Bekas [WTS] Midrange Widerange Micro Precision 5.8
Results 1 to 10 of 17
  • Short URL:  http://modifika.si/565309
    3 Wks 4 Days 10 Hrs 17 Mins 41 Secs
    dijual Midrange Widerange MP5 - 5.8 kondisi ori, dan normal
    Details :
    The 5.8 uses extrem low weight membrane and voicecoil.
    This results in an extreme extended frequency range up to 20.000 Hz.
    The natural paper-membrane has no coloration of midrange and a,
    comparing to the small size, full bodied sound.
    The 5.8 can be used in cabinets from
    1-20 Liter and should be highpassed 120-150Hz / 6 or 12dB/oct.
    Technical information
    Micro Precision 5.8 Fullrange
    Height total [mm]
    53,5
    FS
    120 Hz
    Outer Diameter [mm]
    93,5
    Moving Mass
    2,1 gramm
    Cutout Diameter [mm]
    73,0
    Impedance
    Interior Depth [mm]
    50,0
    Powerhandling
    30 W
    Voicecoil
    Paper
    Voicecoil diameter
    15 mm
    Membrane
    Paper
    Recommend Filter
    120 Hz - oo
    Weight
    0,870 Kg / Pair
    hubungi ane di 0818832456
    up...up....up.....up.....up.....up.....up.....up
    up...up....up...up...upp....up...up....up
    up...up....up...pu....pu....up....pu....up...up... ..
    up...up....pu....up....up....up....up....up....up. ...up....up.
    up....up....up....up.....up....up....up....up...up
    Up....up....up.....up.....up....up.....up.....up
    Up...up...up....up...up...up....up...up
    Up....up.....up....up....up....up...up
    up......up....up....up....up....up.....up
  1. WTS--> MIDRANGE MICRO PRECISION 5.8
    By dobermann in forum Speaker - SubWoofer
    Last Post: 13th December 2011, 21:39
  2. WTS : MIDRANGE MICRO PRECISION MPZ 100 MK III. Kondisi OK :D
    By CARTENS in forum Speaker - SubWoofer
    Last Post: 11th October 2011, 18:43
  3. WTS : Midrange Micro Precision Z100 MKIII
    By kinglay in forum Speaker - SubWoofer
    Last Post: 11th October 2011, 00:30
  4. WTS: MIDRANGE Micro Precision MP 5.28.... (Update Pic)
    By driz in forum Speaker - SubWoofer
    Last Post: 3rd January 2011, 20:38
  5. wts: midrange micro-precision
    By adit_sastra in forum Speaker - SubWoofer
    Last Post: 13th February 2010, 23:02
