Bekas Dijual Power Signat Ram 1 Mark II pure class A 6ch power amp mulus
Results 1 to 7 of 7
  • Short URL:  http://modifika.si/568008
    1 Mth 2 Wks 10 Hrs 19 Mins 36 Secs
    Dijual power langka Signat ram 1 Mark II pure class A 6 ch
    Specs:
    Amp type: 6 channel
    Pc board: double sided gold-plated 24 K
    Power terminal: gold plated fully isolated type
    Speaker terminals: gold plated fully isolated type
    Signal input terminals: 6 x RCA jacks gold plated
    BIC balanced input circuity
    Bridged mode: yes (min. 2 Ohm)
    Trimode operation: built in
    Protection and control circuites: Temperature, overload, short circuit,
    DC offset
    Output load impendance (stereo mode): 1 - 8 Ohm
    Active low pass filter: 50-250Hz, 12dB (ch 5/6)
    Active high pass filter: 50-250Hz,12dB (ch 1/2 & 3/4)
    Technical data:
    Max. peak music power: 700W
    RMS power at 4 Ohm (0,05% THD): 2x90W + 4x45W
    RMS power at 4 Ohm, bridged (0,1% THD): 1x235W + 2x110W
    RMS power at 2 Ohm (0,2% THD): 2x120W + 4x60W
    RMS power at 1 Ohm (0,2% THD): 2x120W + 4x60W
    S/N ratio (A-weighted): 105 dB
    Freq. response (-3dB): 10-65 kHz
    Stereo separation: 70 dB
    Input sensitivity: 100mV - 4V
    Input impendance: 20 kOhm
    Fuse rate: 2 x 30A
    Supply voltage: 12 V DC
    Dimensions: 230 x 57 x 432 mm
    RRP is over $1000
    1.Kondisi barang mulus dan normal
    2.Mohon maaf saya tidak menjual barang Palsu dan barang KW juga tidak menjual barang yang rusak
    3.Lokasi barang di Jakarta selatan (Pakubuwono Area) Bisa test di tempat
    Untuk di luar kota bisa dikirim via JNE or MEX
    4.Untuk informasi Bisa call/whatsapp 0811880333 or pin bb 2AA35183
    5.Untuk posting lainnya silakan buka link ini :
    http://www.modifikasi.com/member.php/130849-Ferrlim
    6.Terima kasih Modcom
    Hub 0811880333 and pin bb baru 2aa52a1c,thanks
    Power ampli
    Luxman CM-2100
    Sinfoni Amplitude 120.4x (4x135Watt-Handmade Itali)
    Genesis five channel (5 channel-UK)
    Genesis Class A P300x (6 channel-UK)
    Orion Xtreme XTR 100 (USA)
    Zapco Competition Z600C2-SL
    Zapco Monoblock Ref 500.1 Class AB
    Power amper class A PA 60
    Audison Lrx1.1K (monoblok)
    RF DSM100 (2biji)
    Soundstream D200ii
    Steg qmos 120.2
    Steg Qmos Monoblok 240.1
    Steg K2.01 (2x105Watt)
    Power HarmanKardon TC300
    Crossfire monoblok cfa390M
    Crussfire BMF 125.2
    Orion HCCA 2100
    Orion 280GX Military spek (2x80Watt) USA
    Hifonics Vulcan 100watt
    Rockford Forgate 75
    Rockford Forgate 150
    Alpine 3540 Japan (2x40Watt)
    Alpine Juba 3501
    Alpine MRV-T500
    Rockford Forgate 75hd (2 x 37,5watt) USA
    Crossfire BMF 125.2 (2x125 Watt) USA
    PhoenixGold M50
    Precision Power 2150M (2x150Watt)
    presision power(ppi2360)
    Ram Signat 6ch pure class A
    Speaker dan sub woofer :
    Venture 2 way V92+V26
    Venture tweter V26
    Midbass Skaning Flexi Unit 6H
    Midbass DLS Ultimate Iridium
    Midbass dLs Nobellium
    midbass dynaudio MW160+tw+pasif
    Cresendo 2 way opus 5
    Midrange Audhible phisik 3"
    Mcintosh mss650 lengkap
    Mcintosh mss630 lengkap
    JL audio 6” coax
    Hertz coaxial 6" hcx165
    Sub woofer :
    Sub skanning Flexi unit FU 10c
    Sub High end Hertz Mille ML2500
    Sub RF 8" RFS-1408
    Pioneer TS-W12PRS
    Kicker Freeair F12c
    Kicker Freeair F8a
    JL audio 12w6 Gold series
    JL Audio 10W3v1
    Dynaudio 24w75xl
    Phass 10” Japan
    Head Unit,Procesor dan accesoris :
    Alpine PXA+Rux 800 New
    Helix C-DSP
    Phoenix gold ax406A
    EQ Audiocontrol EQL
    Crossover Audiocontrol 24XS
    Hi to Low Audiocontrol LC7
    Audiocontrol 3xs
    Audiocontrol DXS (Digital Crossover)
    Pioneer CD-UB100 (New) (USB conector)
    Proc Alpine PXA 700 (Korea)
    Alpine CDA 9855
    Alpine CDA-7949E
    Addzest drx-9255xl
    Alpine 5980
    Nakamichi MB-650
    Pioneer AVH-P7850dvd
