I-charge saingan pivot raizin dan XCS ..mana bagus?
Results 1 to 10 of 52
  • Short URL:  http://modifika.si/56582
    2 Mins 23 Secs
    Mana bagusnya I-charge ( http://www.zeromaxnet.com/testimonial.php ), pivoot raizin, dan XCS ? saya cek testimonal i-charge lbh baik dan lebih bermutu... katanya kijang diesel sebelumnya 12:1 menjadi 18:1 irit banget....benarkah kualitas tdk dapat berbohong.. bahkan kebanyakan pemakai mobil mewah jg memakai alat tersebut.. harganya Rp.1,9 juta
    takut nanti kalau salah beli..
    Feature
    i-CHARGE Voltage Stabilizer 3in1
    • Voltage Stabilizer System
    • Interference Reducer System
    • Battery Doctor System
    Benefits
    • Fuel saving
    • Better RPM response
    • Increase engine torque
    • Engine power up
    • Optimized all electronic devices in car
    Advantages
    • Faster throttle response, engine power up.
    • Reduce car CPU noise signal, improve CPU reaction time, improve electronic efficiency.
    • Smoother gear shift on automatic car.
    • Improve engine power, better acceleration response, hence improve fuel saving.
    • Maximize ignition efficiency, easier engine start.
    • Prolong engine and electrical device life-span.
    • Easy installation, totally DIY, the first choice for ladies drivers.
    • Universal for all cars and motorcycles
    • Reduce noise with built in noise filter, improve sound system performance.
    • Equipped with double fuse protection, for better product life and safety.
    • Faster RPM response, it gives you powerful acceleration even when your car's air condition turn on to maximum load.
    • Cleaner exhaust emission on HC and CO gas. So more environment friendly.
    • Twelve (12) months Limited Product Warranty
    Jika Pivot Rp.700ribu termasuk tambahan kabel merek blitz.. jika XCS harganya sekitar 750ribu... setahunya pivot mampu sampaika berapa persen hemat BBM?
    kalau segini pivot dan xcs murah malah irit kayak i-charge, saya bakal pilih pivot aja.. tapi i-charge itu lebih baik saat ini..
    jika I-charge lbh efiktif dan pas daripada beli CAI, WAI, promixa, pivot dll......
    mohon pencerahan dunk
    west end jakarta - west end java
    4 Hrs 51 Mins 44 Secs
    waduh kenaikannya sampe 50% gtu bos tingkat keiritannya...klo bner si worthed bgt dg 1,9 jt bsa irit sampe 50%...tapi gw blm pernah denger ada produk jenis volt stabilizer yang bisa nambah irit sampe segitunya paling nae satu poin...coz secara logika jg kayanya g mungkin d....
    tapi coba tunggu komentar yang lain
    Bali-Surabaya
    4 Hrs 57 Mins 39 Secs
    wew baru tau ada merk laen lg
    kalo saya skarang pake pivot
    2 Mins 23 Secs
    Quote Originally Posted by d_cha_boy View Post
    ohh bagaimana perubahan hemat bbm dgn pivot? ngomentari donk..ehehe
    saya mau pasang gambar di atas yea.. berapa bandingan ...
    kalau Pivot Rp.700ribu termasuk pivot dan kabel non pivot.
    Kalau XCS berapa yea....
    2 Mins 23 Secs
    Quote Originally Posted by white_corolla88 View Post
    yea betul, tapi itu hanya kijang krista diesel.. 50 % lbh irit bbm
    tapi yg lain gak sampai 50%...
    ini sedang disurvey neh..
    6 Hrs 40 Mins 12 Secs
    ada juga produk lokal yag murah tuh... 450k
    dealernya Multiniaga Solusindo... udah sering promo di milist2 club/otomotif
    cara kerja juga sama...
    2 Days 19 Hrs 1 Min 38 Secs
    wah gua pake PIVOT raizin bgs kog bro... lbh enak n bertenaga.. tp gua paduin ama PIVOT ignition spark dan proxima D900 buat all new jazz gua...
    pertama serasa boyo bgt ga ada tenaga all new jazz matic gua, setelah pake smua ini jd enak bgt tenaganya.. gawsa gas dlm2 da ngaciir tuh mbl..
    klo begitu di tunggu ya hail surveynya klo trnyata berhasil minat jg..coz gw jg mw masang produk kaya gini tuk memperhalus transmisi...maklum matic
    tp mahal jg yah 1.9juta.. bs dibeli dmn ne?
    2 Mins 23 Secs
    Quote Originally Posted by anthony7789 View Post
    ada kontak atau email di website di atasnya... jgn beli i-charge dulu.. mumpung disurvey dulu..ehehe
Venom 300x250 MBtech
  1. JUAL Pivot VoltStabilizer + Mega Raizin + Spark Raizin type S + Ground Wire Pivot
    By lionel in forum ECU, Piggyback, Electronic Parts
    Last Post: 16th February 2014, 20:31
  2. DIJUAL 2nd hand untuk PIVOT Raizin Blue dan Pivot Raizin Red
    By A61 in forum Jual Beli Mesin Lainnya
    Last Post: 1st May 2012, 20:24
  3. WTB : Pivot Blue Raizin / Mega raizin Volt stabilizer original
    By faiz reborn in forum Jual Beli Mesin Lainnya
    Last Post: 15th March 2012, 16:41
  4. DIJUAL 2nd hand untuk PIVOT Raizin Blue dan Pivot Raizin Red
    By A61 in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 19th November 2011, 14:24
  5. Replies: 7
    Last Post: 11th May 2009, 13:53
