Baru [WTS] Kabel High End DC Acrolink mark II 7N 4030 stress free
Results 1 to 10 of 18
  • Short URL:  http://modifika.si/564900
    3 Wks 4 Days 10 Hrs 15 Mins 11 Secs
    Mau jual new roll kabel power ACROLINK POWER CHORD 7N 4030 MKII untuk head unit ,
    Bisa beli per m. harga 1,6jt / m
    Barang Ready
    True Purity of the 7N-P4030 II
    Various manufacturers claim to produce ultra high purity, 7N (99.99999%) copper. However, different refining processes yield materials that vary greatly in both the composition of impurities and crystalline structure.
    Most of the "so called" 6N and 7N materials are not measured comprehensively. Glow Discharge Mass Spectrometry - an extremely powerful tool for performing ultra-trace elemental analysis has been applied to pure copper used in the Acrolink 7N-P4030 II ac power cable. The results in the accompanying table demonstrate that Acrolink has achieved an unrivalled standard of purity.
    The Effect of Impurities
    Minute impurities create variations in impedance, inhibiting the ability of a cable to achieve extended frequency response. Responsible for meeting the needs of leading edge computer and aerospace technology, Acrolink has developed a multi-stage process that removes each impurity individually. Applying this to audio they have been able to achieve flat frequency response to 18 GHz in their Mexcel series!
    Stress-Free
    After the cable core is formed, the Acrolink Stress-Free process is applied to the 7N-P4030 in a clean, oxygen free environment. This imparts permanent self-annealing properties: No matter how often the cable is bent or impacted, it will always return to its original relaxed state (uniform crystalline structure).
    Dielectric
    A new polymer polyolefin, presently the best material available, has been chosen for the insulator of the Acrolink 7N-P4030, for its extremely low dielectric constant .
    Resonance Absorption
    Proper absorption of resonance is one of the key factors in determining final sound quality. Acrolink has focused on this issue for many years and developed tremendous expertise. Materials are carefully selected for each individual design in order to achieve perfectly balanced and effective absorption. A new polymer polyolefin, tungsten powder, and an amorphus powder has been chosen for the inner sheethe of the Acrolink 7N-P4030, for excellent vibration absorption. The outer jacket also utilizes a polyolefin material for excellent flexibility and vibration characteristics.
    7N-P4030 Specifications
    Conductors: 7N Copper, 0.26mm X 100 strands X 2 (red and black); Ground: 4N5 copper 0.26mm X 100 strands X 1 (green)
    Shield: Copper foil
    Conductor Resistance: 2.9 mΩ/meter
    Electrostatic capacitance: 13pF/meter
    Maximum current: 50A/VCTF STandard
    Price : $200 per metre
    Hubungi ane di
    0818832456
    7970BCBF
    up...up...up...up...up...up....up...up...up...up
    up...up....up.....up.....up.....up.....up.....up
    up...up....up...up...upp....up...up....up
    up...up....up....up....up.....up.....pu.....up
    up...up....up...pu....pu....up....pu....up...up... ..
    up...up...up...up...up....up....up....up...up...
    up....up....up....up....up.....up.....up....
    Up....up....up.....up.....up....up.....up.....up
    Up.....up.....up......up.....up.....up
NGK Busi Wuling
  1. BEKAS [WTS] Kabel power Acrolink mark II 7N 4030 stress free cable
    By nsr150 in forum Cables & Interconnects
    Last Post: 10th October 2014, 04:23
  2. Replies: 7
    Last Post: 28th February 2011, 22:14
  3. KABEL HIGH END 2ND============
    By puji in forum Bursa Audio Lainnya
    Last Post: 4th April 2010, 23:33
  4. WTS : POWER HIGH END TRU TECH T03.4.150 .......soldddddd
    By guciboy in forum Power Amplifier
    Last Post: 22nd July 2009, 18:00
