*SUPER SALE !! VOLT STABILIZER set (Include Ground Wire)*
Page 1 of 32 12345 ... LastLast
Results 1 to 10 of 312
  • Short URL:  http://modifika.si/5691
    Sebelah tetangga
    9 Hrs 37 Secs
    Ground Wire Set ( Include VOLT STABILIZER + MASTER FUSE ) / VOLTAGE CHARGING UNIT WITH GROUNDING SYSTEM
    - 12 V Automobile is a special purpose, it is steady to improve traffice safety, voltage, electric current
    - Promote all regional choke valve efficiency
    - Strengthen and start the efficiency of the motor
    - Keep the idele speed steady
    - Save the fuel up to 3-20 (different because of driving habit, road conditions, one horsepower of value, CP Value of selecting the goods for use)
    - Improve torsion value by a wide margin
    - Improve the unable sense of the engine
    - Save effort even more at the time of climbing
    - Improve and can not shaking suitable and horsepower accelerate being sensitive
    - Lengthen Denso product and life-span os storage battery
    - Strengthen the luminace of the headlight
    - Improve the sound system quality and reduce the miscellaneous news
    Price Rp. 800.000,- SUPER DISCOUNT MENJADI RP. 500.000,- SELAMA STOK MASA PROMOSI MASIH ADA !
    Awas Barang Tiruan !!!
    CHarging Unit ORIGIN JAPAN !!!!
    UPDATE GAMBAR :
    0817756556 (back !) - 021 30863062 (damn fuckin hp) -
    ikan asin ikan tongkol
    orang miskin cuma bisa misscall
    ikan lele gede di ember
    cuma orang jelek yang pake private number
    http://www.geocities.com/bantulmerana_2006/katalog1.gif
    Sebelah tetangga
    9 Hrs 37 Secs
    Ukuran kabel lebih besar dari jenis grounding yang beredar dipasaran
    Sebelah tetangga
    9 Hrs 37 Secs
    setelah postingan ini, pasti bakal ada yang bertanya, ngepek gak sih pake ini ?
    gini, sebelum pertanyaan dilontarkan, ada baiknya lihat dulu kabel standard di kutub negative aki.
    kabel nya cuma selembar doank tetapi difungsikan untuk mensuplai seluruh kelistrikan mobil melalu body / rangka mobil.
    untuk mobil mobil yang cukup berumur, tentu akan pengaruh penurunan kualitas dari ground tersebut yang dikarenakan, karat, dan oksidasi lainnya.
    alat /kabel ini cukup membantu (selain fashion) dalam hal kelistrikan terutama di mobil mobil yang berbeban berat. dan setidaknya memperpanjang umur kelistrikan di mobil, contoh HID / ECU / SOUND SYSTEM. worth to buy lah harga segini dibanding barang2 mahal di mobil .. heheheh
    BANDUNG
    3 Hrs 56 Mins 37 Secs
    cek pm bos
    "Goldfish Lover" ^_^
    http://www.modupload.com/images/yvzp6mci4zolj11ta4sw_thumb.jpg
    "MOVE TO ANOTHER FORUM........................"
    Sebelah tetangga
    9 Hrs 37 Secs
    sent back
    8 Hrs 10 Mins 4 Secs
    Gambarnya ga keluar nih.
    Ini sama yg ground wire doang itu beda lagi ya merknya?
    Dari sisi kwalitas groundwire nya bagusan mana?
    Sebelah tetangga
    9 Hrs 37 Secs
    bagusan ini jauh.
    ukuran kabel aja dah beda
    Kalo terminal kepala accunya (positif & negatif) dan terminal kabel positif ada ga? Karena bawaan mobil kan kepalanya dah jadi 1 ama kabel standardnya.
    Biar sekalian 1 paket, ga perlu cari2 lagi ditoko. hehehehe.......
    Kalo ada mau dong.
    Sebelah tetangga
    9 Hrs 37 Secs
    gak perlu bos, itu tiggal di pararel aja masukin aja ke lubang mur dah dah gitu dibaut .. beres .
    gak sampe 5 menit kok
    yang lama nyetting kabelnya biar enak dilihat bos :smt003
    kirim neh ye ke tempat waktu itu ? ;-) hehehe
    Kalo punya tuh terminal2nya mau saya ganti sekalian. Kan ada tu yg bagus, kuning2 gitu kaya gold plated yg pake mur kupu2. Punya ga?
Venom 300x250 GT Radial
  1. Replies: 230
    Last Post: 4th March 2010, 11:22
  2. WTS : Volt Stabilizer + Ground Wire, Speedparks 9R
    By spotz in forum Jual Beli Mesin Lainnya
    Last Post: 14th November 2008, 12:53
  3. Ground Wire & Volt Stabilizer
    By Trebor in forum Diskusi Mesin
    Last Post: 28th October 2008, 02:08
  4. ===APEXi VOLT STABILIZER(INCLUDE GROUND WIRE)
    By zoom-bodyworks in forum Jual Beli Mesin Lainnya
    Last Post: 5th June 2008, 03:09
  5. WTA:gunanya volt stabilizer n ground wire
    By blablabla in forum Diskusi Mesin
    Last Post: 5th December 2006, 20:17
