Bekas Dijual power high end dan rare item...zapco Z600C2-SL mulus
  • Short URL:  http://modifika.si/566796
    1 Mth 2 Wks 16 Hrs 28 Mins 21 Secs
    Dijual power High end dan rare Item Zapco competition Z600C2-SL kondisi istimewa....
    150 watts x 2 @ 4Ohm < .01%
    325 watts x 2 @ 2Ohm < .02%
    450 watts x 2 @ 1Ohm < .05%
    325 watts x 1 @ 4Ohm < .02%
    900 watts x 1 @ 2Ohm < .05%
    1.Barang masih Original,mulus dan no service
    2.Mohon maaf saya tidak menjual barang Palsu dan barang KW juga tidak menjual barang yang rusak
    3.Lokasi barang di Jakarta selatan (Pakubuwono Area) Bisa test di tempat
    Untuk di luar kota bisa dikirim via JNE or MEX
    4.Untuk informasi Bisa call/whatsapp 0811880333 or pin bb 2AA35183
    5.Untuk posting lainnya silakan buka link ini :
    http://www.modifikasi.com/member.php/130849-Ferrlim
    6.Terima kasih Modcom
    Zapco Z600C2-SL
    Competition Amplifier
    by Danny Holdman
    Pros:
    1 ohm stability
    lots of power
    balanced inputs
    excellent sound quality
    braggin' rights
    Cons:
    PRICE
    no rca inputs
    PRICE
    no included crossover
    did I mention....PRICE????
    Features:
    The Zapco Z600 was (until 2000) the flagship sound quality amplifier from Zapco. The power ratings are 150x2 or 600x1 into 4 ohms. 2 ohm ratings are 300x2 or 900x1. The 1 ohm stereo rating is 450x2. This is a large amp, with external dimensions of 19.4"x 8"x 2.4". THD + Noise is listed at <.01% @ 4 ohms, with a S/N ratio of >100dB. Damping is an excellent 1000 @ 4 ohms, and it is stable to 1 ohm stereo/ 2 ohm mono. It has built-in LEDs for power and protection, and also has a built-in LED for clipping. An outboard clipping indicator module is available for dash mounting. A bottom mounted integrated cooling fan helps keep things at a respectable temperature. This amp, like all other Competition Series amps (except the Z100) will also provide power for many outboard Zapco processors, through the balanced Symbilink cables. This translates to less power and ground wiring, and less chance of induced noise. The Symbilink balanced inputs accept up to 18V of input signal, and while there is no RCA input, the included 1 foot RCA-Symbilink adapter provides the connection for those folks unlucky enough not to be running balanced inputs. Crossovers and bass boosts are not built in to this amplifier, as those who spend this much money on a sound quality amp tend to want to use outboard processing. Now for the bad news....MSRP generally runs around....are you ready for this????....$!500! OUCH!
    Installation:
    Install is straight-forward and much as you would expect, with four corner screw holes, but be sure to leave space under the amp to allow the cooling fan to draw air if you are going to run it lower than 4 ohm stereo. Without adequate air passage this amp will get very hot and shut itself down. Using the Symbilink adapter makes for a very clean looking connection, but if you spent $500 a foot on RCAs and want to show them off, you are out of luck. The large gold plated power and ground terminals accept up to 8 gauge wire, and the speaker terminals are also gold plated, accepting what looks like 12 gauge wire (guess). Wiring diagrams are printed above the speaker terminals and are fairly easy to understand even for those of us who are intellectually challenged. 3 integrally mounted 30A fuses are included, for a large maximum current draw. Make sure your electrical system can handle the demand, or you will soon be showing off your amp without playing it.....
    Performance:
    The test sheet included verified performance of the amp at 4 ohm mono, showing about 640 watts RMS before distortion skyrocketed. This is a monster amp with enough power to pound all but the most power-hungry subs. The only amp Zapco makes production (as of this writing) that produces more power is the Studio 500, which does 1000x1 @ 4 ohms, but will be axed in 2000. Conversations with the actual engineers at Zapco have led me to believe that the Z600 is actually capable of producing 1300-1400 watts at 2 ohm mono, provided your electrical system can supply a constant 14.4V. Remember that this amp is the normal Class A/B, and not class D, so the current draw for that kind of output will be substantial. Sound quality is excellent, with a clean, clear output, no added noise. This amp does exactly what an amp is meant to do. AMPLIFY. Unbelievable headroom allows for beautiful musical transients. My Z600 is currently running 4 ohm stereo on a pair of image dynamics IDQ10s, and the sound quality and control of the subwoofers leaves no room for complaint. Uncompromised performance and flexibility have placed this amp on a pedestal in the annals of sound quality competition history. IASCA competitors and champions alike have used this amp for years in various configurations, from driving subwoofers to components speakers to HLCDs. This amp would find its way to the Top Ten list of many industry veterans. I have personally listened to it not only in my own vehicle, but also in several IASCA Finals sound quality vehicles, one of which was a championship system.
