2011, 16:07
  5. HOME Audio : PREAMP TUBE World audio england + Power haffler
    By rendy76 in forum Barang Lain-lainnya
    Last Post: 6th March 2008, 09:49
