Bekas ARCAM HOME THEATER ( HI-END COMBO ) ( DROP PRICE ) ( MINT ) !!!!!
Results 1 to 10 of 24
  • Short URL:  http://modifika.si/565860
    京都- 日本
    10 Mths 3 Wks 4 Days 18 Hrs 7 Mins 36 Secs
    A perfect partner for home theater
    1. Arcam diva dv 135 ( sacd ) + Arcam diva avr 280 ( surround receiver )
    - kondisi mint ( tidak ada masalah ) ( siap pakai ) ( ex display )
    - kelengkapan: unit + remote
    - reccomended buat home theater kelas hi-end
    - coba, cocok, audisi, deal !
    Harga kami: ASK !!! ( super special price buat satu set )
    Spoiler for specification: Show
    PLAYER
    Spoiler for detail: Show
    Digital Audio
    - Dolby Digital, CD, MP3 & WMA audio plus DVD-Audio and SACD playback
    -32-bit Zoran audio DSP for optimum fidelity
    -Top of the line 24-bit 192kHz Wolfson WM8740 DACs
    -Global audio delay manager, 0-150ms, for perfect lip sync with digital
    processors / displays
    -Ultra-low jitter audio clock circuitry
    -State of the art CD replay from a DVD player, including HDCD decoding
    -Quick and easy SACD/CD hybrid layer change for fast comparisons
    -Replays MP3 and WMA files from recordable CDs and DVDs with
    dedicated on-screen browser
    -Coaxial, optical and HDMI digital audio outputs support 2-channel PCM
    up to 24-bit / 96kHz
    -Dual laser DVD drive reads CD-R/RW discs and most copy protected
    audio CDs
    Video
    -Zoran Vaddis 888s processor with built-in “per pixel” motion adaptive
    progressive scan engine
    -Zoran video scaling (supporting 720p, 1080i, 768p to HDMI out)
    -Internal video setup wizard for calibrating display to DVD player
    (Brightness, Contrast, Sharpness & Colour)
    -RGB SCART and component video outputs – latter supports both 525p
    and 625p video
    -HDMI video output, supporting the following formats: 480p, 576p, 720p,
    768p, 1080i
    -Dedicated 768p output for 768 line screens with appropriate HDMI input
    -Zero Chroma Upsampling Error (CUE)
    -NTSC to PAL and PAL to NTSC conversion
    -High quality zoom function with 1.25 and 1.5 settings to fill ‘wrong aspect
    ratio’ screens
    -6 x 11 bit 216 MHz Analog Devices video DACs – permitting simultaneous
    output of interlaced component (or RGB), S-video and composite video
    RGB, component and composite properly buffered 75 ohms video
    outputs, capable of driving long cables without distortion
    -Supports DVD-Video, VCD, SVCD, DVD-R, DVD-RW, DVD+R, DVD+RW discs
    plus CD, SACD (2 ch. only), DVD-Audio (2 ch./multi-channel mixed down to
    2 ch.) MP3, WMA, DiVX, Photo CD and JPEGs
    Surround receiver
    Amplifier power (watts): 7 x 80 watts (all channels driven at 1kHz, 100 watts RMS with 2 channels driven)
    Analogue audio: REAR: 7.1ch input (via 8 RCA/phono) Stereo line in (via RCA/phono) Tape loop (via 2 pairs RCA/phono) Zone 2 out (via 2 x RCA/phono) Subwoofer pre-out (via RCA/phono) FRONT: Headphone socket (via 6 1/4" stereo jack)
    Digital audio: 3 x optical digital in (vis toslink) 3 x coaxial digital in (via RCA/phono) Optical digital out (vis toslink) Coaxial digital out (via RCA/phono)
    DSP, eq. modes & audio options Music, party, club, small room, hall, sport & church eq modes Bass, treble & balance controls, dynamic compression control (adjustable for neighbour friendly listening) Stereo direct mode (disables all processing for the purest, unfettered audio reproduction). Variable lip-sync delay adjustment (up to 220ms)
    Finish: Silver. Sturdy, all-metal construction, built from heavy-guage steel and aluminium for maximum rigidity and improved EMC screening
    Key decoding: Dolby: Digital, EX, Pro Logic IIx (Movie/Music) DTS: ES, 96/24, Neo, Discrete
    On-screen display: Yes
    Speaker outputs: 7.1 channel output via 4mm banana plug/binding posts - can be configured for full 7.1, 5.1 with second stereo zone or 5.1 with bi-amplified front speakers
    Supplied accessories Remote control with batteries
    Tuner: FM/AM tuner with RDS and Radiotext for FM 30 presets for FM 10 prestes for AM
    Video format conversion: Composite to S-Video Composite to component S-Video to composite S-Video to component Features HDMI switching - redirects either HDMI input to HDMI output
    Video/Audio inputs & outputs 2 x HDMI in (supports HD up to 1080P) 3 x component video in (via 3 sets of 3 x RCA/phono) 3 x video in (S-Video, composite video & stereo line in, via 4-pin mini-DIN & 3 x RCA/phono) 2 x video loop (S-Video, composite video & stereo line in & out, via 2 sets of 4-pin mini-DIN & 3 x RCA/phono) HDMI, component video, S-Video & composite video monitor outputs (via HDMI socket, 3 x RCA/phono, 4 pin mini-DIN & RCA/phono respectively) Zone 2 monitor out (composite video out via RCA/phono)
    W x H x D (mm): 433 x 145 x 420
    Weight (kg): 15.9
    08.1234.234.768 ( SUPER SPECIAL PRICE ) !!!!
    京都- 日本
    SOLD ITEMS:
    - REGA APOLLO CD PLAYER.
    - UNISON RESEARCH UNICO TUBE CD PLAYER.
    - MARANTZ CD-17 MARK III.
    - HELIOS STARGATE CD PLAYER.
    - VERMOUTH RED VELVET MARK II
    - SONY X5000 CD PLAYER
    - TANDBERG TCA 3002 ( PRE-AMP )
    - TANDBERG TPA 3003 ( POWER AMP )
    京都- 日本
    SOLD BY MR.A
    京都- 日本
    08.1234.234.768 ( SPECIAL PRICE ! )
    京都- 日本
    京都- 日本
    京都- 日本
    京都- 日本
    京都- 日本
    京都- 日本
  1. Jual for home audio = hi end speaker ATC SCM 19 like new!!
    By iwanjogja in forum Bursa Audio Lainnya
    Last Post: 26th May 2011, 18:32
  2. Ultra Hi-end ABYSS A Class mint condition.............23,5jt
    By MR.GASOLINE in forum Power Amplifier
    Last Post: 22nd September 2010, 05:48