    Bottom line - If you have the money, this amp is worth it. You will not be disappointed.
    Hub 0811880333 and pin bb baru 2aa52a1c,thanks
    Power ampli
    Luxman CM-2100
    Sinfoni Amplitude 120.4x (4x135Watt-Handmade Itali)
    Genesis five channel (5 channel-UK)
    Genesis Class A P300x (6 channel-UK)
    Orion Xtreme XTR 100 (USA)
    Zapco Competition Z600C2-SL
    Zapco Monoblock Ref 500.1 Class AB
    Power amper class A PA 60
    Audison Lrx1.1K (monoblok)
    RF DSM100 (2biji)
    Soundstream D200ii
    Steg qmos 120.2
    Steg Qmos Monoblok 240.1
    Steg K2.01 (2x105Watt)
    Power HarmanKardon TC300
    Crossfire monoblok cfa390M
    Crussfire BMF 125.2
    Orion HCCA 2100
    Orion 280GX Military spek (2x80Watt) USA
    Hifonics Vulcan 100watt
    Rockford Forgate 75
    Rockford Forgate 150
    Alpine 3540 Japan (2x40Watt)
    Alpine Juba 3501
    Alpine MRV-T500
    Rockford Forgate 75hd (2 x 37,5watt) USA
    Crossfire BMF 125.2 (2x125 Watt) USA
    PhoenixGold M50
    Precision Power 2150M (2x150Watt)
    presision power(ppi2360)
    Ram Signat 6ch pure class A
    Speaker dan sub woofer :
    Venture 2 way V92+V26
    Venture tweter V26
    Midbass Skaning Flexi Unit 6H
    Midbass DLS Ultimate Iridium
    Midbass dLs Nobellium
    midbass dynaudio MW160+tw+pasif
    Cresendo 2 way opus 5
    Midrange Audhible phisik 3"
    Mcintosh mss650 lengkap
    Mcintosh mss630 lengkap
    JL audio 6” coax
    Hertz coaxial 6" hcx165
    Sub woofer :
    Sub skanning Flexi unit FU 10c
    Sub High end Hertz Mille ML2500
    Sub RF 8" RFS-1408
    Pioneer TS-W12PRS
    Kicker Freeair F12c
    Kicker Freeair F8a
    JL audio 12w6 Gold series
    JL Audio 10W3v1
    Dynaudio 24w75xl
    Phass 10” Japan
    Head Unit,Procesor dan accesoris :
    Alpine PXA+Rux 800 New
    Helix C-DSP
    Phoenix gold ax406A
    EQ Audiocontrol EQL
    Crossover Audiocontrol 24XS
    Hi to Low Audiocontrol LC7
    Audiocontrol 3xs
    Audiocontrol DXS (Digital Crossover)
    Pioneer CD-UB100 (New) (USB conector)
    Proc Alpine PXA 700 (Korea)
    Alpine CDA 9855
    Alpine CDA-7949E
    Addzest drx-9255xl
    Alpine 5980
    Nakamichi MB-650
    Pioneer AVH-P7850dvd
    Pioneer Dex-P1
    Caps Lightning Audio USA 1F
    Caps Helix 500.000 uf Germany
    capasitor EFX 1 F
    Batcap 300
    Crossover Pasif 2way & 3way Custom by Ko EX
  1. BEKAS Dijual Power High end dan Oldschool Harman Kardon TC-300 USA.....
    By Ferrlim in forum Power Amplifier
    Last Post: 17th July 2014, 15:32
  2. Replies: 8
    Last Post: 4th July 2014, 19:56
  3. Replies: 2
    Last Post: 4th July 2014, 19:52
  4. BEKAS Dijual Power High End MCintosh MCC406M mulusssssss dan ori....
    Last Post: 13th June 2014, 19:10
  5. Replies: 2
    Last Post: 17th April 2014, 22:56
