(ask) sub free air dibikinin box ??
  • Short URL:  http://modifika.si/57269
    5 Days 13 Hrs 18 Mins 52 Secs
    saya ada sub JL audio IB4 10" 2 biji dl dipake di sedan... skrg rencana dipake dijazz... kalo dibikin box.. kt installaturnya boxnya bakal lebih besar dibanding sub non free air? benar?
    ada yg tau spek volume dan typr box yg bagus utk JL ini?
    abis kalo dijazz bisa ga suaranya ky disedan yg ada bagasinya?
    ini speknya :
    # Nominal Diameter: 10 inches (250 mm)
    # Continuous Power Handling: 100 Watts
    # Voice Coil: 2.0" diameter, 2-layer, Kapton former
    # Available Configurations: 8 ohm (Single Voice Coil)
    # Xmax (one-way, linear): 0.30" (7.6 mm)
    # Fs (free-air resonance): 37.5 Hz
    # Qts (total speaker Q): 0.769
    # Qes (electrical Q): 0.837
    # Qms (mechanical Q): 9.4
    # Vas (equivalent compliance): 2.93 82.9
    # Efficiency (1W/1m)*: 89.0 dB
    # Sd (effective piston surface area): 51.8 0.0334
    # Re (DC resistance): 7.20
    # Znom (nominal impedance): 8
    # Pt (continuous thermal power handling): 100 Watts
    http://img.photobucket.com/albums/v12/PUMPKINS/avatarmodifikasi.jpg
    PROffesional DRIVEr
    Diamonds are for girls; Only the wise men follow the stars
    altezza_zita@yahoo.com/satyrwebstore@yahoo.com
    5 Days 10 Hrs 36 Secs
    bener. kayak sub gw. jadi gede bgt bos...
    kata gw sih sayang. mending tuker sub nya bro
    gw jg mau tuker. jadi sempit abisnya
    IMHO
    www.satyrwebstore.web.id - automotive online store since 2006
    Osram, Forch, DS, Wealthy, K&N, Michelin, Denso, NGK, NWB, Castrol, Mobil, Shell, Aral, Total, etc
    Jakarta Timur
    6 Hrs 13 Mins 7 Secs
    Quote Originally Posted by WRX View Post
    ini speknya :
    Gimana klo jazznya u bikin jadi punya bagasi.... Dari jok penupang belakang sampe ke kaca belakang u bikinin pannel baru, trus di belakangnya joknya u lapis papan lagi sampe ke lantai. Nah jadi box baru tuh kaga makan tempat pula, masih bisa taruh barang, cuman gak bisa yang terlalu besar.
    thanks inputnya....
    kynya mending tuker aja yea...
    tapi bisa tuker jadi sub apaan yea?? yg bandingannya?
    oya kalo dipakein box tapi ga sebesar mustinya emang kalo diomong angka dr skala 1-10 jadi kira2 brp tuh dinilainya kalo pake box yg bukan speknya??
    PROffesional DRIVEr
  1. Replies: 0
    Last Post: 7th November 2011, 14:25
  2. Replies: 0
    Last Post: 22nd September 2011, 10:06
