Jual Second Digital Designs 4Channel Amplifier.
Harga jual: Rp 1.850.000 (NEGO)
Berfungsi dengan baik dan normal, belum pernah service.
Spesifikasi Produk:
Series C
Input Sensitivity 0.2V - 6V
Variable High Pass Filter 30Hz - 1.2KHz
Variable Low Pass Filter 30Hz - 500Hz
Variable Bass Boost 0-12dB @ 40Hz
Tested Voltage 14.4
Tested THD 1%
Model C4b
Cont Power at 4 ohm 60W x 4ch
Cont Power at 2 ohm 100W x 4ch
Cont Power at 4 ohm mono 200W x 2ch
Damping Factor >100
Dynamic Power 800W
Efficiency thru Output 65%
Dimensions - mm 244.5W x 54.3H x 300L
Dimensions - inches 11.81L x 9.63W x 2.14H
Signal to Noise >100dB
Shipping Weight 11.5 lbs
Barang bisa di lihat di showroom Linear Autosound, Jalan Raya Serpong no. 45, Serpong - Tangerang
Contact Person.
Vivi
Hp / WA 087888064290
Telp Toko. 021 - 53125526