    Pioneer Dex-P1
    Caps Lightning Audio USA 1F
    Caps Helix 500.000 uf Germany
    capasitor EFX 1 F
    Batcap 300
    Crossover Pasif 2way & 3way Custom by Ko EX
    1.Kondisi barang segel dan normal
    6.Terima kasih
    Power ampli
    Luxman CM-2100
    US AMPS 150 (USA)
    RF DSM100 (2biji)
    Soundstream D200ii
    Steg qmos 120.2 (2x120Watt)
    Steg Qmos 75.4 (4x75Watt)
    Steg K2.02 (2x155Watt)
    Crossfire monobloc 2400d (2400watt)
    Crussfire BMF 125.2 (2x125Watt)
    Orion HCCA 2100 (2x100Watt)
    Rockford Forgate 75
    Alpine Juba 3501
    Alpine MRV-T500
    PhoenixGold M50
    Venture tweter V26
    Flux SC261
    Midbass dynaudio 17 WLQ
    Midbass Phass alnico mw6512Al
    midbass dynaudio MW160+pasif
    Cresendo Opus 9 mk1 dan mk2
    Seas Ensemble 5”+pasif+tw seas lotus
    Scenspeak 15Wu/4731T00 (midwoofer Illuminator series)
    Tweter Scenspeak Ring radiator R2904/70000
    Tweter Scenspeak Illuminator D3004/66200
    Tweter Abbys Reference
    JL audio 6” coax
    Coaxial RF 6”
    Sub woofer :
    Sub RF 8" RFS-1408
    Pioneer TS-W12PRS
    Pioneer 12” slim
    Kicker Freeair F12c
    Kicker Freeair F8a
    JL Audio 10W3v1
    Dynaudio 24w75xl
    Phass 10” Japan
    Alpine PXA 701 JDM
    ARC DSP 8
    Phoenix gold ax406A
    EQ Audiocontrol EQL
    Audiocontrol 3xs
    Clarion hx-D1
    Alpine CDA 9855
    Alpine CDA-9856
    Alpine CDA-7949E
    Nakamichi MB-650
    Pioneer Dex-P1
    Caps bank Braf 1 F
    Caps Bank Helix 1 F
    Caps Bank Rockford Fotgate 1 F USA
    capasitor EFX 1 F
    Caps HU Shark 68.000 uf
    Batcap 300
    Power ampli
    Luxman CM-2100
    US AMPS 150 (USA)
    RF DSM100 (2biji)
    Soundstream D200ii
    Rockford Forgate 75
    Alpine Juba 3501
    Alpine MRV-T500
    PhoenixGold M50
    Venture tweter V26
    Flux SC261
    JL audio 6” coax
    Coaxial RF 6”
    Sub woofer :
    Sub RF 8" RFS-1408
    Pioneer TS-W12PRS
    Pioneer 12” slim
    Kicker Freeair F12c
    Kicker Freeair F8a
    JL Audio 10W3v1
    Dynaudio 24w75xl
    Phass 10” Japan
    Alpine PXA 701 JDM
    ARC DSP 8
    Phoenix gold ax406A
    EQ Audiocontrol EQL
    Audiocontrol 3xs
    Clarion hx-D1
    Alpine CDA 9855
    Alpine CDA-9856
    Alpine CDA-7949E
    Nakamichi MB-650
    Pioneer Dex-P1
    Caps bank Braf 1 F
    Caps Bank Helix 1 F
    capasitor EFX 1 F
    Batcap 300
    1.Kondisi barang mulus dan normal...
    Power ampli
    Steg Masterstroke MSK 3000 (2x400Watt)
    Audison HRV Trenta (2x320Watt)
    Luxman CM-2100
    Genesis Q200x (4 channel)
    RF DSM100 (2biji)
    RF DSM 200ix
    Soundstream D200ii
    Rockford Forgate 75
    Alpine Juba 3501
    Alpine MRV-T500
    PhoenixGold M50
    Alpine 3Way F1 status (Base by scenspeak)
    Venture tweter V26
    Hertz 3 way
    Seas Ensemble 5+pasif+tw seas lotus
    Coaxial RF 6
    Sub woofer :
    Sub RF 8" RFS-1408
    Pioneer TS-W12PRS
    Pioneer 12 slim
    Kicker Freeair F12c
    Kicker Freeair F8a
    Dynaudio 24w75xl
    Phass 10 Japan
    Alpine PXA 701 JDM
    Phoenix gold ax406A
    EQ Audiocontrol EQL
    Audiocontrol 3xs
    Alpine Phantom face 7998R
    Pioneer Baby ODR Dex-P9 + Deq P-9
    Alpine CDA-117 USB
    Clarion hx-D1
    Alpine CDA 9855
    Alpine CDA-9856
    Alpine CDA-7949E
    Nakamichi MB-650
    Pioneer Dex-P1
    CD Changer :
    Alpine CHA-624 (Dus buku)
    Alpine Cha-634 Mp3
    Alpine Cha-1204
    Alpine Cha-1224
    Clarion dvd changer
    Clarion 623
    Clarion 1225
    Caps bank EFX 0.5F (New)
    Caps Bank Helix 1 F
    capasitor EFX 1 F
    Batcap 300
  1. Replies: 18
    Last Post: 23rd January 2013, 21:52
  2. WTS Power 6ch Signat RAM 1 Mark II "Gold Plated"
    By albert_ndoxxx in forum Power Amplifier
    Last Post: 16th September 2012, 11:37
  3. Replies: 30
    Last Post: 17th August 2011, 23:26
  4. Replies: 15
    Last Post: 26th June 2010, 20:15
  5. Replies: 13
    Last Post: 31st March 2010, 13:13
